Utente della settimana: bluemask con ben 18 Thanks ricevuti negli ultimi sette giorni
Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 18
[MOD] HTCCamera 4.5 Plus | All Sense 4 ROMs
    Androidiani Power User L'avatar di iGuich
    Cattolica
    Ringraziato 2,998 volte in 2,007 Posts
    Vi presento la mod by lyapota!
    Thread
    Aggiunge delle funzioni alla nostra amatissima fotocamera.
    Quote Originariamente inviato da lyapota
    The MOD add some new options to HTS Camera application.
    Settings control - Image encoding quality set compression level.
    Settings option - Force audio quality set audio bitrate to 380000.
    Settings option - Force video quality set video bitrate to 760000. *
    Settings option - Hook volume keys set Volume Keys advanced usage. **
    Enabled Scenes for front camera.
    __________________________________________________ ___
    * HD resolution 720 and above.
    ** In checked state.
    Short press VolKey Up - start/stop video reccording.
    Short press VolKey Down - take picture.
    Long press VolKey Up - Zoom In.
    Long press VolKey Down -Zoom Out.
    Questo il changelog:
    Ver 6.1
    Reenabled auto enhance option.
    When taking picture during video recording auto enhance not using, image encoding quality set from media profile(without force).
    Ver 6.0 NewLife
    The sources fully reviewed and cleaned.
    Removed bloatware autofocus option and continues autofocus option.
    Disabled auto enhance option - for while testing on stability.
    Ver 5.0
    Enhanced Camera options - added auto enhance option*
    Added auto delete Camera.odex in install script for easier installation to ODEXED ROMs.
    Perfect
    * this is the camera params option, it not same as image post processing effect.
    Ver 4.0
    Now sources from ENDEAVOR 3.00.999.7
    Camera version changed from 4.0.2217232223.415382.414066 to 4.0.2217291261.415382.414066
    Very stable version. I have not yet had any hang or FC.
    Ver 3.0
    Enhanced Camera options added autofocus option.
    Enhanced Camera options added continuous autofocus option.
    Reorganized additions options.
    Check box Force video quality changed to List of values.
    Check box Force audio quality changed to List of values.
    Ver 2.0
    Enhanced Image Ajustments from 5 to 9 steps. *
    Enhanced Image encoding quality from 4 to 7 steps.
    Corrected Image encoding quality, now it work as planned.
    * Explosure fully working,
    Contrast 7 positions working (-4, -2, 0, +1, +2, +3, +4) - range limitation.,
    Saturation fully working,
    Sharpness 5 positions working (-4, -2, 0, +2, +4) - range limitation.
    Ultima modifica di iGuich; 13-09-12 alle 15:13
    Senior Droid L'avatar di freccia
    Bologna
    Moto Z FORCE,Yoga tab 3 pro
    Ringraziato 81 volte in 58 Posts
    Purtroppo questa mod fa le foto sfuocate
    LENOVO MOTO Z FORCE DROID STOCK 7.1.1
    LENOVO YOGA TAB PRO 3 6.0.1 STOCK
    Installare CWM 6.0.1.0 su tab plus 7 tramite Mobile Odin:
    http://www.androidiani.com/forum/mod...tab-p6200.html
    Cattolica
    Quote Originariamente inviato da freccia Visualizza il messaggio
    Sull'ARHD? Perchè sulla viper va e le foto non sono sfuocate
    Bologna
    Quote Originariamente inviato da Guich Visualizza il messaggio
    esatto...mi sembra di aver capito che lo chiamano FC questo difetto.
    Cattolica
    Già
    Leggi su quel thread?
    foggia
    htc one x-gLxy tab 2 7"
    Ringraziato 717 volte in 645 Posts
    È stato risolto,prima di flashare l'ultima mod flashate il.file che riporta i valori della fotocamera allo stato iniziale dopo flashate l'ultima mod dopodiché ,non si avrà nessun.fc
    inviato da htc one x,coredroid powered
  8. Il seguente Utente ha ringraziato cranio84 per il post:
    freccia (13-09-12)
  9. #7
    Bologna
    Quote Originariamente inviato da cranio84 Visualizza il messaggio
    Ho appena provato a fare come dici...in questi giorni vado in croazia e lo provo...
    P.S: Ottimo consiglio.Ora funziona bene
    Ultima modifica di freccia; 13-09-12 alle 20:53
  10. #8
    Bologna
    Già
    Si si...su xda
    Dal lontano 2006 quando avevo un imate Kjam...
  11. #9
    foggia
    Era tutto spiegato su xda freccia,comunque prego
  12. #10
    Senior Droid L'avatar di tomdelonge87
    HTC One X,Samsung Galaxy Note
    Ringraziato 21 volte in 21 Posts
    ma la stai usando sull'ultima viper? ho letto che già la rom ha una specie di mod per la camera..però non compare più in aroma tipo una spunta per selezionare la mod della camera come nelle vecchie versioni
    HTC ONE X WHITE
    ROM RD-MIUI
    FRANCO KERNEL R12/KERNEL STOCK
