1 allegato(i)
[ROM] IceColdJelly - 3.2.1 | AOKP MS1+ unofficial - JellyBean 4.1.2_r1
Adesso una bella Rom Aokp non ufficiale, ma ottima per il nostro One X.
Sempre funzionante con Hdboot 1.23 o successivi:)
[ROM] 31-10-2012 | IceColdJelly - 3.2.1 | AOKP MS1+ unofficial - JellyBean 4.1.2_r1 - xda-developers
immagine1
REFLASH boot.img for this version
update kernel to NCX v10beta4
Lockscreens: Remove dupe preference (Quick Unlock) - AOKP
GeneralUI: Give TabletUI its own category - AOKP
Lockscreen Targets: fix unlock and homescreen icons - AOKP
RC: Make Toggles hidable - AOKP
RC: Add setting to allow haptic feedback on toggle press - AOKP
Fix Widget Picker color - AOKP
Fixed German Navbar buttons selection issue
Calculator: New Features Part 2 - CM
Fix lockscreen "rings" issue with custom themes - AOKP
Lockscreen Wallpapers: Fix missing sw600dp layout elements - AOKP
NavBar: Tablet Nav bar adjustable width - AOKP
Fix launch of lockscreen targets/nav bar targets from shortcut - AOKP
Rebased Mms app on CM10's source
Maybe fixed Torch in Lockscreen from notification pull down list - AOKP
Lockscreen vibrate moved to Settings/Security - AOKP
RC: Clickable Date and Clock targets in notif are now configurable - AOKP
Camera: add option to select storage location - AOKP
added some patches to fwb, mms, settings and phone from AOSP master branch
SystemUI: add nothing option for clock and date - AOKP
Removed Powermodule and related scripts (boot.img dependant)
RC: Removed Scroller option for now to fix Chrome scroll and similar issues
DeskClock: Add option to hide AlarmClock Icon in StatusBar - ported from CM
fix aspect ratio for notification wallpaper - AOKP
WeatherPanel: Add options to hide weather panel - AOKP
WeatherPanel: add options for short and longclick - AOKP
Allow automatic data connection to APN_TYPE_MMS - CM
Latest Stable Release
Version: IceColdJelly V3.2.1 - 31-10-2012
MIRROR - http://expressleech.com/ch7essig8a0e...3.2.1.zip.html
gapps (Google applications - 20121011)
Boot.img funzionante con hdboot 1.23 o successivi
