1 allegato(i)
[ROM] BugX 1.0 [Jelly Bean] [3.14.401.27] [Android 4.1.1 Senso 4 +]
From Xda - Sebastiaan15
Feature
[SIZE=3]
Citazione:
Based on 3.14.401.31 Android 4.1.1 Sense 4+ Final JB WWE.
Require's Hboot 1.39 - it should also work with lower Hboot (Not lower then Hboot 1.30).
Choose between Stock or Multi-language (WWE).
ROM is build with the Latest Dsixda's Android Kitchen.
Deodexed, Recompressed & Zipaligned.
Removed all debugging info from App and Framework.
PNG Optimization in Apk's & Framework files.
Some Fixes and removed some unnecessary Stuff.
Unsecured boot.img.
Persistent ADB enabled.
SuperSU, Busybox and Sysro/sysrw commands support.
Init.d scripts support.
All Add-ons and Mods can be installed tru Aroma Installer. (So people can leave it Stock as well)
Aroma only system Partition format for Updating.(works perfect now).
Aroma restore's now your selected settings(Don't work if you format the data partition before you run aroma installer).
Widget Scanner script
Engraved Lockrings.
Beautiful BugX Bootanimation
Seb Number Battery
APM
And what i Forgot.
Changelog
BugX 2.6.2:
- Added back the Instant screen off / Power menu in notification dropdown
(for battery procent and number battery)(now it is working as it should)
(Thanks to Mivahe for how to)-(Also to Dunc001 for the fix)
- Add HTC Widget App and Shortcut in Installer -thanks to xcesco89
BugX 2.6.1:
- Fixed sense FC when pressing a option in popup bottom menu homescreen
and replaced notification with a other option
(thats the only way i now to fix the fc)
BugX 2.6:
- Removed Seb Number battery Noclock
(youtube video playback fc , and some other player)
(i think there must be more changed for this (noclock)
- Add Aosp Style recent apps
BugX 2.5:
- Updated Contact (there was a little ota update for this)
- Add Seb Number battery Mod with center clock or No Clock
(with or without transparent statusbar)
(thanks for PsyChoses to make them white)
- Fixed Lockrings - thanks to prof peach
(now without the V in the middle of the ring)
- Removed version 5 longpress control
(the version 6 is still in there)
- Add Volume Awake - Thanks to Alex-v
(not for the version with media control)
(i think thats not so good idea)
- Fixed Normal Advanced powermenu back button
(with no kill app function)
(kill app was still inside ,removed it)
- And some little fixes
- Also Fixed the lockrings in ADD-ONS
(without the V in the middle of the ring now)
BugX 2.4:
- Rebuild the rom from scratch again
(and the rest what i do to rebuild the rom)
- Fixed stock camera (not fc with recording anymore)
- Fixed google android camera 4.2
(not fc anymore when the is clock to center or no clock)
- Add Stock langauges in the aroma installer
(so people can choose stock or multi langauges in the installer)
- Add Version 6 from the Longpress Control - thanks to lyapota
(without play/pause),(but now volume down previous track , volume up next track)
- Updated Powersaver Mod to ver. 9.1 - Thanks to lyapota
BugX 2.3:
- Changed the name Context menu to Menu Button Support in aroma installer
(i think the name is better for the popup menu at the bottom)
- Reorganized text in aroma installer , cleaned up text in installer
- Add Version 5 from the Longpress Control - Big thanks to lyapota
(now also with longpress media control)
(i modify the longpress back key to 2 sec to kill the apps same as before)
BugX 2.2:
- Fixed Updater-script (for missing apps , with the system format partition only)
BugX 2.1:
- Updated lyapota HTC Camera JB 4.5 Plus Extrim to version 5.1 - thanks to lyapota
- Add Widget scanner to the install script - thanks to Patrics83 (no lost widgets anymore)
(i use only the script and modify it,so it is easier to add to aroma installer)
- Cleaned up the updater-script
- Cleaned up the aroma-config
BugX 2.0:
- Rebased on 3.14.401.31 - Thanks to Patrics83.
- Fixed disable exchange security mod - thanks to Shnizlon
- Added SMS Screen On in Aroma installer - Thanks to mwilky
- Added option to remove unneeded keyboards in AROMA - Good Idea Shnizlon
- Removed Lowest AutoBrightness
BugX 1.0
- Initial Release.
Downloads
Downloads
