[MOD] HTC-J shortcut widget port for One-X | Trasparent Clock widget|V1.0|3.14.401.31
    Androidiani Power User L'avatar di cesco
    Sep 2010
    Bg
    TYTN2,desire,desireHD, oneX
    Ringraziato 1,346 volte in 724 Posts
    Htc J Shortcut Widget Port for One-X
    salve gente!
    oggi vi propongo qualche mod che potrebbe piacervi per il vostro One X. si tratta innanzi tutto di un port del widget con le scorciatoie del Droid DNA (aka HTC J o Butterfly)
    screenshots:
    Changelog:
    codice:
    V1.0 - Initial release
            - resized widget
            - known bugs:
                - not perfect drag n drop on homescreen ( WIP)
                - edit mode screen need to be a little resized (WIP)
    Transparent 4X2 Clock, Droid DNA look
    dopo svariati tentativi di resizing o merging del widget orologio del Droid DNA, ho deciso di modificare quello originale del One X per renderlo simile a quello del DNA.
    ecco com'e'
    Default skin:
    con altre skins:
    Transparent 4X1 Clock, Droid DNA look
    Screenshot
    Download:
    Zip flashabile con Aroma Installer!!
    WidgetMods_V1.0.zip
    44.3 Mb
    Thanks to:
    • il Duce for the amazing VTS thread
    • Virtuous Team for give us the amazing Ten Studio!
    • Skydragon Team for make this possible
    • amarullz fo the Aroma installer
    • My brain
    Follow me on:
    <!-- Place this tag where you want the widget to render. -->
    <div class="g-person" data-width="180" data-href="//plus.google.com/113012341277613226011" data-theme="dark" data-rel="author"></div>
    <!-- Place this tag after the last widget tag. -->
    <script type="text/javascript">
    window.___gcfg = {lang: 'it'};
    (function() {
    var po = document.createElement('script'); po.type = 'text/javascript'; po.async = true;
    po.src = 'https://apis.google.com/js/plusone.js';
    var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(po, s);
    </script>
    <br>
    <a class="twitter-timeline" href="https://twitter.com/xcesco89" data-widget-id="398762031488040960">Tweets di @xcesco89</a>
    <script>!function(d,s,id){var js,fjs=d.getElementsByTagName(s)[0],p=/^http:/.test(d.location)?'http':'https';if(!d.getElementB yId(id)){js=d.createElement(s);js.id=id;js.src=p+" ://platform.twitter.com/widgets.js";fjs.parentNode.insertBefore(js,fjs);}} (document,"script","twitter-wjs");</script>
    Androidiani app
    Estensione Androidiani per Google Chrome
