Disponibile per 4.1.2/4.2.2 Sense e Google Edition ;)
Lo stesso Autore dell'ElementalX Flar2, con meno opzioni, più "semplice"
Basato sul Kernel stock, ma con alcune migliorie, Flashabile da Recovery, i diversi Settings saranno impostabili direttamente da Aroma e non necessita di app particolari (Viper e company) per la modifica.
July 22, 2013 - Bulletproof-4.2
-add option to enable fastcharge automatically
-fix sweep2wake bugs
July 21, 2013 - Bulletproof-4.1
-installer fixes
-new logo (thanks @deagleone)
-linaro 4.8.1 O3 build
July 20, 2013 - Bulletproof-4.0
-use Google Android toolchain 4.6
-update installer options
-fix for home button options (if not using logo2menu)
-add ability to restore 3-dot menu
-fix capacitive buttons sometimes still active while screen off
July 11, 2013 - Bulletproof-3.4
-fix touchscreen registering input during calls
-add TCP congestion algorithm options
-fix fastcharge (@tbalden)
-vibration feedback for s2w
-add sysfs config for sleep/wake vibration strength
-change lower voltage limit to 700mV
June 30, 2013 - Bulletproof-3.2
-fix BLN setting not applied
-update BLN
-fix for app-mounted directories (thanks @mkasick)
June 29, 2013 - Bulletproof-3.1
-add support for Android 4.2.2
-update aroma installer
June 23, 2013 - Bulletproof-2.1
-adjust doubletap2wake
-tweak hsic
June 20, 2013 - Bulletproof-2.0
-update to latest HTC sources (still 4.1.2!)
-updated camera (works with .16 base ROMs)
-updated capacitive button sensitivity
-revert earpiece audio patch
-remove camera fix
-adjust doubletap2wake sensitivity
-pocket detection only active when screen off
May 22, 2013 - Bulletproof-1.10
-make camera fix optional
-wifi as module
-revert arm rwsem algorithm
-adjustments and fixes to sweep/wake options
May 14, 2013 - Bulletproof-1.9
-add option to disable pocket detection
-add new settings schema for sleep/wake functions
-fix bug dt2w not working when s2w disabled
-change l2w to automatically sleep/wake after pressed for a certain time
May 12, 2013 - Bulletproof-1.8
-suppress accidental wakes with s2w and dt2w
-fix dt2w setting not sticking
-add button light notification @tbalden)
May 10, 2013 - Bulletproof-1.7.1
-fix for camera on .16 based ROMs (thanks to he_stheone64)
May 5, 2013 - Bulletproof-1.7
-add DoubleTap2Wake
-update faux sound control support
-add option to disable menubar
-minor fixes
May 1, 2013 - Bulletproof-1.6
-add vibration to logo2wake (tbalden)
-fix hsic wakelock
-faux123 sound control (faux123)
-optimized arm rwsem algorithm
-optimized AES and SHA1 routines
-disable usb whitelist
-fix fastcharge
April 25, 2013 - Bulletproof-1.3
-voltage control
-camera fix included
-added /dev/frandom
-glibc memcpy
April 22, 2013 - Bulletproof-1.2
-new implementation of sweep2wake
-CIFS fix (thanks tbalden)
April 21, 2013 - Bulletproof-1.1
-Fixed moc_crypto loading (kernel name is same as stock: 3.4.10-g42e6c45)
April 21, 2013 - Bulletproof-1.0
-fix earpiece sound in calls (many thanks to tbalden!)
April 16, 2013 - Bulletproof-0.5
-adjust sweep2wake
-force fastcharge (untested: use at your own risk)
-re-enable perflock
April 16, 2013 - Bulletproof-0.4
-adjust sweep2wake
April 16, 2013 - Bulletproof-0.3.1
-adjust boot.img
-add sweep2wake
-wifi driver built-in
April 15, 2013 - Bulletproof-0.2
-disable perflock
-arm cpu topology
-update cpu_power according to cpu load
-mhl change to 1280x720@60Hz
-add CIFS support
-add FIOPS and SIO i/o schedulers
-update ramdisk
April 13, 2013 - Bulletproof-0.1
-compiled -O3 with Linaro 4.7.3
-aroma installer
-based on HTC source code 1.28
-intellidemand governor
-init.d support
-ntfs r/w support
-xz kernel compression
-disable system write protection
-adjust readahead to 2048
-fast rcu nohz
Bella lì blackjack.....un GRAN BEL lavoro :cool:
Tienilo aggiornato e avvisaci in caso di aggiornamenti ;)
P.S. Tu l'hai provato?
02-08-13, 20:33
BlackJack89
Originariamente inviato da Actuamy
Al momento no, ho chiesto al mod se può andare scritto così, visto che compatibile con GE, si può fare un collegamento??
02-08-13, 20:47
Actuamy
Originariamente inviato da BlackJack89
Non ho capito che intendi per "si può fare un collegamento??"
Hai postato tutti i link, lo spoiler (utilissimo) con le differenze con l'ElementalX, i changelog, i link per il download per le G.E......
Che altro? ;)
P.S. blackjack....io mi ricordo questo nick (ma non molto bene del tuo avatar)....
Per caso in passato ci siamo beccati nel thread del modding di S3?
O forse in quello del kernel Shark?
02-08-13, 21:55
ldm85
Ciao a tutti su htc one 32 ita nero no brand e rom viper da 1 aggiornata direttamente a 1.2.1 si installa ma non funziona (il tel dice che monta kernel ma non prende i comandi sleep wake)
adesso riflasho kernel stock (eseguiti wipe) info in merito?
Ps. utilizzo la cwm touch (ultima v.)
02-08-13, 22:15
BlackJack89
Che altro? ;)
Si sono io ;-)
Originariamente inviato da ldm85
Non ho capito onestamente
03-08-13, 02:11
davideperbe
Io lo uso con ARHD 12 e devo dire che va molto bene... Il consumo energetico di questo kernel rispetto allo stock è molto ma molto più basso
03-08-13, 03:19
BlackJack89
Originariamente inviato da davideperbe
Hai provato anche l'altro più completo?
03-08-13, 03:31
davideperbe
No ho provato solo quello base... Prima avevo il kernel tbalden ma lo usavo solo per il logo to wake, come risparmio energetico meglio il bullet
Davide fai qualche ciclo di ricarica completo (almeno tre) e facci sapere di nuovo come và ;)
Noti differenze a livello di prestazioni/fluidità/velocità?
03-08-13, 08:01
ldm85
Ragazzi vorrei installarlo pure io sulla mia viperone 1.2.1 l'ho scaricato,messo nella memoria da pc e l'ho flashato e fin qui tutto ok,ma poi non cambia nulla,ovvero mi dice nelle impostazioni di sistema che è installato correttamente ma lo spero e il wake non funziona insomma non cambia nulla,come lo stock. Qualcuno l'ha provato sulla viperone?helpme please.
03-08-13, 11:25
iGuich
Devi settarlo durante l'installazione da aroma.
Se poi non ti vanno bene alcune impostazioni, devi cambiarle come scritto nel thread su xda.
03-08-13, 11:46
BlackJack89
Originariamente inviato da Guich
Che dici, lo aggiungo sotto?
03-08-13, 16:40
davideperbe
È già da tre settimane che lo sto usando, direi che a livello di prestazioni non ho visto questa grande differenza, mi sembra uguale a quello stock... Il bello di questo kernel sono le personalizzazioni che permette, io per esempio ho impostato il logo HTC come menù... E va' alla grande... Prima avevo provato il logo to wake and to sleep ma sembrava consumare un po di più in standby quindi l'ho modificato...
il problema di questo kernel così anche come quello elementalx è:
imageshack.us/a/img405/5844/senzanomeiw.png
03-08-13, 17:20
Actuamy
A durata della batteria come stai messo?
http : // imageshack.us/a/img405/5844/senzanomeiw.png
Correggi il link perchè non si vede la foto....
04-08-13, 02:34
davideperbe
A durata direi che sono sui due giorni con tre ore e mezzo di schermo acceso... niente di eccezionale ma ho sempre connessione dati arriva, mai wi-fi, luminosità controllata con lux dash...
Buona sera raga, io sono in attesa del nuovo revone per poter installare una custom rom senza avere problemi con la garanzia...poi mi interesserebbe un kernel che abbia lo slide2wake o logo 2 wake, devo sempre aspettare il revone per installare il kernel senza toccare la garanzia?
12-08-13, 05:27
Actuamy
Originariamente inviato da fabionik2004
No assolutamente.....
Una volta che installi una RUU, il kernel ritornerà stock (come anche al recovery).
12-08-13, 11:42
fabionik2004
Quindi in attesa del nuovo revone posso gia intallare un kernel sulla mia stock senza invalidare la garanzia e senza sbloccare nulla? E quale kernel mi consigliate considerando che poi lo installerò anche sulla viperone?
12-08-13, 13:06
Actuamy
Vai tranquillo fabio ;)
L'unica cosa è che dovrai re-installare il kernel stock per la garanzia ;) Se hai la versioen build 2.24.401.1 ce l'ho già ;)
Sennò male che va, dovrai installare una RUU e tornerai come nuovo ;)
ho letto che si installa da recovery questo significa che di base c'è gia una recovery installata? qual é la sequenza per entrarci?
12-08-13, 14:09
Actuamy
Ovviamente si.
Ogni ROM ha una recovery....ma per installare un kernel custom c'è bisogno di una recovery custom.
Puoi scegliere tra la CWM e la TWRP (piena di tweaks e più completa).
P.S. Il kernel che ti ho linkato nel post precedente non è altro che la versione "full" (per così dire) di quello del thread in cui ci troviamo ora ;)
12-08-13, 14:23
fabionik2004
grazie mille... quindi anche la custom recovery non tocca la garanzia giusto?
12-08-13, 14:27
Actuamy
Certo che si.
Per la garanzia ci vuole la recovery STOCK, non una custom.
Ma installando la RUU torna tutto stock, sia recovery che kernel (nel caso in cui lo andassi a modificare) ;)
12-08-13, 14:32
fabionik2004
si scusa ho sbagliato io volevo scrivere stock..il mio numero di software é 2.24.401.1 in caso avrò problemi posso rivolgermi a te per scarcarlo allora..ciau e grazie...mi metto all opera
12-08-13, 15:15
fabionik2004
Actuamy please sono bloccato in attesa di un tuo cenno...come faccio ad installare la custom recovery se non sblocco il bootloader? e come faccio a sbloccare il bootloader se ho una stock rom 4.2.2?
12-08-13, 16:19
Actuamy
Giustamente....il revone non funziona con la 4.2.2
Dovresti fare un downgrade: cioè installare una RUU più vecchia, in modo tale che l'HBOOT cambi e poter utilizzare il revone.
Allora sto facendo una confusione enorme...
riepilogo della mia situazione:
Ho acquistato un htc one e questo risulta gia essere aggiornato ad android 4.2.2.
Io vorrei installare la Viperone e un cusom Kernel senza pero' invalidare la garanzia e mi è stato risposto che al momento attuale non è possibile perchè non c'è il revone compatibile.
Poi ho chiesto se è possibile installare solamente il Kernel e Actuamy mi hai detto di si che però bisogna installare prima una custom recovery.
Seguendo la guida però bisogna prima sbloccare il bootloader senza revone il che significa invalidare la garanzia.
Adesso Actuamy mi hai detto di fare il downgrade, in questo caso non bisogna sempre sbloccare il bootloader prima invalidando la garanzia?
12-08-13, 17:28
Actuamy
Giusto...
Se hai una rom sbrandizzata (senza bootanimation o tool e programmi di qualche operatore) allora puoi installare la RUU.
Tanto se la tua rom è no-brand, con la RUU torni apposto per la garanzia.
12-08-13, 17:55
fabionik2004
Si ho una rom sbrandizzata:
Dunque in linea di massima dovrei fare il dowgrade e poi seguire la guida per il 4.1.2 utilizzando il revone?
E per quanto riguarda il back-up della mia ROM STOCK come faccio? Premetto che ho acquistato il mio HTC in Svizzera infatti nelle lingue non c'è italiano ma italiano svizzera (se puo' essere utile)
PS per installare la RUU non bisogna sbloccare il bootloader prima?
25-08-13, 10:28
BlackJack89
Devi avere recovery custom, segui prima la guida stickata ad inizio sezione
25-08-13, 16:22
fabionik2004
