Visualizzazione dei risultati da 1 a 10 su 27
[ROM] AndroidNow NG || Android 4.4 || Sense 5.5
    Androidiano L'avatar di electrostatus
    Casa mia
    HTC One
    Ringraziato 79 volte in 48 Posts
    AndroidNow NG 4.4.0-10
    Tutte le modifiche sono presenti nell'installer AROMA
    New Base 4.06.1540.2
    Android 4.4
    Sense 5.5
    OpenGL ES 3.0
    Updated Kernel
    Updated Aroma Installer
    Keyboards WWE
    Added HTC TaskManager
    Added HTC File Explorer
    Ability to turn off BlinkFeed
    Improved BlinkFeed
    Improved UI Experience
    Audio improvements
    Camera improvements
    Updated OEM Apps
    Many visible UI changes
    Add Battery 100%
    Add HTCPowerManager - disabled PowerSaver notification
    Add Sound Mod ViPER4Android FX
    Add Beautiful icon weather(optional)
    Add Beautiful icon status bar(optional)
    Add Landscape Sense Prism to AutoRotate
    Add Bootanimation Black Theme (AndroidNow)
    Add Camera Panorama 360
    Remove Photo Grid - Removes the dots for low resolution contact pictures
    Mail Exchange Disabled Security - useful if you work email makes you use a pin on phone for work email, decreases security!
    Disable Software Rendering - Forces all rendering to be done by GPU only
    ASOP Style Recent Apps - Changes recent apps style from HTC to android default
    Boot Sound - Enable Sound inclusion when starting
    NFC Notification Icon - Remove power saving persistent notification
    OpenVPN Support - Enable VPN Support
    SQLite Support - Enable SQLite Support
    Disable Noise Suppression - Use this only if people have trouble hearing you / phone only European
    PureXAudio - Greatly enhance your audio entertainment
    Many other changes ......................................
    Changelog 4.4.0-6:
    Fixed problem with root
    Fixed problems with NFC (modification) I hope so
    Added new modifications to the AROMA
    Other minor changes and fixes
    Changelog 4.4.0-9:
    rebuilding AROMA Installer
    Fixed a problem with the battery charging animation
    Removed erroneous modifications (return as a'm done with the repair)
    Full language localization is added to the pop-up menu launcher
    should be quickly and efficiently (including battery)
    Other minor changes and fixes .....
    Changelog 4.4.0-10:
    fix error ''set-perm error and abort install: 7''
    fix error V4A
    Installazione:
    Per installare avete bisogno della TRWP 2.6.3.3 e del firmware FW 4.06.1540.2
    Scaricate il file zip lo copiate nella radice del telefono e tramite recovery procedete all'installazione (dopo i vari wipe del caso)
    Download:
    AndroidNow
    I ringraziamenti vanno al creatore della rom "S3V3N"
    Altri ringraziamenti speciali a: V6-Maniac
    lyapota
    team venom
    w00dstock
    baadnewz
    Commento personale attuale:Sto testando la rom ormai da alcune ore. La bellezza è centrata sulla personalizzazione e le trasparenze dei menù,inoltre,il tema che è presente negli screen è qualcosa di eccezionale! Anche se siamo alle prime versioni della rom sembra andare tutto per il verso giusto come una stock htc ma personalizzata al meglio. In queste 4 ore di uso ne crash ne altro...staremo a vedere!
    Ultima modifica di electrostatus; 16-12-13 alle 17:06 - Motivo: Aggiornamento
    Casa mia
    HTC One
    Alcuni banner della rom
    Androidiano VIP L'avatar di Actuamy
    Martina Franca (TA)
    Samsung S8+
    Ringraziato 1,439 volte in 1,268 Posts
    Ma la stai usando?
    L'hai flashata?
    Smartphone: Oppo Find 7
    Operatore: H3G
    Rom: Stock
    Kernel: Stock
    Recovery: TWRP 2.7.1.0
    ColorOS Version: 1.2.3i
    Casa mia
    HTC One
    Quote Originariamente inviato da Actuamy Visualizza il messaggio
    Ma...
    Aggiunto commento personale al post
    Io cerco di fare del bene postando quello che so e aiutando per quello che so. Se gradite mettete un mi piace!
    HTC One REGNA!
  6. Il seguente Utente ha ringraziato electrostatus per il post:
    Actuamy (08-12-13)
  7. #5
    Dopo due ora di uso di questa rom, il cell mi si è spento e non si accende più, come devo fare??
  8. #6
    Casa mia
    HTC One
    Non si avvia per nulla?? Se è così credo che non sia problema della rom
    HTC One REGNA!
  9. #7
    Invece io penso proprio di si poichè ho flashato tante rom, ma solo questa mi ha dato il problema, quindi
  10. #8
    Casa mia
    HTC One
    Quote Originariamente inviato da Moxy Visualizza il messaggio
    Io penso che ancora non so l'entita del danno finche non mi dici effettivamente cosa fa il telefono..
    HTC One REGNA!
  11. #9
    parlando con un altro utente ho constatato che si sia brikkato, e ora non so come recuperarlo
  12. #10
    Casa mia
    HTC One
    Te lo ripeto la mia domanda è stata chiara...non si avvia per nulla? Fastboot o altro?
    Anche io ho questa ROM e a me va perfettamente
    Ultima modifica di electrostatus; 10-12-13 alle 23:03
    HTC One REGNA!
