Piccolo aggiornamento. Ho scritto al supporto SunShine, per la precisione li ho contattati tramite una chat. Il supporto mi ha chiesto espressamente quale ROM ho sul device precisando che se è una Sense devo flashare un kernel non-debuggable tramite TWRP e poi riprovare con l'applicazione SunShine.
Ecco quello che ci siamo detti in chat:
[14:07] == Marco_____ [50b6608c@gateway/web/freenode/ip.80.182.96.140] has joined #sunshine-support
[14:08] <Marco_____> hello!
[14:08] <@nkk71> hi
[14:08] <Marco_____> i'm italian, sorry for my english! :)
[14:09] <@nkk71> np, your english is fine
[14:09] <Marco_____> I downloaded and installed SunShine APK
[14:09] <Marco_____> I have an error:
[14:09] <Marco_____> "SunShine can not function on devices which are set to debuggable. You need to flash a non-debuggable ramdisk/kernel (boot.img). Our support staff can help you with this."
[14:09] <@Zanzibar> !info debuggable (Triggered by Marco_____ saying "non-debuggable")
[14:09] <@NookieBot> DEBUGGABLE = If you are running a Sense ROM, flash
https://www.dropbox.com/s/g1egybl8vd..._v2.2.zip?dl=0 TWRP. If you are running CM or any AOSP, you need to flash a Sense ROM.
[14:10] <@jcase> Marco_____, flash the above zip
[14:10] <Marco_____> ok
[14:10] <@nkk71> nookie to the rescue :), Marco_____ flash that try again
[14:10] <@nkk71> what rom are you running on what device?
[14:11] <Marco_____> NuSenSeveN v4.02 GSM 05-07-15 (Android 5.0.2 & Sense 7)
[14:11] <Marco_____> OK, I try flash the zip
[14:11] <@nkk71> yep, try that first (it's small and easy)
[14:12] <Marco_____> ok thanks very mouch
[14:12] <Marco_____> :)
[14:12] <@nkk71> no problem
Volevo chiedervi se è capitato a qualcun altro oppure sono il primo ad effettuare questa operazione....
