[ROM][RC]AOKP "Initiate Your Swagger"[4.1.2][Jan 20][OTA][Playstation][AC!D][OTG]
Sense 4 "Like" Recent's --> <-- Optimus Lock Screen
Questa è la mia prima AOKP Rom...Sviluppata usando il device tree di Bruce2728.
Video By:eadm
Video By:MrSoTech Updated 11/20/12
Video By:Alien44 Video By: Ducter
Per chi vuole sapere le differenze tra CM10 e AOKP guradi qui.
Funzionante
*WiFi hotspot Tested. Working w/encryption
*Front Facing Camera
*Voice Recorder
*Navigation Bar Tweaks in Rom Control
*Camera
*Wifi
*Audio
*Calls & data
*Hardware acceleration
*button lights
*vibration
*USB Mount
*Charging
*LEDs led
*Sensors
*Root
*Headphones
*Torch
*Bluetooth
*Voice Search
*Video playback Thank's to R.M.S,bruce2728,me
*Playstation Mobile
Come usare Goo Manager OTA scarica e flasha manualmente, NON usare Auto Flash!
Check for update
Download, wipe cache and install rom
Reboot
To enable ZRAM use tweaks v1.3 or edit system/etc/89tweaks go to where it says ZRAM=0 and put ZRAM=1 that will enable it...Then go to system/etc/sysctl.conf and change vm.swappiness to 100...save then reboot go to terminal and type in free and you will see the swap used and free...
Downloads Available Addons...4.2 JB Stuff with and w/o keyboard,AC!D Audio Engine, Playstation Mobile App,Kernel Tweaks v1.3,Awesome Beats,remove sense 4 recents mod
All Downloads Here @ Goo.im For Dec 14+ Install PSM.apk from Fixes Folder
Test Builds
Stockish MMS.apk thread
Un full wipe è necessario solo se venite da un altra ROM.
Prima Installazione
DO NOT use a superwipe script,
1.Wipe/factory reset (Full Wipe)
2.Install ROM
3.Install Gapps
4.Reboot...
Updates Install
1.Download Update
2.Reboot into Recovery
3.Flash Update
4.Wipe Dalvik Cache & Cache
5.Reboot...
Change Govenor
1.Download Setcpu or System Tuner from the Play Store
2.Download Tweaks v1.1 in Downloads Section
3.Select The Govenor You Want
4.Reboot into Recovery Flash Tweaks v1.1
5.Select Use Other Govenors If you go back to badass, flash stock...That will reinstall the badass script
6.Reboot...
AOKP Source: Here
AOKP Gerrit Status: Here
Burce2828 Github: Here
My Noobish Github: Here
Ringraziamenti Speciali
Bruce2728
intervigilium
cretin45
Vorbeth
CyanogenMod Team
AOKP Team
R.M.S
duchian for FTP Server
ivicask
eadm
MrSoTech
rmd3only
Indirect
Jiggs82
Bluewall
Team AC!D
All the guys over in #JB-pyr Freenode
Standard disclaimer
La tua garanzia ora è invalidata.
Non sono responsabile per device brikkati, sd card nno funzionanti, guerre termonucleari, o del tuo licenziamento perchè la sveglia non ha suonato.
Sei TU che scegli di usare questa ROM e modificare il tuo telefono perciò se mi incolpi di qualcosa, RIDERÒ DI TE!
