Pagina 1 di 2 12 ultimoultimo
[ROM][RC]AOKP "Initiate Your Swagger"[4.1.2][Jan 20][OTA][Playstation][AC!D][OTG]
    Nexus 4
    Sense 4 "Like" Recent's --> <-- Optimus Lock Screen
    Questa è la mia prima AOKP Rom...Sviluppata usando il device tree di Bruce2728.
    Video By:eadm
    Video By:MrSoTech Updated 11/20/12
    Video By:Alien44 Video By: Ducter
    Per chi vuole sapere le differenze tra CM10 e AOKP guradi qui.
    Funzionante
    *WiFi hotspot Tested. Working w/encryption
    *Front Facing Camera
    *Voice Recorder
    *Navigation Bar Tweaks in Rom Control
    *Camera
    *Wifi
    *Audio
    *Calls & data
    *Hardware acceleration
    *button lights
    *vibration
    *USB Mount
    *Charging
    *LEDs led
    *Sensors
    *Root
    *Headphones
    *Torch
    *Bluetooth
    *Voice Search
    *Video playback Thank's to R.M.S,bruce2728,me
    *Playstation Mobile
    Come usare Goo Manager OTA scarica e flasha manualmente, NON usare Auto Flash!
    Check for update
    Download, wipe cache and install rom
    Reboot
    To enable ZRAM use tweaks v1.3 or edit system/etc/89tweaks go to where it says ZRAM=0 and put ZRAM=1 that will enable it...Then go to system/etc/sysctl.conf and change vm.swappiness to 100...save then reboot go to terminal and type in free and you will see the swap used and free...
    Downloads Available Addons...4.2 JB Stuff with and w/o keyboard,AC!D Audio Engine, Playstation Mobile App,Kernel Tweaks v1.3,Awesome Beats,remove sense 4 recents mod
    All Downloads Here @ Goo.im For Dec 14+ Install PSM.apk from Fixes Folder
    Test Builds
    Stockish MMS.apk thread
    Un full wipe è necessario solo se venite da un altra ROM.
    Prima Installazione
    DO NOT use a superwipe script,
    1.Wipe/factory reset (Full Wipe)
    2.Install ROM
    3.Install Gapps
    4.Reboot...
    Updates Install
    1.Download Update
    2.Reboot into Recovery
    3.Flash Update
    4.Wipe Dalvik Cache & Cache
    5.Reboot...
    Change Govenor
    1.Download Setcpu or System Tuner from the Play Store
    2.Download Tweaks v1.1 in Downloads Section
    3.Select The Govenor You Want
    4.Reboot into Recovery Flash Tweaks v1.1
    5.Select Use Other Govenors If you go back to badass, flash stock...That will reinstall the badass script
    6.Reboot...
    AOKP Source: Here
    AOKP Gerrit Status: Here
    Burce2828 Github: Here
    My Noobish Github: Here
    Ringraziamenti Speciali
    Bruce2728
    intervigilium
    cretin45
    Vorbeth
    CyanogenMod Team
    AOKP Team
    R.M.S
    duchian for FTP Server
    ivicask
    eadm
    MrSoTech
    rmd3only
    Indirect
    Jiggs82
    Bluewall
    Team AC!D
    All the guys over in #JB-pyr Freenode
    Standard disclaimer
    La tua garanzia ora è invalidata.
    Non sono responsabile per device brikkati, sd card nno funzionanti, guerre termonucleari, o del tuo licenziamento perchè la sveglia non ha suonato.
    Sei TU che scegli di usare questa ROM e modificare il tuo telefono perciò se mi incolpi di qualcosa, RIDERÒ DI TE!
    Nexus 4
    Code:
    Changelog
    Jan 20
    -Added SIO IO sched.
    -Added BFQ IO Sched.
    -Max Freq. Now 1944 Mhz (Not recommended for everyone or everyday use) Default is still @ 1188 Mhz
    -And yes finally updated to 3.0.53 with good battery life
    -Fixed OTG USB Storage for good (tested by me)
    -vm.swappiness = 100 already included for those who use ZRAM
    -Many Other Changes....
    Jan 15
    -Added Rom Based Ad Blocker
    -Added Beats Logo When pluging headsets in
    Addons
    -Added remove sense 4 recents mod (as flashable zip)
    Jan 8
    -Added Mirror Effect to Sence 4 recents
    Jan 7
    -Fixed Dolby Digital left side sound only in headset mode
    -Fixed WiFi Screen off disconnect(Kernel)
    -Added Screen off speed managment PM_MAX/PM_FAST By: franco.Kernel (Kernel)
    Tweak1.3
    -Added option to use my kernel settings (Frankinstine's Setting)
    Jan 6
    -Added Intellidemand Govenor and set as default
    -CPU Clock set back to 1188 (Kernel still overclockable)
    -Fixed MMS Picture's in bubble
    Non Rom Related
    -Fixed goo.im files not veiwable in goo app or some browsers
    Jan 4
    -Removed Buggy Group Messaging
    -Added CM Keyboard Let me know if you want me to keep it
    Jan 2
    -Added New Sense 4 "like" Recents
    Dec 29
    -Added CM Filemanager
    Dec 25
    -Added AC!D Audio Engine Thank's Knight47
    -Fixed Dolby Digital headset/speaker
    -OTG Fix Please Test...
    Dec 20 Merry Christmas
    -Fixed Gtalk voice bug...
    Dec 17
    -Added Scroller Options
    -Added Increasing ring tone
    -Removed PSM.apk (playstation mobile App) Install manually w/PSM.apk in Tweaks and Addons folder
    Dec 14
    -Added HTC WiFi Voltage By:Bluewall Thanks Bruce2728
    -Removed Scroller Options (Not Much Difference with it on)
    -Added and working Playstation Mobile
    -Forgot to add increasing ring tone...
    Nov 22
    -Fixed Picture message text overlap Still have some overlap to with phone number and time though
    -OTG Fixed please test
    -Cyanogenmod Auto retrieve fix added
    Nov 13
    -Added alpha settings to Circles lockscreen rings
    -All latest merged commits till Nov 13...
    Nov 12
    -Fixed CRT flicker (Thanks Bruce)
    -Updated Kernel to 3.0.50
    Nov 10
    -System UI FC's are fixed
    -Minor Fixes
    -All latest merged commits till Nov 9...
    Nov 9 System UI will FC...Don't Panic! It's a known bug and will only FC on rotation and is already being fixed...
    -Updated Kernel to 3.0.49
    -Fixed Hardware Info in settings
    -New Optimus 4x lockscreen w/ring colors,etc
    -Headset restore correct volumes when plugged in
    -Added Lefty Mode
    -Added Scroller control again
    -All latest merged commits till Nov 8...
    Nov 7
    -Added Hardware Info
    -MMS Theme Settings
    -Forgot to Add Scroller Settings
    -Added Open Commit WeatherPanel: Add toast
    -All latest merged commits till Nov 6...
    Nov 4
    -Added Camera Settings 8mp 16.9,8mp 4.3 etc...
    -Added Camcorder 1080p thanks to cile381
    -Added Default device volumes not initialised
    -Added Option to show connected wifi network in notifications
    -Added Lockscreen before secure unlock
    -Fixed Performance FC...
    Nov 2
    -Added Increasing ringtone volume option
    -Added Port CM Advanced Phone Settings
    -Removed Group mms threading
    -Could not add lockscreen before secure unlock, I will have to manually add back on next update...
    Oct 30 Still Alive!
    -Added Open commit group MMS
    -Added Scroller Control Friction & Velocity
    -Added fast charge on kernel side
    Oct 27 Last Update Before Hurricane SANDY Passes!
    -Added "Vibrate on Touch" behavior for Slide unlock
    -Torch Fixed
    -Added Make Toggles hideable
    -Fixed Secure WiFi Hotspots
    -Latest Gerrit Changes...
    Oct 25
    -Added Open commit "lock screen before secure unlock"
    Oct 23 Please Wipe Data
    -Added WiFi Fix
    -Fixed Video playback again
    -Updated to build 5 aokp
    -Added Wifi tethering toggle
    -And More....
    Oct 19
    -Swagg Kernel updated to 3.0.46
    -Added smartassV2 & lagfree govenor
    -Added Sweep2wake
    -Removed Second Quick pin in lockscreen settings
    -Updated Nova Launcher
    -Updated to Oct 19 gerrit...
    Oct 17
    -Badass govenor fixed
    -Reverted back to 3.0.43
    -Sweep2wake & lagfree govenor temp. removed
    -Lock Screen targets finally merged on gerrit ( we already had )
    Oct 16
    -Added 2G toggle
    -Fixed/removed double Quick Pin setting
    -updated to JB 4.1.2 JZO54k
    -SDcard Speed to 1024
    -Update to latest gerrit commits
    Oct 15
    -Fixed Video Playback (local)
    -Fixed YouTube overlay and playback
    Oct 13
    -Added CRT animation
    -FFC Fixed (thanks bruce2728)
    -Updater Fixed TWRP Recovery Needed For it to Auto flash...
    -Added lockscreen targets
    -Fixed framework graphic glitches
    -more
    Oct 8_Test -->Graphic Glitches Are Back!
    -Added GooManager Manual Updates for now!!
    -Fixed Youtube overlay
    -Added Lockscreen Custom Targets
    -Swagg Kernel (based Off Bruce's JB Kernel)
    -Updated To Oct. 8 Gerrit.
    Oct 05
    -Added New Boot Animation
    -Video Playback w/o disable hw overlay
    -Added Data Toggle
    -Added Bruce2728's JB Kernel
    -Added SD card tweak (512 for now)
    -Updated to Oct.2 Gerrit
    Sep 25
    -Added gapps
    -Updated to Sep.24 gerrit
    Sep 23
    -Fixed graphic glitches
    -Updated to JB Version JRO03R
    -Updated to Sep.22 gerrit
    Sep 20
    -Added OTA Updater
    -Updated to Sep. 19 --> Here
    Sep 19
    -Fixed Video Playback some more (still have to disable HW Overlay)
    -Added Tile Rendering
    -Fixed Data drop bug again... For Devs: my data drop was a bad commit in framework/base/telephony
    -Tablet mode has been added
    -Custom LCD Density
    -Custom Vibrations
    -Smoother than Sep-5 build
    -Updated to new build JRO03L
    -Now Using CM's Audio to fix all or most routing issues
    -and More...
    Sep 5
    -Fixed Camera Orient.
    -Fixed Cam 720p & Playback
    -Added Lots Of tweaks
    Build 1 Deleted From Server
    -Added Carrier label back on
    -Added Lock Screen text color
    -Added Clock Color chooser from ICS
    -Fixed Nav Bar Again
    -Voice Recorder Works
    -Added mdecision and thermald
    -And More
    Aug 24
    -Fixed Data
    -Removed Carrier Label Temp.
    -Minor Fixes
    Aug 19
    -Some Weight loss
    -Carrer Label addon
    -Swag Papers
    -And More
    Aug 17
    -Fixed Headphones
    Aug 16
    -Fixed voice search but broke headpohnes (use headset routing app from store)
    -Removed Aug 11 and Aug12 initial builds from downloads
    Aug 15
    -Add the latest merges but BROKE VOICESEARCH! (Will fix in next build)
    -Nav Bar working -tested by me
    Aug 14
    -Fixed Headphones
    Aug 12
    -Fixed bootanimation
    -Partially fixed cam w/ivicask's Files
    Aug 11
    -Initial Release
    Nexus 4
    spero che questa rom venga seguita anche qui su androidiani perchè è davvero un'ottima rom!! la sto usando da qualche tempo e nn ha nessun problema!! gira veloce e fluida con nova launcher e nn consuma troppo come le altre jb..in piu rispetto alle altre ha mille tweak da usare per la personalizzazione che la rendono molto piacevole e comoda!! =)
    Androidiano VIP L'avatar di paoloc67
    Jun 2009
    Noale (ve)
    Samsung S6 edge green
    Ringraziato 397 volte in 344 Posts
    se guardavi bene è già da ottobre che questa rom è presente :https://www.androidiani.com/forum/mo...zo54k-ota.html
    Un grazie se meritato non costa niente , premete il pulsante nell'angolo in basso a sinistra
    Nexus 4
    sorry..nn l avevo visto..
    cmq per chi vuole qui c è il link dei download sia della rom che delle mod
    http://goo.im/devs/frankinstine
    Ultima modifica di pierre88; 28-01-13 alle 20:09
    OnePlus2,Nexus5,HTC Sensation
    Quote Originariamente inviato da pierre88 Visualizza il messaggio
    Goo.im Downloads - Browsing frankinstine
    ho fatto un danno credo!!!!!!
    dopo aver installato la ROM riavvio e mi rimane sulla schermata con l'unicorno e gli ingranaggi che girano!!!!!!
    Sono bloccato lì...non va più avanti e non ho un backup perchè nella fretta mi sono dimenticato di farlo!!!!!!!!!
    Cosa dovrei fare?
    Nexus 4
    Che firmware hai?? Hai controllato la md5 della ROM che hai scaricato?? Coincide?? Hai provato a reinstallarla dopo full wipe?
    Inviato dal mio HTC Sensation usando Androidiani App
  9. #8
    come non detto, mi sono accorto che qualcosa era andato male durante l' s-off e ho rifatto la procedura.
    hai un link per le g-apps???
  10. #9
    ora ho un altro problema, se installo le gapps il telefono continua a riavviarsi in ricovery...
  11. #10
    Nexus 4
    Le gapps le trovi li nel link..installa nella ordine ROM e poi gapps..se non ti si riavvia ti mando il link io..
