Pagina 1 di 27 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 267
[ROM] Android Revolution HD™ 3.6.11 XE | High Quality & Performance | OC |
    Androidiano VIP L'avatar di skanky80
    Apr 2011
    Udine
    Ringraziato 205 volte in 182 Posts
    Exclamation
    Hello flashmaniacs!! Ecco a voi l'ultima Revo!! La rom più popolare che esista su XDA!!
    Se cercate qualcosa di stabile per un ottimo daily usage siete nel posto giusto!!
    Link al thread uficiale della rom su XDA
    Parlando di Android Revolution HD
    Dettagli sistema:
    • Android 2.3.4 (Gingerbread) - latest official HTC RUU 1.73.401.2
    • This ROM will turn your HTC Sensation into powerful HTC Sensation XE with Beats Audio technology and 1.5 GHz dual core!
    • This is improved version of stock ROM - no visual changes!
    • Very fast, clean & stable!
    • Full HTC Sense 3.0 Interface
    • Multi-language (WWE)
    • Arabic and Hebrew languages full support! (see the second post)
    • HTC Sensation 4G (US T-Mobile) support with Wi-Fi Calling
    • For HTC Sensation, HTC Sensation 4G & HTC Sensation XE
    Dettagli kernel onboard:
    • New kernel: 2.6.35.14 (under-volted & tweaked)
    • CPU up to 1.56 GHz (1.51 GHz by default - original speed for MSN8660 chipset) - controlled automatically by built it O/C Daemon. How to use O/C Daemon?
    • If you want to control CPU manually, you would need SetCPU from here: SetCPU
    • In SetCPU remember to check "Set on Boot", but using O/C Daemon gives much better performance and battery then SetCPU
    • Many CPU governors (SmartAss, Ondemand, Performance, Conservative, UserSpace)
    • GPU+ patch (Improved 2D & 3D Graphics performance
    • 3D Engine overclocked from 266.6 MHz to 320 MHz
    • L2 Cache Bandwidth Boost from 310MHz to 360MHz
    • Synchronous L2 Cache
    • V(R) I/O as default scheduler
    • SLQB Memory Management
    • CIFS, TUN & UTF8 support
    • LZMA compression
    • Wi-Fi module improved drivers
    • Code cleaned up with custom voltages, tweaks & many more!
    • You can find custom kernels here
    • Kernel source
    Dettagli Rom:
    • Fully optimized and tweaked
    • ROOT (SU + SuperUser Permissions - Thanks to ChainsDD)
    • Unsecured boot.img
    • Newest BusyBox
    • RAM optimizations
    • Improved Andreno200 configuration for better quality and performance!
    • Speed optimizations
    • Enabled GPU UI rendering
    • SD Card speed tweak
    • Data partition special speed tweak
    • Battery auto-calibration script (Thanks to seo)
    • Bloatware applications removed (Amazon MP3, SoundHound trial, etc.)
    • All system applications updated to latest available
    • Improved camera performance
    • Advanced Power Menu and CRT Animation as extra add-ons
    • Zipaligned (Improved RAM management)
    • Zipalign on boot (for user applications on data partition)
    • Fully de-odexed
    • init.d scripts (BusyBox run-parts) support
    • sysro/sysrw commands support
    • Excellent battery life!
    • Improved EXT4 performance by changing mounting method
    • SD card EXT4 partition support
    • 4EXT Recovery (Thanks to madmaxx82)
    • You can replace HTC boot animation with any custom boot animation
    • Support almost 24h a day
    • ...and many more!
    codice:
    Android Revolution HD 3.6.11 --- release date:31 December 2011 ---
    New faux's123 kernel 0.2.8.3
    • Fixed SuperUser
    • Maxthon updated
    • Restored stable version of Daemon Controller
    • Other minor changes and fixes
    Android Revolution HD 3.6.10 --- release date:29 December 2011 ---
    Kernel updated to latest 0.2.8.2 by faux123
    • OC Daemon binary updated for better dual-core support (Thanks to rmk40)
    • Maxthon updated to latest 2.4.1
    • Adobe Reader updated to latest 10.1.1
    • BDI read_ahead_kb changed from 1024KB to 512KB
    • SuperUser binary updated to latest 3.0.3.2
    • ES File Explorer updated to latest 1.6.1.0
    Android Revolution HD 3.6.9 --- release date: 17 December 2011 ---
    Kernel updated to latest 0.2.7.1
    • 4EXT Recovery updated to latest 1.0.0.2 RC1
    • Android Market updated to latest 3.4.4
    • Twitter updated to latest 3.0.0 and moved to data/app
    • Daemon Controller upated to latest 3.5 beta 2
    • Adobe Flash Player updated to latest 11.1.112.60
    • Zip-aligned using newest SDK r16
    • Maxthon updated to latest 2.3.9
    • Google Maps updated to latest 6.0.3
    • Facebook updated to latest 1.8.1
    Android Revolution HD 3.6.8 --- release date: December 2011 ---
    New kernel from faux123 0.2.6. Details below: - PM / Sleep: fixed coding derp from "Drop pm_op() and pm_noirq_op()" - mfd: timpani-codec: Handle register write for numbers more than cached one - mfd: timpani-codec: Write register defaults when disabling devices - msm_fb: Remove Audio Packet Control Register setup - mfd: timpani: Retry upon I2C failure. - msm_fb: Check for ACP and ACFG register before reset core. - msm_serial: add PM_RUNTIME code from CAF - mm: retry page fault when blocking on disk transfer - msm: kgsl: Do not allow SLUMBER from INIT - PM / Sleep: Drop pm_op() and pm_noirq_op() - PM / Sleep: Unify diagnostic messages from device suspend/resume - sched/rt: code cleanup, remove a redundant function call - ARM: Add optimised swahb32() byteswap helper for v6 and above - hugetlb: Replace BUG() with BUILD_BUG() for dummy definitions. - kernel.h: Add BUILD_BUG() macro. - msm: kgsl: New low power level - msm: vidc: print message as kernel info instead of error - camera:gemini: update gemini engine from hTc Ruby - battery: battery driver and charging driver update - mm: Android Ashmem update from hTc Ruby - misc: android pmem update from hTc Ruby source code - mfd: marimba core update from hTc Ruby - board: ARM kernel update from Ruby source code - cpufreq: add two-phase to ondemand and intellidemand
    • Improved 3D performance
    • SuperUser updated to latest 3.0.7
    • Increased sleep_min from 192 MHz to 384 MHz to prevent from reboots in some cases
    • Market updated to latest 3.3.12
    • YouTube updated to latest 2.3.4
    • ES File Explorer updated to latest 1.6.0.8
    • Maxthon updated to latest 2.3.6 with many improvements!
    • Google Maps updated to latest 6.0.0
    Android Revolution HD 3.6.7 --- release date: 14 November 2011 ---
    New kernel 0.2.5.2 by faux123
    • Private beta for Android Revolution HD users. Source will be out with final version
    • Faster enabling CPU1
    • Add HTC off-alarm support from XE source
    • Updated sii9234 tpi driver from XE source
    • Misc code updates from XE source
    • Enable Android USB gadget projector support
    • Added thermal trip critical retry from XE source
    • Updated DMA engine from XE source
    • Fixed HTC battery driver coding derp
    • Added HTC Beats headset support from XE source
    • Lots of cutting edge technologies not even in latest 3.1 kernel from kernel.org
    • Added DM-Cache
    • New scheduler optimizations
    • ...and many more amazing features!
    • IntelliOndemand governor slightly adjusted for even better performance
    • Tweaked ondemand governor for better performance
    • Increased sleep_max from 384 MHz to 486 MHz to prevent from reboots in some cases
    • Tweaked thermal configuration file for lower temps while stress
    • Adobe Flash Player updated to latest 11.1.102.59
    • Google Maps updated to latest 5.12.0
    >>> Super Wipe <<<
    Full wipe da flashare prima della rom
    TUTTI GLI EXTRAS LI TROVATE QUI
    Ultima modifica di jog21; 02-01-12 alle 21:45
    Apr 2011
    Udine
    Versione temata "NO SENSE"
    Removed:
    • Rosie launcher
    • HTC Themes
    • HTC Widgets
    • HTC Lock-Screen
    • Most of the HTC Sense UI components like Stock, HTC Likes etc.
    Kept:
    • HTC Dialer - still better then Android stock one
    • HTC Contacts
    • HTC Live Wallpapers
    • Facebook for HTC Sense
    • HTC Navigation
    • Genie Widget
    • + Go Launcher EX
    Come installare:
    • Scaricare Android Revolution HD ROM al primo post
    • Scaricare Android Revolution HD no-sense script
    • Mettere i due fils nella SD e riavviare in recovery
    • Flashare full wipe.zip
    • Flashare la rom senza riavviare
    • Flashare Revolution HD no-sense script
    • Riavviare
    Ultima modifica di skanky80; 05-09-11 alle 19:42
    Ready for HTC M8....
    Apr 2011
    Udine
    Spiegazione sul Deamon: cos'è, a cosa serve come si usa - si modifica.
    Quanto segue è stato scritto dal Super Moderator memnoch quindi meriti e ringraziamenti vanno a lui.
    Tutorial per il daemon
    Il daemon è un programma "fantasma" che riesce a rimanere in background completamente invisibile al sistema. I processi detti "daemons" (in italiano "demoni") creano dei cloni di se stessi. Questi cloni vengono killati dal sistema per ragioni di ottimizzazione RAM. Quando questo avviene, il sistema viene "ingannato" perchè crede di aver eliminato un processo in background (clone del daemon) che invece è ancora presente e funzionante. L'uso di questa tattica nei sistemi linux è molto diffusa. Grazie ad essa, si ottiene dai processi la massima efficenza a costo 0 per la RAM. Ecco perchè il daemon funzionerà sempre meglio di qualsiasi app per la gestione della cpu.
    Il daemon è studiato per avere un comportamento ben preciso. Infatti adotta due profili diversi a seconda che il device sia a "riposo" (sleep mode) o sia in "attività" (wake mode). se il device è spento, il daemon si modifica, e gestisce le frequenze attraverso un governor detto "conservative" che tende alle frequenze più basse possibili. Se invece il device è attivo, il daemon gestisce le frequenze col governor detto "ondemand", che ha come caratteristica il rilascio di potenza direttamente proporzionale alla richiesta del sistema. Detto questo, è sconsigliabile cambiare sia l'uno che l'altro governor. Infatti il daemon, per sua stessa natura, si comporta già in maniera molto aggressiva. Per aggressività, si intende il numero di step (a livello di frequenze) che il daemon utilizza nella gestione della cpu. Per fare un esempio:
    Il governor smartass fà 4 steps di frequenze (minima,media,medio-alta,massima). Poche se pensiamo a quelle disponibili.
    Il governor ondemand fà 8 steps di frequenze (minima, minima-media, media,medio-alta,medio alta1,medio-alta2,alta,massima). Molte, anche pensando a quelle disponibili.
    Ovviamente questo era solo un esempio ma rende l'idea. Ecco perchè il daemon, che ha come "stile" proprio lo smartass, và gestito da un governor che non nè accentui l'aggressività, ma con uno "neutro" che segua le richieste del daemon senza interferenze. On demand è il migliore. Non ci sono dubbi.
    il daemon è supportato dalla rom. Quindi non ha niente a che vedere con il kernel. Potete installare qualsiasi kernel e usare sempre il daemon. A patto che però si conoscano esattamente le frequenze che il kernel che vogliamo installare utilizza. E' infatti chiaro come ogni kernel abbia una sua propria tavola ACPU con frequenze differenti a seconda di come è stato compilato e di quali sono i suoi sorgenti.
    OPERARE SUL DAEMON
    da PC
    Potete modificare il daemon PRIMA del flash della rom.
    Aprite (senza scompattare) lo zip della rom
    navigate in system\etc\virtuous_oc
    modificate i 6 files servendovi del "Blocco Note" (installato di default in qualsiasi os)
    chiudete tutto (date conferma di aggiornare l'archivio dello zip se vi viene chiesto)
    flashate la rom
    Se avete GIA' FLASHATO LA rom.
    In questo caso potete usare Qtadb o pushare i files MODIFICATI tramite adb col comando adb push (per utenti esperti)
    in entrambi i casi, la procedura è sempre la stessa.
    modificate i files e rimetteteli al loro posto.
    Riavviate il dhd e siete ok.
    da terminale
    GUI per daemon
    Si tratta di un user interface creata per gestire il daemon. E' diversa da Set CPU, anche se non lo sembra. In pratica non conta come applicazione e non pesa sul sistema. Installatela con Astro File Manager. Una volta installata, settate i valori (consiglio quelli "recommended", al massimo alzate il valore Sleep max a 460800MHz..non andate oltre perchè non ci sono miglioramenti. Una volta fatto schiacciate "apply" e i valori verranno settati. Non c'è bisogno di riavviare.
    Link al download dell'app se non fosse presente nella ROM.
    Senior Droid L'avatar di jog21
    HTC Sensation
    Ringraziato 64 volte in 55 Posts
    Ho flashato la ROM dopo il super wipe, ma il wi-fi mi da errore. Controllando nelle impostazioni l'indirizzo mac non c'è nemmeno. Qualcuno sa aiutarmi?
    Apr 2011
    Udine
    Quote Originariamente inviato da jog21 Visualizza il messaggio
    Probabilmente qualcosa è andato storto nel flash della rom..io riproverei a flasharla sempre dopo il super wipe..ma se aspetti 5 minuti uppo l'ultima versione 3.5.0 XE
    Edit: Niente mi ci vuole troppo per upparla ed ora non ho tempo lo farò stasera...prova a scaricarla da qui se vuoi..ancora non l'ho provata ma sembra promettente. Se dovessi avere ancora problemi col wifi o di qualunque genere ti consiglio un erase approfondito segui la prima guida in firma.
    Ultima modifica di skanky80; 15-09-11 alle 16:41
    HTC Sensation
    Niente da fare, anche la 3.5 mi segna errore in wi-fi e relativo hotspot.
    Anche la leedroid e la pyramid3d mi danno questo problema.
    Ho fatto dapprima il wipe data poi il wipe cache, successivamente ho formattato data system partizioni e via dicendo, ho fatto wipe della dalvik e ho fatto partire il super wipe della revo.
    L'ho installata e non si accende l'antenna.
    Dimmi che non devo flashare la radio che mi viene un colpo al cuore.
    Apr 2011
    Udine
    Che versione di radio hai? Non te lo so dire con certezza se il problema sia quello..però è probabile che sia così, specialmente se hai una versione di radio datata. In ogni caso se guardi qui ed esegui esattamente la guida non dovresti avere problemi.
  9. Il seguente Utente ha ringraziato skanky80 per il post:
    jog21 (15-09-11)
  10. #8
    HTC Sensation
    Io di radio non so nulla su c'è quella stock
    A cosa serve aggiornare la radio? E perchè si può brickare?
    Ultima cosa, quale mi consigli?
    Grazie in anticipo
    Ultima modifica di jog21; 15-09-11 alle 21:14
  11. #9
    Apr 2011
    Udine
    Grazie in anticipo
    La radio gestisce tutto quello che riguarda le varie connessioni: umts, gsm, wifi, gps, ecc. è comunque una parte del software che si può cambiare all'occorrenza se come nel tuo caso si hanno dei problemi. La guida ti spiega chiaramente come fare..il rischio di brik è minimo se l'md5 del file PG58IMG risulta esatto. A volte ci possono essere incompatibilità tra rom e radio come nel tuo caso per questo bisogna aggiornarla. Io ti posso dire che l'ho fatto molte volte seguendo le guide sia col dhd che col sensation e non mi è mai successo nulla. Credo che tu non abbia alternative in ogni caso se lasci la revo 3.5.0 monta la 10.58.9035.00U_10.15.9035.02_2
  12. #10
    Provata oggi la 3.5.1 con funzionalità XE...
    Sempre molto valida!
    Anche la radio è stata aggiornata...
    Inviato dal mio HTC Sensation Z710e usando Androidiani App
    R.I.P. la Lingua Italiana, prematuramente scomparsa.
LinkBacks (?)
