Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 33
[ROM] Android Revolution HD™| 4.1.9 |Sense 3.5
    Androidiano VIP L'avatar di skanky80
    Apr 2011
    Udine
    Ringraziato 205 volte in 182 Posts
    Exclamation
    Ed ecco a voi la nuova
    Android Revolution HD with Sense 3.5
    del nostro Mike1986
    Nuova base (sperimentale) 2.08.401.1 non XE
    Link al thread ufficiale della rom su XDA
    Importante: se si passa da una rom Sense 3.0 ad una Sense 3.5 è importante fare un wipe approfondito del terminale...vedere thread in rilievo...
    Parlando di Android Revolution HD
    Dettagli sistema:
    • Android 2.3.5 (Gingerbread) - latest HTC RUU 2.08.401.1
    • This is improved version of stock ROM - no visual changes!
    • Very fast, clean & stable!
    • Full HTC Sense 3.5 Interface
    • Multi-language (WWE)
    • Arabic and Hebrew languages full support! (see the second post)
    • HTC Sensation 4G (US T-Mobile) support with Wi-Fi Calling
    • For HTC Sensation, HTC Sensation 4G & HTC Sensation XE
    Dettagli kernel onboard:
    • New kernel: 2.6.35.14 (under-volted & tweaked)
    • CPU up to 1.56 GHz (1.51 GHz by default - original speed for MSN8660 chipset) - controlled automatically by built it O/C Daemon. How to use O/C Daemon?
    • If you want to control CPU manually, you would need SetCPU from here: SetCPU
    • In SetCPU remember to check "Set on Boot", but using O/C Daemon gives much better performance and battery then SetCPU
    • Many CPU governors (SmartAss, Ondemand, Performance, Conservative, UserSpace)
    • GPU+ patch (Improved 2D & 3D Graphics performance
    • 3D Engine overclocked from 266.6 MHz to 320 MHz
    • L2 Cache Bandwidth Boost from 310MHz to 360MHz
    • Synchronous L2 Cache
    • V(R) I/O as default scheduler
    • SLQB Memory Management
    • CIFS, TUN & UTF8 support
    • LZMA compression
    • Wi-Fi module improved drivers
    • Code cleaned up with custom voltages, tweaks & many more!
    • You can find custom kernels here
    • Kernel source
    Dettagli rom:
    • ROOT (SU + SuperUser Permissions - Thanks to ChainsDD)
    • Fully optimized and tweaked
    • Unsecured boot.img
    • Newest BusyBox
    • RAM optimizations
    • Improved Andreno200 configuration for better quality and performance!
    • Speed optimizations
    • Enabled GPU UI rendering
    • SD Card speed tweak
    • Data partition special speed tweak
    • Battery auto-calibration script (Thanks to seo)
    • Bloatware applications removed (Amazon MP3, SoundHound trial, etc.)
    • All system applications updated to latest available
    • Improved camera performance
    • Advanced Power Menu and CRT Animation as extra add-ons
    • Zipaligned (Improved RAM management)
    • Zipalign on boot (for user applications on data partition)
    • Fully de-odexed
    • init.d scripts (BusyBox run-parts) support
    • sysro/sysrw commands support
    • Excellent battery life!
    • Improved EXT4 performance by changing mounting method
    • SD card EXT4 partition support
    • You can replace HTC boot animation with any custom boot animation
    • Support almost 24h a day
    • ...and many more!
    codice:
    Android Revolution HD 4.1.9 --- release date: 17 December 2011 ---
    • Kernel updated to latest 0.2.7.1
    • 4EXT Recovery updated to latest 1.0.0.2 RC1
    • Android Market updated to latest 3.4.4
    • Twitter updated to latest 3.0.0 and moved to data/app
    • Daemon Controller upated to latest 3.5 beta 2
    • Adobe Flash Player updated to latest 11.1.112.60
    • Zip-aligned using newest SDK r16
    • Maxthon updated to latest 2.3.9
    • Google Maps updated to latest 6.0.3
    • Facebook updated to latest 1.8.1
    • Other minor changes and fixes
    Android Revolution HD 4.1.8 --- release date: 5 December 2011 ---
    • New kernel from faux123 0.2.6
    • Improved 3D performance
    • SuperUser updated to latest 3.0.7
    • Increased sleep_min from 192 MHz to 384 MHz to prevent from reboots in some cases
    • Market updated to latest 3.3.12
    • YouTube updated to latest 2.3.4
    • ES File Explorer updated to latest 1.6.0.8
    • Maxthon updated to latest 2.3.6 with many improvements!
    • Google Maps updated to latest 6.0.0
    Android Revolution HD 4.1.7 --- release date: November 2011 ---
    • New kernel 0.2.5.2 by faux123
    • Private beta for Android Revolution HD users. Source will be out with final version
    • Faster enabling CPU1
    • Add HTC off-alarm support from XE source
    • Updated sii9234 tpi driver from XE source
    • Misc code updates from XE source
    • Enable Android USB gadget projector support
    • Added thermal trip critical retry from XE source
    • Updated DMA engine from XE source
    • Fixed HTC battery driver coding derp
    • Added HTC Beats headset support from XE source
    • Lots of cutting edge technologies not even in latest 3.1 kernel from kernel.org
    • Added DM-Cache
    • New scheduler optimizations
    • ...and many more amazing features!
    • IntelliOndemand governor slightly adjusted for even better performance
    • Tweaked ondemand governor for better performance
    • Increased sleep_max from 384 MHz to 486 MHz to prevent from reboots in some cases
    • Tweaked thermal configuration file for lower temps while stress
    • Adobe Flash Player updated to latest 11.1.102.59
    • Google Maps updated to latest 5.12.0
    Android Revolution HD 4.1.6 --- release date: 5 November 2011 ---
    • Kernel updated to 0.2.3r3 by faux123
    • Fixed battery drain issue for some users
    • Market updated to latest 3.3.11
    • Maxthon updated to latest 2.3.4
    - You can download custom kernels from here - Remember to remove SetCPU or any other CPU tuner in order to have O/C Daemon working - Read this post to learn about O/C Daemon - No need to use Super Wipe if you have 4.1.x already!
    Android Revolution HD 4.1.5 --- release date: 28 October 2011 ---
    • New kernel 0.2.3.16 by faux123
    • Included first time kernel package from faux123 - please don't flash it!
    • Updated OC Daemon engine for better dual-core support - better performance Thanks to madmaxx82
    • sleep profile set to conservative for OC Daemon - better battery
    • Superuser updated to latest 3.0.6
    • su binary updated to latest 3.0.3
    • If you have FC on any app that requires root then clear data from Superuser in settings
    • Maxthon updated to latest version
    • More HTC spying stuff removed
    • Zipaligned using newest SDK v.15
    MD5: 928582DDFEE44CAC9A12E038698B03C5
    >>> Super Wipe <<<
    Ultima modifica di jog21; 24-12-11 alle 19:01
    Apr 2011
    Udine
    Riservato...01
    Ready for HTC M8....
    Apr 2011
    Udine
    Riservato...02
    Ci sono novità o si riavvia sempre con la radio consigliata???
    Apr 2011
    Udine
    Quote Originariamente inviato da KernelPanic Visualizza il messaggio
    Credo che i problemi siano rimasti perché Mike ha cambiato la radio consigliata mettendo l'ultima disponibile cioè quella che ho io in firma.
    Inviato dal mio HTC Sensation Z710e usando Tapatalk
    Quote Originariamente inviato da skanky80 Visualizza il messaggio
    Bene...! Aspetteremo!
    Tu la usi già? Ti trovi bene?!?!?!
    Apr 2011
    Udine
    No a me la sense 3.5 non è che piaccia più di tanto onestamente..ma è solo un'opinione personale..poi queste sono tutte relase sperimentali io disolito aspetto basi più stabili.
  9. #8
    May 2009
    io l'ho installata ieri ma non mi funziona la chat di facebook e inoltre friendstream permette solo di registrare account flirk o twitter... come mai?
    un ultima cosa io come radio ho sempre quella base... sono un pò arrugginito con ADB perchè col vecchio desire mi ha troppo viziato col semplice flash dello zip per la sostituzione... per il sensation non c'è una medesima soluzione?
    Ultima modifica di Toller; 29-09-11 alle 22:51
  10. #9
    Apr 2011
    Udine
    Quote Originariamente inviato da Toller Visualizza il messaggio
    È normale che all'inizio dello sviluppo ci sia qualche bug..verranno sistemati col tempo.
    Per la radio dai un'occhiata ai thread in rilievo.
    Ultima modifica di skanky80; 30-09-11 alle 10:15
  11. #10
    Ho dei problemi con il market sia di questa ROM (4.1.0), sia dell'altra (3.6.1). In pratica dopo aver avviato il telefono ed aver impostato l'account google. Il cellulare inizia il download delle app che avevo sul precedente SO. Fin qui tutto ok, ma molte non c'è verso di farle installare. Ad un certo punto inizia a darmi errore per ogni app dicendo che non ho più spazio sul telefono. Come mi comporto?
    Ultima modifica di ema0185; 02-10-11 alle 13:15
