Sul wildfire s è possibile portare i mghz a più di 600 con no frills cpu?? se sì come?? e cosa cambia da Governor: userspace, ondemand, perfomance e da I/O scheduler: noop deadline cfq??
se hai ancora la cyano installata non ne hai bisogno perchè c'è il menu cyanogenmod nel quale trovi la sezione sistema da dove poter overclockare il tel... ti conviene mettere performance cmq...
No, non ho la Cyano ma la ROM originale...
Inviato dal mio HTC Wildfire S A510e usando Androidiani App
Performance? Così la cpu starà sempre al max, no no no....
7. CPU Scaling Governors
CPU governors control exactly how the CPU scales between your “max” and “min” set frequencies. Most kernels have “ondemand” and “performance.” The availability
ondemand – Available in most kernels, and the default governor in most kernels. When the CPU load reaches a certain point (see “up threshold” in Advanced Settings), ondemand will rapidly scale the CPU up to meet demand, then gradually scale the CPU down when it isn't needed.
interactive – Available in newer kernels, and becoming the default scaling option in some official Android kernels. The interactive governor is functionally similar to the ondemand governor with an even greater focus on responsiveness.
conservative – Available in some kernels. It is similar to the ondemand governor, but will scale the CPU up more gradually to better fit demand. Conservative provides a less responsive experience than ondemand, but can save battery.
performance – Available in most kernels. It will keep the CPU running at the “max” set value at all times. This is a bit more efficient than simply setting “max” and “min” to the same value and using ondemand because the system will not waste resources scanning for CPU load.
powersave – Available in some kernels. It will keep the CPU running at the “min” set value at all times.
userspace – A method for controlling the CPU speed that isn't currently used by SetCPU. For best results, do not use the userspace governor.
smartass – Included in some custom kernels. The smartass governor effectively gives the phone an automatic Screen Off profile, keeping speeds at a minimum when the phone is idle.
SetCPU for Root Users
Tu che impostazioni mi consigli?
Io uso smartassv2 (o il primo), non mi da problemi e il cambio di clock è volece.
Con ondemand invece se passavo dallo standby allo sblocco si vedeva che doveva ancora ingranare la marcia.
Gli altri li ho scartati a priori.
