[ROM] WildPuzzleROM_2.1 Eclair v1.0.1 con HTC sense
WildPuzzleR.1 Eclair v1.0.1 con HTC sense
Features:
1. Based on: WWE_1.37.405.1 (Android Eclair/2.1 HTC Sense)
2. Overclocked (flash standard kernel 0050 if your system doesent boot, a few user have problem with overclocked kernel)
3. JIT (flash 0991 to activate or 0990 to deactivate)
4. System read/write access (flash 0151 to activate it, or 0150 to deactivate)
5. Trackpad to wake (and powerbutton)
6. 3in1 reboot menu
7. Wifi-N support
8. Proxy support
9. Tweaked
10. Deodexed
11. Rooted
12. Busybox
13. Nano
14. Shell
15. Apps2sd (requires an ext partition)
16. Host file to block ads
17. Java (Jbed)
18. No boot sound
19. Custom bootanimation
20. And alot more...
Downloads:
0001_*.zip base rom, this is the only file you need to flash if you dont need to change the basic rom
0001_WildPuzzleROM_2.1_v1.0.1
http://rom.tat.tw/wildfire/wildpuzzl...2.1_v1.0.1.zip
Provatela vi assiucuro che č la migliore per ora :)
Guida: basta solo flashare il file 0001, perņ prima fate il backup e dopo fate un wipe completo :D
Ne io ne questo forum (nessuno) non ci assumiamo eventuali danni recati al vostro apparecchio.
Non dovreste avere nessun problema se seguite la mia guida.
Per eventuali problemi contattatemi.
Fonte:XDA forum.
