Problemi dopo avere installato una rom
Ho usato alpharevx per s-off ok
Usato il metodo xda per la rootazione ed ok
Installato rom manager ok
Fatto backup con recovery ok
Durante installazione joker-rom crack. il cell cade e stacca batteria :-(
Sono rovinato. Come ripristino ?
In Recoveri mi dice md5 mancante
se provo a reinstallare Joker mi dice :
Installing update ...
Amend scripting (update-script) is no longer supported.
Amend scripting was deprecated by google in android 1.5.
It was necessary to remove it when upgrading to the clockwork 2.0 gingerbread based recovery.
Pleasy switch to edify scripting 8UPDATER-SCRIPT AND UPDATE BINARY) to create working update zip packages.
Install aborted
Help me please. :'(
