[Huawei Ascend G700]Themes for TWRP 2.5.0.0
Here are 4 Themes for Twrp
Holo Light
https://drive.google.com/file/d/0B-b...p=docslist_api
Holo Dark
Miui Style
Lewa Style
Extract the Zip and in the zip is an ui.zip
Create in your TWRP Folder under BACKUPS a folder Theme.
It may only be the ui.zip in the Theme folder that is desired.
After you copy the ui.zip in Theme Folder you Reboot Recovery and Theme create.
Source from 4pda Gravilla
