[Huawei Ideos X5][ROM] Ported dal Desire S [basata su cyanogenmod 10]
		si dice sia un'ottima rom:
Features
•Based on the Latest CM sources(ported from DesireS)
•Used October Shendu Kernel with OC upto 1.8Ghz(Found it best for gaming)
•Unlocked FPS
•zipaligned Apks
•KickAssKernel and V6 script
•Seeder 2.0.0
•Pretty Ass Smooth!
•Every other Features from CM10.0
Stock
Download: https://www.dropbox.com/s/45qxead1y5...o_rik_v1.0.zip
version 1-By Me
•Initial Release
uscita nuova versione 1.0.1:
https://www.dropbox.com/s/6vgif83t7d...ial_v1.0.1.zip
changelog:
version 1.0.1-By PrakharKumar
•LED bug removed
•CM10 Dialer
•Fixed camera (now using ShenDu camera)
•Backlight bug removed
•New Shendu Kernel(updated december)
•Most other previous Release Bugs are removed.
versione 2.0
http://d-h.st/bT0
changelog:
Version 2.0-By PrakharKumar
•latest ShenDu kernel (28/02/2013).. still 3.0.8(ICS) instead of 3.0.31(JB)
•4.2 camera (ofcourse, without photosphere)
•fixed root (to be on the safer side, ShenDu Permission, Superuser & SuperSU, all three are there)
•removed useless/duplicate/double apps (reduced the ROM's size quite a bit)
Versione 3.0 by Herna (feat cuvetto e rittik)
http://d-h.st/O1g
Changelog
Version 3.0
•Latest Shendu Kernel
•Camera Autofocus Totally fixed
•Some 3rd party Camera fixed(partially) •Sound/noice fixed from speaker
•Wifi tethering and hotspots Fixed.
•RAM Management Partially fixed(Should be better than earlier releases)
link su xda: [ROM]CyanogenMod 10 {Unofficial} Initial Release - xda-developers
PS come bug la v3 ha il vivavoce. Bug che comunque a detta di rittik e altri su xda sono stati risolti e che verrà rilasciato un bug fix sotto forma di zip
		R: Nuova rom basata su cyanogenmod 10 ported dal desire s
		Quindi chi usa il Wi–fi è inutile metterla...  Grazie per la dritta...
Inviato dal mio U8800Pro con Tapatalk 2
		Installata la versione 2 sul cellulare ed è una bomba ;–)
		L'unico problema è la tastiera che autocrasha ma basta installare la SwiftKey e si risolve tutto...
