Pagina 1 di 15 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 143
[LG G2][KERNEL][LINARO] Modded stock kernel - d802 [G2 + G3 ROMs]
    Androidiano VIP L'avatar di Pilone92
    Venezia
    SAMSUNG S+ - LG G2 - ONEPLUS 5
    Ringraziato 514 volte in 421 Posts
    Cool
    Modded Stock kernel - d802
    thread originale XDA
    Basato sul kernel stock di lg G2
    Sviluppato con Linaro 4.8 stable toolchain
    Ottimizzato con -O3 compiler flags
    Varie altre ottimizzazioni per renderlo veloce e stabile
    Aggiornati GPU drivers dal Code Aurora
    Aggiornati CPU drivers dal Code Aurora
    3 fasi thermal control
    rgb screen colour adjustment
    faux sound control
    CPU voltage control
    Compatibile con G3 ROM (testata su Cloudyfa e Optimus)
    Questo kernel è di base stock e lo sviluppatore non inserirà ulteriori governor o la possibilità di OC
    INSTALLAZIONE
    Andare in recovery (testata su TWRP 2.7)
    install
    flash del kernel
    wipe cache e dalvik
    reboot
    enjoy
    DOWNLOAD
    http://www.androidfilehost.com/?w=files&flid=14686
    NON SONO RESPONSABILE DI ALCUN DANNO
    buon modding
    Changelog:
    codice:
    26-4
    Compile kernel with linaro using -o3 compiler flags
    Added support for CyanogenMod DSP Manager (this broke LG's audio effects)
    Added DSP Manager apk and supporting files
    27-4
    Merged in the latest changes from LG kernel source
    This includes Knock Code and LG's audio fix
    Fixed support for both DSP and LG's audio effects
    29-4
    Just a rebuild after cleaning up source and commiting to github
    30-4
    SCHEDULER: Autogroup patch
    lib/memcopy: use glibc version
    lib/string: use glibc version
    Optimized ARM RWSEM algorithm
    jbd2: Fix use after free after error in jbd2_journal_dirty_metadata()
    msm: Fix high load average from uninterruptible waits
    vfp - compile with neon
    vfp: hardfloat
    vfp: since we use hardfloat, change the modifer accordingly
    Update Makefile cflags for unaligned-access and unroll-loops
    defconfig: remove a lot of debugging, stats, logs and tests
    03-5
    Switched toolchain to linaro 4.8
    Updated kgsl from CAF
    04-5
    Readded KnockCode to kernel and ramdisk
    Only compatible with Roms based on D80220D (may work with others, not tested)
    16-6
    n_tty: Fix n_tty_write crash when echoing in raw mode
    futex-prevent-requeue-pi-on-same-futex.patch
    futex: Validate atomic acquisition in futex_lock_pi_atomic()
    futex: Always cleanup owner tid in unlock_pi
    futex: Make lookup_pi_state more robust
    25-6
    arm: Add option to skip buffer zeroing
    ion: Skip zeroing on secure buffers
    30 commits to kgsl (GPU driver)
    Upgrade gpu ion from caf
    Update cpufreq from caf (CPU driver)
    Remove SECUREBOOT from ramdisk (fixes boot on G3 port)
    v0.2
    Added 3 phase thermal control
    Get rid of __cpuinit calls from whole kernel
    Fix storage settings on G3 port
    Fix user adjustable rgb in kcal
    v0.3
    Added faux sound control
    Added CPU voltage control
    RINGRAZIAMENTI
    bruce2728 sviluppatore del kernel e utente XDA
    Ultima modifica di Pilone92; 07-07-14 alle 13:50
  2. I seguenti 3 Utenti hanno ringraziato Pilone92 per il post:
    DiNG0 (07-07-14),iSTE983 (04-08-14),ldoublel (18-02-15)
    Venezia
    Ecco un utente xda con questo kernel e cloudy g3
    Non chiedetemi come ha fatto..
    http://forum.xda-developers.com/show...php?p=53744107
    SCREENSHOTS BATTERIA
    Ultima modifica di Pilone92; 08-07-14 alle 20:02
    Venezia
    Test di oggi luminosità auto 100%
    Fb whatsapp viber gmail in push
    Tutto attivo a parte google now
    Clash of clan 15min
    Rom optimusG3 1.1
    Il sistema risulta molto fluido e veloce e la batteria è una bomba:thumbup:
    Androidiano VIP L'avatar di DiNG0
    Feb 2014
    Far from any road
    Ringraziato 487 volte in 442 Posts
    Lo provo su CloudyG3 e riporto le mie impressioni.
    Grazie per la segnalazione.
    Ser bueno no es sinónimo de ser idiota. Ser bueno es una virtud que algunos idiotas no entienden.
    si vis pacem para bellum si vis pottam para augellum
  7. #5
    Dec 2009
    Ringraziato 33 volte in 24 Posts
    Installato su stock 20f, sembra comportarsi meglio di dorimanx per quanto riguarda la batteria ma attendo qualche giorno per confermare.
  8. #6
    Ciao ragazzi, chi ha già installato questo kernel da un po mi/ci può dire come si comporta? Ovviamente punto saliente la batteria.... Io uso il dorimanx con optimus g3
  9. #7
    Venezia
    Questo kernel secondo me è ottimo lo tengo da due giorni faccio tranquillo 6 ore di schermo. Come vedi in alto sono arrivato a 7 ore con uso intenso e il bello è che non serve modificare nulla non c'è nessuna configurazione da sistemare come il dorinmax e il sistema è fluido. Ho trovato un po lenta la chiusura della fotocamera e il switch tra camera anteriore e posteriore.
    Edit: ho inserite nel secondo post alcuni screenshot della batteria con rom optimus g3 e kernel v0.3 di bruce!
    Ultima modifica di Pilone92; 08-07-14 alle 20:03
  10. Il seguente Utente ha ringraziato Pilone92 per il post:
    quacchino (08-07-14)
  11. #8
    Senior Droid L'avatar di Giulio19799
    Ringraziato 33 volte in 29 Posts
    Quote Originariamente inviato da Pilone92 Visualizza il messaggio
    Lo consigli quindi sulla Cloudy 1.2 no?
    Volendo poi il kernel di quest'ultima si trova?
  12. #9
    Venezia
    Quote Originariamente inviato da Giulio19799 Visualizza il messaggio
    Si lo consiglio ma l'ho provato solo su optimus. Comunque per sicurezza fai un nandroid backup. Non so se è reperibile in qualche modo il kernel cloudyfa. Anche oggi penso di fare 7 ore di schermo
    Ok grazie.
    Al link che hai postato ci sono tre kernel,quale dovrei prendere?
