Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 11
[BUMPED][ROM][D855] Candy5 - Official [5.0.1]
    Androidiano L'avatar di zichichi
    Nov 2010
    Villarosa (EN)
    LG G3 16GB
    Ringraziato 39 volte in 34 Posts
    Ne lo scrivente ne Androidiani sono responsabili di eventuali (quanto improbabili) danni al terminale
    Features
    *Candy Interface
    *Navi Bar Height...Candy Interface
    *Battery Percent ...Candy Interface / Status Bar
    *Recents Panel Options ...Candy Interface/Recents Panel
    *Clock and Date Options...Candy Interface/Clock and Date
    *Wake Options ...Display
    * Rotation 360 degrees...Display
    *Custom Notification Lights...Sounds&Notifications
    *Lockscreen Notifications Per App...Sounds&Notifications/App notifications
    *IME options from 4.4+ ...Language and input/advanced options
    *Disable Ime selector (thanks cm)
    * Visual improvements
    *ALL of Cm's Latest Feature Additions
    DOWNLOAD V.0.8.3
    GAPPS
    SUPERSU
    LINK XDA
    7
    CHANGELOG:
    0.8.3 - 18/12/2014
    *Reverted Dpi Changer...conflicts with built in su. Will bring it back when bug is resolved
    *Added Custom HeadsUp options [thanks Slim]...Sound & notification
    *Added PullDown header weather option...Candy Interface/Statusbar
    *Added Lock screen Gestures security...Security/Screen lock
    *Added Volume music controls...Candy Interface
    *Tons of C5 under the hood improvements
    *Added ALL Cm's new features (quite a few)
    *TONS of Cm fixes and maintenance
    *Added "Buttons Options" back (just power and home)
    0.8.2 - 12/12/2014
    Added Dpi Changer...Candy Interface
    Added Option to remove Carrier logo on lock screen
    Fixed Wake on Plug /Unplug
    Fixed/Moved Network Indicator to the left
    Rearranged some Settings menu's to Candy specifications
    Added some [N6] L UIsounds
    Many Device Specific Improvements
    Ultima modifica di zichichi; 24-12-14 alle 08:34
  2. I seguenti 2 Utenti hanno ringraziato zichichi per il post:
    DreamReaper (13-12-14),ECLAIR (14-12-14)
    Senior Droid L'avatar di ECLAIR
    Nov 2014
    Trapani, Sicilia
    Lg G3
    Ringraziato 233 volte in 187 Posts
    Provo per dare le prime impressioni
    Inviato dal mio LG-D855 con CM12
  5. #3
    torino BIANCONERA
    NEXUS 6P
    Ringraziato 499 volte in 419 Posts
    Quote Originariamente inviato da LG3D855 Visualizza il messaggio
    Attendiamo notizie...
    Se fosse possibile ti chiederei una prova della fotocamera...
    Per valutare la differenza dallo stock
    Grazie!
    Smartphone posseduti:
    "iphogne " 3gs
    galaxy s2 - s3 - s4 poi NEXUS 5, lg g3, P9 e finalmente li NEXUS 6P
  6. #4
    Nov 2014
    Trapani, Sicilia
    Lg G3
    Allora, come fluidità è perfetta, mi ha stupito il fatto che fra le impostazioni c'è la possibilità di cambiare i DPI.. Adesso sto utilizzando con 480 DPI gira bene e mantiene circa 800 MB di RAM libera(nel mio g3 con 2Gb) .
    Batteria aspetterei un po per dare maggiori informazioni..
    Vorrei sapere se c'è qualche kernel compatibile perche questo è quasi privo di modificabilità.
    Fotocamera molto molto meglio della CM12, direi quasi paragonabile alla stock, fluida e ottime foto.
  7. Il seguente Utente ha ringraziato ECLAIR per il post:
    bonusax (14-12-14)
  8. #5
    torino BIANCONERA
    NEXUS 6P
    Ma si va... Mentre guardo la partita la metto in download
    "iphogne " 3gs
  9. #6
    Nov 2014
    Trapani, Sicilia
    Lg G3
    Mi sto un pochino ricredendo sulla fotocamera.. Le foto non sono ottimali.. Per il resto gira bene
    Inviato dal mio LG-D855 con Candy ROM 5.0.1
  10. Il seguente Utente ha ringraziato ECLAIR per il post:
    bonusax (14-12-14)
  11. #7
    S22 Ultra,Find X2 pro,Mi 10
    Benissimo, per quanto riguarda il kernel ho qualche dubbio che ci sia qualcosa che va bene. Ma provare non costa niente.
    Ps (ricordate che l'assistenza LG è chiusa fino a Gennaio 2015 )
    Sto Guidando (cit. Dieguccio)
  12. #8
    Nov 2014
    Trapani, Sicilia
    Lg G3
    Ahahahahah avevo fatto qualche prova, e ho crashato un paio di volte il kernel ahahahaha, comunque grazie per la precisazione dream ;')
    Inviato dal mio LG-D855 con resurrection remix ;D
  13. #9
    Nov 2010
    Villarosa (EN)
    LG G3 16GB
    Nuova versione appena uscita
    0.8.3 - 18/12/2014
    *Reverted Dpi Changer...conflicts with built in su. Will bring it back .
    hen bug is resolved
    Uscita 0.9.0RC.
    Ultima modifica di DreamReaper; 24-12-14 alle 15:47
  14. Il seguente Utente ha ringraziato zichichi per il post:
    DreamReaper (24-12-14)
  15. #10
    Quote Originariamente inviato da zichichi Visualizza il messaggio
    0.8.3 - 18/12/2014
    hen bug is resolved
    Uscita 0.9.0RC.
    Ti ringrazio per la notizia.
    Però ti ricordo che sarebbe necessario porre il changelog in Italiano corrente
