Pagina 1 di 9 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 88
[rom] king_3d_rom_v2.2
    Sviluppatore Android
    Apr 2011
    SAMSUNG GALAXY S7 EDGE
    Ringraziato 232 volte in 152 Posts
    13th version of the KING_3D_ROM by KING3Developers.
    • Based on v10k
    • Busybox + Root
    • Updated Superuser
    • Updated bin/su
    • Full deodex apps & Framework
    • Original Kernel
    • New King ICS framework
    • Optimized ram
    • Increased speed of microSD
    • Performance patch
    • Increased speed of system
    • Added ringtones ICS
    • Added bootanimation ICS
    • Added music ICS
    • Added Roboto ICS font
    • Added live wallaper
    • Added 2D-3D Converter
    • Added KING-manager
    • Removed LG Apps
    • Fixed bug of GoSmsPro
    • Android Market 3.1.5
    • GoLauncher 2.61
    • KING-manager 1.0
    KING_3D_ROM v2.2
    KING_3D_ROM v2.2 BETA (more performance but more battery drain)
    To install: Put the patch that you want in your SD, and flash it.
    Original apps patch
    3D games in internal SD
    3D games in external SD
    KING ICS framework
    KING ICS framework + %battery
    Frame KING (the old grafics)
    Original LG framework
    NOTE! You should make a nandroid backup, if something goes wrong, or if you want to restore configuration and apps.
    Installation procedure - Quick guide:
    1) Copy the KING_3D_ROM in your SD.
    2) Reboot in to recovery (ClockworkMod)
    4) Do the 3 wipe (data/factory reset, cache partition, and in advanced, dalvik cache.
    5) Go to Flash zip from sdcard -> Choose zip from sd card and select the KING_3D_ROM and confirm.
    6) When the installation is completed, reboot your system.
    Installation procedure - Detailed guide for newbies (ENG\ITA):
    - Nandroid buckup
    - Install the ROM
    Note! Please not restore the data from recovery mode, it may cause reboots. Restore your apps with programs as MyBackup PRO.
    Ultima modifica di boostermbkking; 29-10-11 alle 14:27
    Samsung Galaxy S8 G950F & Samsung Galaxy S7 G930F
    My Work:
    [5.0+]Sphere Icon Pack
    [5.0+]Ripped Icon Pack
  2. I seguenti 2 Utenti hanno ringraziato boostermbkking per il post:
    maurizioscintu (31-10-11),Pidol (07-11-11)
    Apr 2011
    Preview of new King ICS Framework
    For good effect, you shoud install the GoLauncherEx Ice Cream Sandwitch theme (and apply it in the theme section of GoLauncherEx)
    GoLauncherEx Ice Cream Sandwitch theme - Download
    My Work:
  5. #3
    Apr 2011
    questa mi piace, bravo davvero, la grafica sembra proprio bella, la provo subito!
    se posso farti una richiesta, mi piacerebbe avere al posto dell'icona della batteria la percentuale residua, cosi evito di installare un widget. E' una cosa mia, lo so, ma mi fa incazzare vedere la batteria senza nulla, devo mentalmente avere sempre sott'occhio quanto residuo ho...
    grazie ancora.
    "il vecchio smanettone" (tua citazione)
  6. #4
    Apr 2011
    dai oggi sono buono, aggiungerò un'altro frame con la percentuale della batteria,dammi il tempo di farlo e lo trovi qui,intanto te flasha la rom e flasha il frame ics...
    My Work:
  7. Il seguente Utente ha ringraziato boostermbkking per il post:
    maurizioscintu (29-10-11)
  8. #5
    Apr 2011
    Quote Originariamente inviato da boostermbkking Visualizza il messaggio
    Grandissimo, sei davvero gentile, ora sto provando a scaricarla (mi sa che il server è saturo da quanti la vogliono provare) e poi ti dico.
    Ciao e grazie ancora
  9. #6
    Apr 2011
    di già??? lo appena messa online... XD sii paziente e riprova + tardi...
    My Work:
  10. Il seguente Utente ha ringraziato boostermbkking per il post:
  11. #7
    Apr 2011
    perdona la domanda stupida: scarico entrambe (ROM e ICS) e poi flasho prima la ROM e poi l'altra parte, corretto? Ovviamente sempre senza uscire da recovery. Grazie ancora, giuro che per oggi non scrivo più...
  12. #8
    Apr 2011
    no no mi fa piacere che scrivete,mica disturbate,cmq si hai azzeccato,prima sempre la rom poi le patch...
    ho pubblicato la nuova patch con % batteria
    My Work:
  13. Il seguente Utente ha ringraziato boostermbkking per il post:
    maurizioscintu (11-11-11)
  14. #9
    Apr 2011
    grandissimo!!! sto caricando la ROM, poi vado sul resto dei componenti.
    ti ringrazio infinitamente.
  15. #10
    Apr 2011
    allora, intanto grazie di tutto, mi piace molto la nuova versione.
    ti chiedo, come si fa a mettere le icone ics che hai nelle foto? ho flashato ics+battery ma escono quelle di go launcher, ho provato a cambiare il tema usando l'app che trovo in lista, mi da errore e si chiude. in cosa sbaglio?
    grazie mille
    Ultima modifica di maurizioscintu; 29-10-11 alle 19:53
