[ROM][JB 4.2.2][AOKP/CM10.1/PA] ReVolt JB [Linaro 4.8.1][Unofficial] [27/07/2013]
ReVolt JB per LG Optimus 4X HD
http://imageshack.us/a/img19/7846/xsv5.png
Caratteristiche
Rom compilata dai sorgenti AOKP/Paranoid Android
Kernel CM10.1
Built from ReVolt Sources | Based on Android 4.2.2 JellyBean
ROM Control Features (from AOKP)
Hybrid Engine | Paranoid Preferences (Thanks to PA Team & Carbon ROM)
Halo (Thanks to PA Team)
Per-App-Color
AOKP Ribbons
Updates Center | GooManager (With Push Notifications)
CyanogenMod Profiles
Power Widget
Navigation Bar Color
Status Bar Color
Option to select Saving Location in Camera
Option to control cursor in text fields using volume keys
Multi User Option
Advanced Phone Options from CyanogenMod (Vibrate on Answer, Every 45 Sec., On Call waiting and Hangup)
Different Pattern Sizes
Apex Launcher
Nova Launcher
Trebuchet Launcher (ReVolt Version)
cLock App (Lock Clock) (CyanogenMod)
Expanded Desktop (Hide StatusBar & Navigation Bar)
Pie UI (Paranoid Android)
Font Size Controlling
DPI Changer *really no need for this, there is pa settings for this*
Notification Shortcuts
CRT On / Off Effect Controller
Lock Screen Targets (CyanogenMod)
Lock Screen Shortcuts (Paranoid Android)
Lista completa: Features | ReVolt ROM
Installazione
E' consigliato fare un nandroid backup della vostra attuale rom.
Copiare rom e gapps nel telefono
in recovery wipe data/factory reset, wipe dalvik cache
flash rom
wipe cache e dalvik cache
flash gapps
riavvio
Download
Rom: http://goo.im/devs/demetris/OptimusX4HD/Revolt
Gapps: Goo.im Downloads - Downloading gapps-jb-20130301-signed.zip
Links e sorgenti
https://github.com/ReVolt-ROM
ReVolt ROM | Fast. Smooth. Stable.
http://imageshack.us/a/img51/1451/ekpa.png
Link XDA: [ROM][JB 4.2.2][AOKP/CM10.1/PA] ReVolt JB [Linaro 4.8.1][Unofficial] 03/07/2013 - xda-developers
