Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 15
[ROM] MotoGinger 2.3.4 (Teaser V.3) *12/08/2011*
    Androidiano VIP L'avatar di iaio72
    Jul 2009
    Ringraziato 618 volte in 346 Posts
    MotoGinger 2.3.4
    Based on Leaked/build Motoblur retail-en.gb 4.5.1-134_DFP-10
    Features:
    Teaser v.3
    > Reworked all system/app -----> deodexed------> optimized -----> and finally "zipaligned"
    > Modded icons/emoticons from statusbar Android formula and GB
    > Removed Gallery3d
    < Removed Maps and street
    < Added 720p record Patch (works only on red lens) (Big thanks to walter79)
    < Removed OI filemanager
    < Added Black statusbar (thanks to Aruoc)
    < Added 1% step battery (thanks to spica123)
    < Replaced "again" logwrapper in system/bin (thanks to walter79)
    < Removed Facebook app
    < Latest bootmenu pre-installed 0.86(defy 2nd init)
    < Added module call record (thanks to ReBoot)
    < Added file manager from ms2 china gb
    < Added battery calibration from ms2 ginger (thanks to walter79)
    < Added clock/alarm widget from ms2 ginger (thanks to walter79)
    < Added sound recorder from china ms2 gb
    < Added original MediaGallery.apk (451-134 rom),deodexed (big thanks to MaxKnall)
    < Update Youtube app
    < Fixed contacts bug
    < Fixed DLNA force-close
    < Fixed Motoblur access (thanks to walter79)
    < Fixed task.apk
    << For fixed the StickyNoteWidget.apk, i hope to solved in the next release! >>
    __________________________________________________ ____________________
    Previous Teaser version
    > Installed BlurHome (launcher)
    > Rom with Motoblur, (tested by my self, works fine!)
    > Removed Blur.Music replaced with CMP
    > Added Gallery3d simple (mediaGALLERY deodex dont work)
    > Added DLNA/Dlna-system apps from chinaGB MS2 (thanks to walter79)
    < Reinstalled old market
    < Added carhomegoogle
    < Aosp Lockscreen
    < Added Maps and street
    < Added Microbes lw and Forest lw
    < Removed module(system/lib) and apk(system/app) 10 point multitouch v0.2 (thanks to dewyeyed and ga1axy)
    < Fonts ubuntu style
    < OI filemanager/Desclock
    > Added Barnacle wifi tether
    < Defy baseband v0.7
    < Added DigitalClock from se
    < Added RadioFM
    < Added Adobe reader
    < Added SpareParts plus
    < Replaced logwrapper in system/bin (thanks to walter79)
    < Updated Facebook
    < Replaced the audio driver milestone2 from original to defy
    < Removed kiplooger.apk (thanks to walter79)
    < Fixed calendar
    < Wifi analyzer
    < Fixed multitouch keyboard
    ----> I remind you that, this rom its a TEST, if you find problems or bugs please report me! Thanks.....
    HOW TO INSTALL
    - Starting installation with any original froyo 2.2.2 (rooted)
    - Download MotoGinger Teaser v3 and put the unzipped folder in Microsd--->(folder and subfolder) clockworkmod---> backup---> put motoginger-test5 folder
    1. wipe via CWM
    2. advanced restore (system/only)
    3. flash fixed-sbf ----> DOWNLOAD
    4. wipe via stock recovery, then reboot.
    For peoples that have GREEN lens, after installed motoginger-rom, can flash from recovery, the patch by Simplestas ---> LINK
    EXTRA
    - if you like other theme/satusbar, you can flash it from recovery as a zip!
    --> Theme sense style with battery %
    --> Theme Honeybread style
    -----> Hey Guys, please REPORT me, if you find any bugs! Thanks!
    Ultima modifica di iaio72; 12-08-11 alle 00:49
    OnePlus 3T
    Meizu Mx6
    Matera
    Motorola mb525
    Ringraziato 55 volte in 21 Posts
    Complimenti Iaio:-) peccato che non posso dedicarmi anche io alla creazione di rom modificate xke posseggo solo un DeFY
    Rocca Priora
    Motorola Defy
    Ciao Iaio72, come da oggetto sono a chiederti, avendo già installato la tua Official Ita Deblur come da procedura , come devo installare Motoginger? Ho visto che su forum-xda è già presente la 3rd test mentre qui di seguito c'è la 2nd test. Quale mi conviene installare a partire dalla mia base.
    Complimenti x il tuo lavoro grazie anticipatamente
    Jul 2009
    Quote Originariamente inviato da teledaniel71 Visualizza il messaggio
    metti la versione 3, che essendo uno zip si installa meglio!
    devi pero prima installare la 451-134 con il metodo nandroid + fixed sbf
    OnePlus 3T
    Meizu Mx6
    Rocca Priora
    Motorola Defy
    Scusa ancora iaio72 se ti disturbo, ma vorrei capire meglio come installo la 451-134 con il metodo nandroid + fixed sbf .
    Grazie ancora
    Jul 2009
    Grazie ancora
    parti da una rom froyo installata
    scarichi il primo pacchetto download, al cui interno trovi il fixed.sbf e la rom originale nandroid (cartella)
    codesta cartella la copi nella microsd, in questo percorso microsd/clockworkmod/backup (catella e sottocartella se non le hai, creale da te)
    dal market scaricati defy 2nd init ed installalo
    poi entri in custom recovery (latest recovery) sarebbe la cwm 4.0.0.6
    vai su backup restore, poi su advanced restore e vedrai la cartella "backup 451-134" e confermi, poi confermi su restore system.img e attendi l'installazione
    quando ha finito o ti sposti dietro fino a confermare su power off
    oppure togli e rimetti la batteria, entri in bootloader (volsu+power) e via rsdlite fleshi il fixed sbf, poi riavvio
    al riavvio avrai la motoblur 451-134 originale rootata
    a questo punto scarichi la mia motoginger.signed che metterai nella microsd,
    riscaricati dal market defy 2nd init,
    rivai in recovery ed installa la mia rom come "install zip from sdcard".....
    al riavvio avrai la motoginger, deodex e funzionante!
    questa procedura serve per poter tornare poi a froyo!
    OnePlus 3T
    Meizu Mx6
  8. Il seguente Utente ha ringraziato iaio72 per il post:
    teledaniel71 (11-07-11)
  9. #7
    Jul 2009
    rilasciato 5 test
    OnePlus 3T
    Meizu Mx6
  10. #8
    Rocca Priora
    Motorola Defy
    Ciao Iaio72, dalla descrizione che hai dato x installare la test 5 sembrerebbe che salvo la test 5 nella microsd, installo tramite RSD il flash.sbf ed il gioco è fatto. Mi sembra che manchi qualcosa.... oppure devo seguire la procedura descritta per la test 3? Grazie anticipatamente
  11. #9
    Jul 2009
    Rilasciata MotoGinger teaser v3
    OnePlus 3T
    Meizu Mx6
  12. #10
    Nov 2010
    Quote Originariamente inviato da iaio72 Visualizza il messaggio
    Ciao iaio , io sono un po tonto a capire ma nello zip Multiupload.com - upload your files to multiple file hosting sites! io trovo solo nandroid e system, nel Multiupload.com - upload your files to multiple file hosting sites! trovo il file sbf che lo installo non rsd ma non trovo il file ginger signed che tu indichi nell'installazione.
    Sbaglio qualcosa?
