Utente del giorno: kroko con ben 1 Thanks ricevuti nelle ultime 24 ore
Dhacker29's IC3RAZR [2nd test version online]
    Androidiani Power User L'avatar di paolosv
    Jun 2009
    Ringraziato 172 volte in 108 Posts
    Working now: phone calls, SMS, data, everything else so far (need to test)
    Not working: Camera, Bluetooth (never activate bt -> causes restart + loop), adb, USB mass storage works not reliable
    Current version (15.02.2012): Pre-Alpha Test0
    Download: ic3razr_test0.zip
    Changelog:
    Test0:
    - system backup from my working system
    - possibly andoid.phone error fixed
    Installation from the scratch:
    - BACKUP your system via Bootstrap
    - wipe your phone via MOTOROLA Recovery (System + Data)
    - flash this rom via RSD or with the tool provided here if have the newest bootloader
    - enable usb-debugging and installation from unknown sources
    - root with your preferred method
    - install Bootstrap
    - flash IC3RAZR GSM test 0
    - reboot, ICS should start now, you should not get an android.phone crash, but an "unknown sim card" error
    - to enable mobile data you have to add an APN in network settings (look at your operator's hp which settings you have to use)
    Update: After about 4 hours of work and testing I came to the conclusion, that atm we can't get rid of the sim card error because we don't have the source code from the Moto leak
    Will try RIL libs from other roms the next days, stay tuned and report whether you could make it work with the manual above. Greetz
    Annotations:
    - working version of Gapps is included
    - CWM on boot is standard to avoid flashing via RSD every time
    - data works, apn has to be set manually
    - "sim card from unknown source" error is normal, annoying, but doesn't affect system
    Modifications:
    For an improved ICS impression, you can enable the typical on screen buttons
    (see attachements; soft keys are deactivated now): Download
    To deactivate on screen buttons again flash this: Download
    Versione ancora in fase TESTING!
    io l ho provata non gira malissimo ma giusto una versione da testare non utilizzabile a lungo per il momento!
    Motorola RazR
    Motorola Xoom
    Rom Team Eos ICS v1.0.0 3G (mz601)
    Kernel Tiamat ICS 3.0.5
    Cpu overclock Min : 216 - Max : 1504
    Governor Lagfree
    POTETE RINGRAZIARE CON IL TASTO IN BASSO A SINSTRA
    Oct 2010
    Tantissimi, li ho avuti tutti
    Ringraziato 212 volte in 159 Posts
    Quote Originariamente inviato da paolosv Visualizza il messaggio
    ma perchè non spieghi che cosa è? copiate le cose da xda e neppure spiegare cosa sono! per questo nessuno ha commentato non si capisce cos'è
    Jun 2009
    Quote Originariamente inviato da Abrax Visualizza il messaggio
    Visto che è in fase TESTING non credo meriti che io gli dedichi tempo a tradurre!
    E' una Rom Moddata su base ICS per il RazR
    Rom che però essendo in fase Testing è altamente instabile e non tutto funziona, ovvero è piena di quello che si definisce BUG
    - Problemi di BT
    - Problemi di ricezione
    - Reboot improvvisi
    - Impossibilità di settare l'APN
    ecc
    Per questo mi sono limitato a un copia e incolla...
    nel momento in cui la riterrò alla portata di "tutti" allora approfondirò l'argomento.
    Per il momento non merita nulla di piu che un semplice copia e incolla!
    Motorola RazR
    Motorola Xoom
    Governor Lagfree
