[ROM AOSP] CronosGinger 1.7.1
    Senior Droid L'avatar di hero96
    May 2010
    Pocophone F1
    Ringraziato 29 volte in 23 Posts
    Here is a new release of your favorite Cronos ROM for your Device. This time it has the first release of Cronos X included.
    This is still WIP (Work In Progress) by me and Computerfreak so please dont go flaming us about features that are not included.
    If you have a wish list of functions please use a proper Forum thread to post them so that we can have a look at it.
    NOTE: DOES THE PHONE FEEL SLOW AFTER THE FIRST FLASH?
    GO TO X SETTINGS, CPU SETTINGS AND CHANGE THE MINIMUM AND MAXIMUM SPEED TO YOUR DESIRED SPEED.
    I HAVE HAD TO PUT A LOWISH DEFAULT THAT IS SAFE FOR EVERY DEVICE.
    You have bugs to report? Please use: MantisBT
    Note: Please reboot after any flash you do. This is very important.
    Release Notes
    21 July 2011 | Cronos Ginger X 1.7.1:
    Fixed: Android Battery Drain.
    Please recalibrate your battery.
    Please fully charge the battery to 100%.
    X Settings updated to version 0.0.3
    Font sizing will stay permanent.
    Fixed: ScreenStatus Scaling.
    Fixed 30tweak file, thanks bleep42.
    System should be a bit snappier.
    Added a new version string for X Settings Mod itself.
    Volume rocker wakeup port by ComputerFreak
    Enable/disable CRT on/off animationport by Feeyo/Computerfreak
    Added option to change the indicator color in the notification widget port by ComputerFreak
    Fixed some checkboxed incorrectly checked by default by ComputerFreak
    Fixed some incorrect text when selecting brightness mode by ComputerFreak
    Feeyo sta facendo un enorme lavoro anche per altri terminali e vi consiglio vivamente di provare questa rom...
    Ulteriori info Qui bisogna essere registrati...
    Buon modding
