Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 39
[ROM] [BASED ON CM9] CyanogenMod S3 Evolution Beta 3
    Androidiano L'avatar di Androidianodream
    Samsung Galaxy Ace
    Ringraziato 59 volte in 17 Posts
    Salve a tutti, oggi voglio presentarvi questa rom che ho trovato su xda basata su CyanogenMod 9.
    CHANGELOG: (IN ATTESA DI QUALCUNO CHE MI AIUTI NELLA TRADUZIONE LI METTO IN INGLESE)
    Beta 3 Ultimate:
    - Merged on CyanogenMod 9.0.4-RC1-MacławStudios
    - disable wallpaper scrolling (like stock Galaxy s3) & some tweak on TWUx launcher for beter performances
    - LagFreeV3 ReRolled include (thank's to Slaid480's)
    - AMARULLZ DATA TO SD-EXT(A2SDX) (i provide one without to) (thank's to amarullz for made it & sergeantgeneral for share)
    - SRS Audio Effects (thank's to paul-xxx for made it & ImbaWind for share)
    - fix Google voice shearch-
    - Accuweather style on lock screen
    - Fix missing Languages (korean chinese ect...)
    - better battery
    - fix the system not responding some time
    - replace clock with TW clock
    - SG3 Clock widget
    - Samsung apps
    - S3 other service
    - Samsung Account Service (youcan download additional s3 app on samsung apps and make it work (like Music hub 3.0 , kies Cast , Family story , mystory)
    - Facebook Sns Account
    - stock video player
    - youtube
    - polaris office
    - Quik Panel settings
    - Cfw Manager
    - Application monitor widget
    - WiFi File Manager (allow you to connect to your sd card with web browser on your Pc)
    - New real S3 bootanimation
    - Music Hub Hd 3.0
    - Family Story
    - Kies Cast
    - PicsPlay (Replace the S3 photo editor work great but need to adjust Dpi comming next release)
    - Postit
    Beta 3 Light:
    - better battery
    - SG3 Clock widget
    - S3 other service
    - youtube
    - polaris office
    - Cfw Manager
    NE IO NE ANDROIDIANI CI ASSUMIAMO ALCUNA RESPONSABILITA PER LE VOSTRE AZIONI, SEGUITE LA GUIDA A VOSTRO RISCHIO E PERICOLO
    Per installare la rom ci servirà una partizione ext3 o ext4.
    Su xda consigliano di usare questo tool, scaricabile da qui Free download Magic Partition Manager Software, partition magic alternative, free partition magic, partition magic Windows 7 and server partition software - Partition Wizard Online
    Guida:
    1: Eliminare la vecchia partizione QUESTA AZIONE ELIMINERA TUTTI I FILE QUINDI CONVIENE FARE UN PRIMA UN BACKUP
    ATTENZIONE: SCEGLIETE CON ATTENZIONE LA SD CARD (QUELLA CON L'IMMAGINE DIVERSA), NON L'HARD DISK
    2: Creare una nuova partizione in FAT O FAT 32: FAT SE LA NOSTRA SD E 2 GB O MENO, FAT32 SE E 4 GB O PIU.
    Mettete le impostazioni come nell'immagine e in file system mettete FAT O FAT32.
    3: Dopo aver inserito correttamente tutte le impostazioni cliccate su ok.
    Ora scarichiamo una delle due versioni dai seguenti link:
    Ultimate: Dev-Host - S3-Evolution-Beta-3-Ultimate.zip - The Ultimate Free File Hosting / File Sharing Service
    Light: Dev-Host - S3-Evolution-Beta-3-Light.zip - The Ultimate Free File Hosting / File Sharing Service
    Dopo averca scaricata copiamola nella sd.
    INSTALLAZIONE (RICHEDE CLOCKWORKMOD 5):
    Avviamo il telefono in recovery e facciamo un wipe data/factory reset.
    Attendere il termine del wipe e andare su install zip from sd card, scegliere la rom e installarla.
    Il telefono dovrebbere riavviarsi automaticamente alla fine dell'installazione.
    Se lo schermo rimane bianco togliere la batteria e riaccendere.
    ALCUNE IMMAGINI:
    IO NON L'HO PROVATA MA SU xda DICONO CHE FUNZIONA, FATEMI SAPERE COM'E
    SE VI E PIACIUTA LA GUIDA CLICCATE THANK
    Immagini allegate
    Ultima modifica di Androidianodream; 19-08-12 alle 17:37
    Samsung Galaxy S4 Mini Non Moddato
    Android 4.4.4 KitKat
    I MIEI LAVORI
  2. I seguenti 4 Utenti hanno ringraziato Androidianodream per il post:
    ClaudìoS3 (15-10-12),Homer99 (30-03-13),maurysilver (26-08-12),PeppeGSR (28-09-13)
    Catania
    Samsung galaxy ace gt- s5830
    Provata , a livello di interfaccia è molto bella , molto simile a quella dell s3 a parte per la barra dei power widget che non è affatto come si vede nella foto. A livello di prestazioni però non brilla molto , a volte si blocca e va un pò a scatti quando fai un pò più di operazioni contemporaneamente , infatti ho dovuto impostare la cpu a 883 mhz per averla leggermente migliore. Per il resto la rom non è male anche se presenta gli stessi problemi della cm9 :/
    [Device]Samsung Galaxy S3 GT-I9300
    [Versione Android] 4.1.2
    [Kernel]3.0.31-1314436
    [CyanogenMod Version//
    [Numero Build]JZO54K.I9300XXEMG4
    [Script]//
  5. #3
    CIAO andryx97 come hai fatto a:
  6. #4
    Androidiano VIP L'avatar di Toni5830
    Somewhere Over the Rainbow
    Samsung Galaxy S Advance
    Ringraziato 485 volte in 375 Posts
    Scarica ad esempio no-frill cpu control dal market e regoli la frequenza della cpu (hai questa rom??)..
    Quello di cui ho bisogno è un'informazione,
    non un'informazione utile, naturalmente,
    ma inutile.
  7. #5
    Smile
    Quote Originariamente inviato da Toni5830 Visualizza il messaggio
    ciao grazie devo ancora installarla ma mi sto documentando
    grazie di tutto
  8. #6
    Androidiano L'avatar di Gianny08
    Samsung Galaxy Ace (S5830)
    ragazzi la batteria quanto vi dura? v lo domando perche io ho installato la cyanogenmod 9 e la matteria ,senza utilizzare per niente il cell, mi si è scaricata in 1/2 giornata :-(
    e per a partizine in ext3/4 è obbligatorio ? velo domando perché io non ho kmai partizionato l'sd per installare una custm rom e non capisco a cosa serva partizionare l'sdin ext3 per installare ua rom xD
    Ultima modifica di Gianny08; 01-10-12 alle 19:01
    [Smartphone] Samsung Galaxy Ace GT-S5830
    [ROM] Cyanogenmod 10 (JB 4.1.2) Versione del 05/12/2012
    [Kernel] 2.6.35.14-jellybean lagloose@jellaxy-note #15
    [Launcher] Trebuchet 0.2
    Rom Testate:
    iOS 5 ROM per Galaxy Ace
    Cyanogenmod 10 (JB 4.1.1) by Jellaxy.com
    StockLite v7.1
    PAC (Paranoid+AOKP+Cyanogenmod 10 by nims11)
    Cyanogenmod 9 RC 2.1
    Cyanogen Mod 7.9 V1
    Se ti sono stato D'aiuto clicca su Thanks !!!!
  9. #7
    Androidiano L'avatar di ipeppe
    Forli
    Oneplus 6
    ma ha gli stessi bugs della cm9 rc1 vero?
  10. #8
    Senior Droid L'avatar di dagasp10
    Android's world
    Nexus 5
    Ringraziato 90 volte in 85 Posts
    Ragazzi perchè quando la installo e riavvio rimane lo schermo celeste e non si accende? Ho installato la 3.1 facendo anche la partizione della sd, full wipe e tutto, perchè?
  11. #9
    Quote Originariamente inviato da dagasp10 Visualizza il messaggio
    Hai la recovery cwm?? Inoltre la rom su cui è basata (la rc1 di maclaw) ha dato anche a me lo stesso problema..ho risolto riflashando..
    Inviato dal mio Cooper con cm9
    ma inutile.
  12. #10
    Monza
    Nexus 5
    Ha qualche bug questa rom o è tutto funzionante?
