Utente del mese: megthebest con ben 40 Thanks ricevuti nell'ultimo mese
[ ROM ][JB][ANDROID 4.2.2]Androidarmv6 CM-10.1
    Senior Droid L'avatar di erikteck
    Galaxy Gio, Nexus 5
    Ringraziato 118 volte in 68 Posts
    Thread originale: Androidarmv6 for Samsung Gio GT-5660 update 12.02.2013 - Other - MoDaCo
    Cosa funziona:
    GPSCamera preview & taking pictures
    Playstore
    Gmail
    Wifi
    Mobile data
    Booting
    Audio
    HW accel
    Touch (with multitouch)
    Sensors
    USB mass storage
    Telephony
    Bluetooth
    Camera recording
    Changelog:
    12.02.2013
    • CM and Androidarmv6 optimizations
    • Further see here mainly kernel updates
    • BLN disabled by default, led will not light up for minutes anymore
    17.01.2013
    • GPS Fix (Wayland Ace)
    • Re-organized vendor samsung, added device specific files (psyke83)
    • Disabled Triple FrameBuffer and some other kernelchanges (optimize memory)
    • CM Changes
    • Wifi allways on in sleep (reconnecting problems)
    06.01.2013 Beta5:
    • Applications added: Google Talk, chrome bookmarks sync, Setup wizard
    • OMX libs fixed: Youtube controls bug fixed, camera crash fixed, camcoder works in HW mode
    • Source based liblight with BLN support, BLN enabled by default
    • Superuser settings crash fixed
    • Surface dithering disabled by default for more perfomance
    • Added lagloose's force repeat ringtone hack
    • Other fixes, that I forgot
    • Latest CM and androidarmv6 sources
    31.12.2012 Beta4:
    • Wifi enhancements: signal indicator is working, faster connecting to AP, tethering (unstable)
    • Network location fix (A-GPS is working now)
    • Lockscreen improvement: date is too visible
    • UI improvements (again little speedup)
    • Some OMX libs improvements
    • CM and androidarmv6 sources updates
    28.12.2012 Beta3:
    • Gallery issue is fixed (Thanks CM team)
    • Lockscreen issue with cutted clocks is fixed
    • GPS improved
    • Added LiveWallpapers picker, so u can install any livewallpaper if u want
    • ALL locales and languages support
    • init.d script is working now
    • UI responsibility is improved
    • CM sources updated
    24.12.2012 Beta2:
    • Added language locales: en_GB fr_FR it_IT de_DE es_ES ru_RU
    • Added predefined APN list (for mobile data)
    • Added back ThemeChooser
    • Google search box disabled by default, can be enabled in Settings
    Marry Xtmas
    23.12.2012 Beta1:
    • native USB tethering fixed
    • bluetooth fixed
    • CM sources update
    • Backported USB gadget stuff from kernel 3.0 (USB functions do not use legacy stuff anymore)
    • Video recording
    • Quick search box added
    • Other changes
    Note: ADB must be enabled in development settings
    19.12.2012 Alpha5:
    • Camera preview & taking pictures is working
    • Removed second camera app (LegacyCamera is not used anymore)
    • Updated CM sources.
    18.12.2012 Alpha4:
    • wifi fixed, switched to wpa_supplicant version 0.8
    • mobile data is working
    • keyboard size is fixed
    • keyboard new swipe ability does not cause crash anymore
    • updated cm sources
    • Torch application is added
    • Readded developer options is settings.
    29.11.2012 Alpha3:
    • USB mass storage is fixed
    • new hw QCOM modules
    • Telephony fixed
    • Better stability
    • Android 4.2.1
    26.11.2012 Alpha2:
    • new notification bar buttons fixed
    • added CM10 bootanimation instead of CM9 animation
    • audio playback fixed (missing media_codecs.xml) was added
    • added lockscreen
    • Hardware "Home" button is fixed
    26.11.2012 Alpha1:
    • Initial version (very unstable)
    DOWNLOAD: cm-10.1-20130212-NIGHTLY-gio.zip | by erikcas for Galaxy Gio
    Smartphone: Samsung Galaxy Gio
    Rom: CyanogenMod 7.2
    Recovery: CWM 6.0.3.2
  2. I seguenti 2 Utenti hanno ringraziato erikteck per il post:
    anto999 (17-02-13)
    Galaxy Gio, Nexus 5
    Riservato per aggiornamenti
    domani sistemerò il thread
  5. I seguenti 2 Utenti hanno ringraziato erikteck per il post:
    p3ste (18-02-13)
  6. #3
    Baby Droid L'avatar di p3ste
    Siena
    Samsung Giò
    Ringraziato 14 volte in 9 Posts
    Ho visto che hai aperto un thread su questa rom ti volevo segnalare l aggiornamento del 16/02/2013 " [ROM] [JB] [ANDROID 4.2.2] Androidarmv6 CM-10.1 16-02-2013" sul forum xda.
    Xiaomi Mi A1
  7. #4
    Androidiani Power User L'avatar di anto999
    Camposano (NA)
    galaxy Nexus-galaxy gio
    Ringraziato 1,520 volte in 1,196 Posts
    Chiudo da come richiesto!
    Inviato dalla tazza del tè.
    Il MODDING TI MODDA...NON INIZIARE
    by
    Gg636(il saggio )
