Pagina 1 di 52 1231151 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 520
[ROM]CM7.2 Democracy FINAL based squadzone
    Androidiani Power User L'avatar di anto999
    Camposano (NA)
    galaxy Nexus-galaxy gio
    Ringraziato 1,520 volte in 1,196 Posts
    DEMOCRACY?
    Non so,è solo un nome..
    Screenshots sono con le prefenze dell'autore app,sfondi,ecc..
    Wallpapers, fonts e favorites apps,non sono incluse app a pagamento.
    CREDITS & THANKS TO:
    # XDA - for this place, tutorial, reference etc
    # Android - for OS platform
    # Samsung - for firmware & platform
    # Google - for references, resources etc.
    # CyanogenMod - for ROM/sources
    # vo-1 - for ROM
    # lovetz - bring infomation ROM to XDA
    # ketut.kumajaya - for Blackhawk Kernel
    # dragonn - for Firekernel version
    # Achep - for ICS Theme & Layouts
    # balamu96m - CM9 Style Settings tutorial
    # lagloose - GPS and Sensors patch
    # itasoulas - hw Library GPS & Sensors patch
    # happily1986 - Solutions for faster GPS locks
    # imbawind - for Adrenaline™ Engine
    # slaid480 - build.prop tweaks tutorial
    # knzo - build.prop tutorial
    # hubix - tutorial easy flash recovery
    # pyronia - for easy guideline script making
    # yagya - for PDroid Patch tutorial
    # Team Carbon - blue torch icon
    # Mobint - for Holo Launcher
    # tj_droid - for tutorial decompile/compile using APKManager
    # P4qui7o - for tutorial manually deodex
    # skynet28 - Tools for Disable and enable journaling in internal ext4 Partitions
    # aaiko - idea for QuickPic replacement for Gallery3D
    # Ace King 34 - point me for fix bootloop - Launcher failure
    # All friends here - for supports & reading my topic
    # Antonio8297 - for port to Gio
    # Your name here - PM me if you think, you should be here (may be I'm forgot)
    FEATURES & INFO[HIDE]
    - phiexz kernel(6/6/2012)
    - Based on CM7.2.0 squadzone
    - Preinstallato PDroid & Patchers
    - Preinstallato Holo Launcher
    - Preinstallato Link2sd
    - Preinstallato Ice Cream Sandwich theme (always blue signal)
    - Preinstallato Adrenaline™ Engine
    - Fully Integrated ICS Layout - no need reboot - patch - reboot - undo - reboot - patch - reboot
    - Integrato Slim Lock Patterns & semi transparent circle
    - Integrato Slim SIM PIN Code Entry
    - Integrato text correction for USB Mass Storage description
    - Ads blocked by host file.
    - No fancy bootanimation. Ridotto tempo d'avvio con very lite bootanimation (only 71kb in size)
    - Black theme for FM Radio
    - Fix spinner overlaping text for USB mass storage
    - Apps tested & work fine; Link2SD, Font Changer, Viber, Foursquare, BLN Pro, PDroid
    - QuickPic - replacement for Gallery3D
    - Not recommeded restoring apps via Titanium Backup, install apps normally.[/HIDE]
    DOWNLOAD LINKS nel 3rd POST
    Ultima modifica di astrone; 05-10-12 alle 21:55
    Il MODDING TI MODDA...NON INIZIARE
    by
    Gg636(il saggio )
  2. I seguenti 10 Utenti hanno ringraziato anto999 per il post:
    Andryx240709 (29-09-12),AngeloV3rsus (15-08-12),blinker (28-07-12),DanielV (09-08-12),dedeswim (10-07-13),erre (06-08-12),ferrando (23-08-12),mneo (06-01-13),Ricky72 (27-07-12),Timmy (23-09-12)
    Camposano (NA)
    GUIDA IMPORTANTE CONFIGURAZIONE - MY SETTINGS
    1. Launcher
    - Menu - Launcher settings - General Settings - Unticks all
    - Menu - Launcher settings - Desktop Settings - Layout Settings - 5 X 5
    - Menu - Launcher settings - Desktop Settings - Scrolling Settings, Other Settings - Unticks all
    - Menu - Launcher settings - Drawer Settings - Layout Settings - Potrait grid 4 X 5
    - Menu - Launcher settings - Drawer Settings - Layout Settings - landscape grid 4 X 5
    - Menu - Launcher settings - Drawer Settings - Scrolling Settings - Transition effect - None
    - Menu - Launcher settings - Drawer Settings - Scrolling Settings - Infinite scrolling - Untick
    - Menu - Launcher settings - Drawer Settings - Scrolling Settings - Scrolling speed - 100
    - Menu - Launcher settings - Drawer Settings - Scrolling Settings - Scrolling cache - None
    - Menu - Launcher settings - Drawer Settings - Other Settings - Tick Disable open/close animation
    - Menu - Launcher settings - Drawer Settings - Other Settings - Background transparency - 24
    - Menu - Launcher settings - Dock Settings - Tick Enable dock, Dock pages = 1, Dock icons = 5
    - Menu - Launcher settings - Dock Settings - Scrolling Settings - Infinite scrolling - Untick
    - Menu - Launcher settings - Dock Settings - Scrolling Settings - Scrolling speed - 100
    - Menu - Launcher settings - Dock Settings - Other Settings - Untick Hide dock divider
    2. CyanogenMod settings - Interface - Notification power widget
    - Interface - Notification power widget - General - Tick Hide indicator (for hide green indicator below toggle power widget)
    - Interface - Status bar tweaks - AM/PM style - Tick small
    - Interface - Status bar tweaks - Battery status style - Tick Percentage
    3. Performance settings
    - CPU settings - Available governors - Tick smartassV2
    - Min CPU frequency = 245MHz
    - Max CPU frequency = 806Mhz
    - Tick Set on boot
    - Unticks for Use JIT, Enable surface dithering but Tick for Use 16bit transparency.
    - Tick for Use JIT if you use S2E (simple2ext)
    - Scrolling cache - Choose for Force disable (it will help you prevent the background becomes white when scroll through messages)
    4. GPS Settings
    - Location & security - GPS Source - Tick for Use Internal GPS
    - Configure GPS by your country (except Malaysia - already figured for Malaysia)
    5. Customize fonts
    - Download & install Font Changer from Google play.
    - Download more fonts here: dafont.com
    - App drawer - Font Changer - Menu - Settings - Fonts Location - /sdcard/fontchanger/ - press OK
    - Put your download fonts to /sdcard/fontchanger
    - App drawer - Font Changer - choose your desire font - reboot
    - Done.
    6. Tips for battery life
    - Save battery life here
    - Other tip Precise Volume Control, Smooth Scrolling and Battery Drain Fix . (Democracy's ROM already have this fix)
    - After reboot - go to Menu - Manage apps - Running tab - Kill process for Google playstore
    - App drawer - Settings - Accounts & sync - Untick Background data
    - Turn it on Background data & Google playstore if you want download from Google playstore.
    by
    Gg636(il saggio )
  5. I seguenti 10 Utenti hanno ringraziato anto999 per il post:
    Alex792 (25-06-13),babydovio (29-12-12),blinker (28-07-12),DanielV (09-08-12),erre (06-08-12),ferrando (23-08-12),ishockzz (26-07-12),mneo (06-01-13),Ricky72 (27-07-12),Timmy (23-09-12)
  6. #3
    Camposano (NA)
    DEMOCRACY V2 screen shots
    APKS REMOVED
    - ADWLauncher, Androidian, CMUpdateNotify, CMWallpapers, Cyanbread, Development, DSPManager,
    Email, Gallery3D, HTMLViewer, PicoTts, Protips, Provision, QuickSearchBox, RomManager, SamsungServiceMode,
    Stk, TtsService, VoiceDialer & VpnServices.
    CHANGELOG V2
    - Firekernel updated to 22.07.12
    - Fixed bootloop when switch to Centered under Widget layout
    - Rearrangement menu, layout, row colums etc (more viewable screen, no need change LCD Density)
    - Merged theme into system (no 3rd party theme need)
    - Semi transparent statusbar
    - Semi transparent Launcher menu
    - Semi transparent popup menu
    - Semi transparent SIM PIN code entry
    - BLN support
    - Add 30 volumes steps
    - Check box alarm clock (ICS9 Style)
    - Removed PDroid & Patchers (complicated with 30 volumes steps)
    - Removed Link2sd
    - Removed ICS Theme
    - Rearrangement ICS CM9 style settings
    - Busybox updated to v1.20.1
    - Hololauncher updated to v1.1.2 (free version)
    - Superuser updated to v3.1.3
    - Google Play Store updated to v3.7.13
    CHANGELOG V2.1
    - Add QuickSearchBox.apk, Stk.apk, Talkback.apk, TtsService.apk, Gmail.apk & VoiceSearch.apk
    - Standard Clock - on the right side (prevent overlapping notification icon)
    =====V3.1=====
    - same base with v2.1
    - added Audio Manager (free version)
    - added Color Note
    - Mod transparent calendar by me
    - Mod transparent superuser by me.
    - fixed gray text & text margin
    - fixed superuser & transparent
    - fixed calendar & transparent
    - fixed keyboard (LatinIME) not showing icon under "manage applications"
    - Holo Launcher v1.2.3*
    - Mod framework-res & some others apks.
    - Enabled Mms enter key
    DOWNLOADS
    =====V3.2=====
    - removed Audio Manager
    - added Beats audio engine + Alsa + AudioFXwidget (thanks to Lovetz)
    - added stock Task Manager (thanks to Cryss)
    - added Browser apk
    - Task Manager mod by me (ICS Theme)
    - fixed superuser
    =====V3.3=====
    - Added Adrenaline™ Engine 4.3
    - Replaced browser.apk with DolphinBrowser
    - Fix superuser
    - Fix Accessibility settings for "Power button ends call"
    - Fix titlebar text to close.
    - Beats audio engine + Alsa + AudioFXwidget (still here)
    - Task Manager (still here)
    =====FINAL EDITION=====
    - Intergrated Adrenaline™ Engine 4.3
    - Replaced browser.apk with DolphinBrowser (updated to v9.0)
    - Google Play updated to v3.9.1.6
    - Colored icons ICS settings styles
    - Colored icons Phone Options*
    - Added some menu for ICS settings styles (Mobile Network, Task Manager & Wallpapers)
    - Added ICS Theme mod (non transparent for popup dialog, background for some apps)
    DOWNLOADS
    v2: *http://www.mediafire.com/download.php?ymgj73724fj297a outdated
    v2.1: http://www.mediafire.com/download.php?zjxc5zsqf3u2mw9 outdated
    v3.1: Democracy_v3.1 (mirror,use mirror only if first link not work)
    FINAL:DCMR-GIO-FINAL
    =======BEGIN INSTALLATION FOR FINAL=======
    1. Flash DCMR-FINAL-GIO (Installation steps is same as previous rom)
    OPTION
    Holo Launcher mod for transparent menu, resize font, row, icons etc.
    - Put in HoloLauncher-update.zip on your SD Card
    - Boot into CWM5 Recovery - mount system
    - Instal zip from sdcard - choose zip from SD Card - flash HoloLauncher-update.zip
    - Reboot
    PATCHERS 1
    Enabled enter key create new line for Mms apk
    (Integrated with V3.1)
    - App drawer - Messaging - Menu - Settings - EXTRA SETTINGS
    i- UNTICK Send on Enter will create new line
    ii-TICK Send on Enter msg will be send when enter key pressed
    File allegati
    Ultima modifica di anto999; 22-11-12 alle 23:05
    by
    Gg636(il saggio )
  7. I seguenti 8 Utenti hanno ringraziato anto999 per il post:
    Alex792 (25-06-13),blinker (28-07-12),DanielV (09-08-12),erre (06-08-12),ferrando (23-08-12),ishockzz (26-07-12),Ricky72 (30-07-12),Timmy (23-09-12)
  8. #4
    Camposano (NA)
    GUIDA INSTALLAZIONE:
    * Riavviate in recovery
    * Eseguite wipe data,e da advanced fate wipe dalvik cache
    * Da install zip from sdcard scegliere la rom
    * Eseguite un wipe data,poi da advanced fate wipe dalvik cache
    * Reboot system now
    N.B:
    Il primo avvio ci vorrà un pò di tempo,ma non preoccupate,se non si avvia ritornate in recovery e rifate un wipe!
    Ultima modifica di anto999; 19-12-12 alle 22:32
    by
    Gg636(il saggio )
  9. Il seguente Utente ha ringraziato anto999 per il post:
    Alex792 (25-06-13)
  10. #5
    Baby Droid L'avatar di ishockzz
    Padova
    Samsung Galaxy s2
    bel lavoro complimenti
  11. #6
    Banned
    Google Nexus 5
    Ringraziato 3,070 volte in 2,700 Posts
    veramente bella questa rom, sicuramente sarà una che proverò, ma che cambia di effettivo tra questa e la cyano 7
  12. #7
    Camposano (NA)
    Quote Originariamente inviato da 0raziel0 Visualizza il messaggio
    è una cyano 7 moddata in stile ics e basata sulla cyano 7 più stabile,la squadzone.
    PS aggiunto il link download
    ps2: ho già avuto 160 download in 1 ora
    Ultima modifica di anto999; 27-07-12 alle 00:24
    by
    Gg636(il saggio )
  13. Il seguente Utente ha ringraziato anto999 per il post:
    0raziel0 (27-07-12)
  14. #8
    Susegana
    Ma a livello di prestazioni hai implementato qualcosa rispetto alla apocalypse? (forse prestazioni batteria?)
    Inviato dal mio GT-S5660 usando Androidiani App
  15. #9
    Camposano (NA)
    Quote Originariamente inviato da Mabit Visualizza il messaggio
    questa è tutt'altra cosa,ma a prestazioni siamo lì,essendo già ottimizzate di loro.e sono simili
    by
    Gg636(il saggio )
  16. #10
    Molto bella ..la sto provando e va di meraviglia...ho un piccolo problema...
    lo sfondo mi compare tutto nero sono andato a impostazione--->Themes li compare lo sfondo Democracy ...faccio "Applica" vado alla schermata principale ed è sempre nero lo sfondo cioè vuoto ...cosa devo fare? ho riflashato ma niente sempre uguale... mi piace lo sfondo Democracy
    invece se imposto uno sfondo della Galleria lo prende senza problema...
    del resto va molto bene mi sembra meglio della apocalypse...
    grazie Anto..
