Utente del mese: megthebest con ben 40 Thanks ricevuti nell'ultimo mese
Pagina 1 di 2 12 ultimoultimo
[Q] How to pull out kernel from stock firmware with .pda extension?
    Ringraziato 15 volte in 4 Posts
    How to pull out kernel from stock firmware with .pda extension? so, if i installing custom kernel, i can back to stock kernel with flashing stock kernel extension .pda from odin :o
    Please answer.
    I can speak italian, and bad in english.
    Sorry and thanks before.
    Androidiano VIP L'avatar di ZackFair84
    LG G5
    Ringraziato 1,022 volte in 794 Posts
    .pda extension?? It must be a .tar file :/
    Proud developer of Galaxy Next Turbo Custom Rom Optimus Rom™ 3.0.0 testing
    Androidiano L'avatar di deltafile
    Brescia
    Galaxy Next Turbo e Moto G
    Quote Originariamente inviato da Fahmi1597 Visualizza il messaggio
    Please answer.
    There is a link to download a flashable stock kernel (extracted by Michelasso from the XILG1 firmware) in this forum...you can search in the Cor Optimi thread for it..i think it's in the first page.
    https://dl.dropbox.com/u/34455199/GT..._XILG1.tar.md5
    Ultima modifica di astrone; 01-11-12 alle 16:14
    PHONE: Galaxy Mini/Pop Plus GT-S5570I
    ROM: CM7 Reincarnation
    KERNEL:Cyanus 1.9
    non uso più questo device (anche se seguo le news) adesso ho:
    PHONE: Motorola Moto G 8GB
    ROM: C-Rom 6.2 [4.4.2 kitkat]
    KERNEL: Furnace Kernel 1.2.0
    Androidiano VIP L'avatar di astrone
    In mirroring
    Oneplus 6T
    Ringraziato 2,417 volte in 1,487 Posts
    Please answer.
    No problem, if u have problem with italian Language you can use English
    11° Discepolo, SuperSuita a vita
    Androidiano VIP L'avatar di Michelasso
    Treviso
    Ringraziato 984 volte in 486 Posts
    Once you have the file PDA_blablabla.tar.md5 made with splitfus or Odinatrix you can untar it with
    tar -xvf PDA_blablabla.tar.md5
    One of the files will be boot.img. That's the kernel image for you..
    Se sono stato utile non dimenticare di premere Thanks!
    Visita la mia collezione di temi per telefoni e tablet Xperia!
    Okay, wrong extension, my mean .tar.md5 so i can use/flash it via odin in .pda box
    Thank you all, nice to join here
    Quote Originariamente inviato da deltafile Visualizza il messaggio
    And how to create odin flashable kernel with .tar.md5 extension, sir michel? I think learning from you will better
    Quote Originariamente inviato da ZackFair84 Visualizza il messaggio
    Nah, that's my mean
    Ultima modifica di astrone; 02-11-12 alle 09:50
  9. #8
    SAMSUNG GT-S5570I
    Ringraziato 1,091 volte in 873 Posts
    Nah, that's my mean
    Just extract the original rom into a directory and with splitfus2 use this command line to extract only the kernel image from it.
    codice:
    ./splitfus2 -k romfilename.tar.md5
    Obviously you should have linux or cygwin under windows
    Guida per partizionare la microsd: HERE
    Tutti i file per il Next Turbo nel mio repository: HERE
    Premi a sinistra per ringraziarmi se ti son stato d'aiuto!
  10. #9
    Quote Originariamente inviato da Korgar Visualizza il messaggio
    codice:
    sure, i have cygwin in my Windows
    but why it's happens?
    Fahmi@Windows ~
    $ ./splitfus2 -k S5570IDXLF2HOME.tar.md5
    SplitFUS2 by Doky v2.00.120425GA[*]Exctracting kernel image only
    Processing file: S5570IDXLF2HOME.tar.md5
    *** Error decoding filename
  11. #10
    SAMSUNG GT-S5570I
    Fahmi@Windows ~
    Will check myself this morning. If I encounter the same issue, it's better to ask the author on the xda forum.
    Inviato dal mio GT-S5570I usando Androidiani App
    Edit: here's my log
    codice:
    $ ./splitfus2 -k splitfus2.exe S5570IDDLG2_S5570iODDLG2_S5570IDDLG2_HOME.tar.md5
    SplitFUS2 by Doky v2.11.120625GA
    Checking prerequisites...
    ...tar, md5sum, zip found, ready to go![*]Exctracting kernel image only
    Processing file: S5570IDDLG2_S5570iODDLG2_S5570IDDLG2_HOME.tar.md5
    MODEL: S5570I
    PDA: DDLG2
    CSC: ODDLG2
    MODEM: DDLG2
    Temporary workfolder: S5570I_DDLG2_ODDLG2\
    [      sbl.bin ] --- Size: 1306624 bytes
    cygwin warning:
      MS-DOS style path detected: S5570I_DDLG2_ODDLG2\sbl.bin
      Preferred POSIX equivalent is: S5570I_DDLG2_ODDLG2/sbl.bin
      CYGWIN environment variable option "nodosfilewarning" turns off this warning.
      Consult the user's guide for more details about POSIX paths:
        http://cygwin.com/cygwin-ug-net/using.html#using-pathnames
    [    BcmCP.img ] --- Size: 11534336 bytes
    [     boot.img ] --- Size: 4448256 bytes
    Checking wipe data file: _base\S5570I_userdata.img  [OK]
    Packing kernel image
    Now creating the kernel pack
    Output file: Kernel_S5570I_DDLG2.tar.md5
    Removing work folder
    SplitFUS2 finished
    It works on my side, I suggest you to download the same package from sammobile.com and to keep the same filename while extracting.
    Ultima modifica di Korgar; 03-11-12 alle 09:55
