Utente del mese: megthebest con ben 20 Thanks ricevuti nell'ultimo mese
Visualizzazione dei risultati da 1 a 10 su 30
[Kernel] Perseus e molto altro!!!
    Androidiano VIP L'avatar di pegliese93
    Liguria, Genova
    Ringraziato 671 volte in 442 Posts
    PERSEUS
    Ciao a tutti apro questo 3D per raggruppare tutte le guide, aggiornamenti e script e molto altro, per il Samsung Galaxy Note 2 LTE .
    In questo caso vi segnalo un ottimo kernel, il Perseus .
    Vi incollo parte della descrizione:
    Welcome to the Perseus kernel! I thought it would be a nice catchname considering the Galaxy/Universe/Pegasus themes.
    This is a direct port of my kernel on the Galaxy S3. I am using the same source base for both devices for the kernel, just with a different configuration file. The kernel images are not interoperable! I will continue development in parallel for both devices, with the Note 2 having maybe some delay due to third party testing.
    I'm trying to be more cutting-edge in terms of development in this kernel. In contrast to other kernels and philosophies of other developers, I don't believe giving the users more choice is a very smart thing to do. As such you won't find a dozen different governors or twenty different settings for this kernel. There is a optimal, or at least, most optimal setting on which the devices operate both in terms of performance and power management. For the average user this kernel will brings lots of benefits to battery life, screen improvement, fluidity and sound enhancements without having to set up any of the configurations.
    Advanced users are welcome to modify the scaling mechanisms of PegasusQ and I advise SetCPU 3 for this, most of the behaviour that one should configure is configurable via that application. CPU undervolting is compatible with most undervolting applications. For all other things, one should use scripts.
    Don't be scared by the alpha denomination of the kernel, I'm just taking the traditional naming scheme where alpha designates feature development, beta is feature-completeness, and final will actually be when I'll actively stop developing the kernel. The kernel is very stable, and any bugs are fixed in hotfix versions (alpha x.y)
    The kernel is also being maintained and released cross-device for the I9305 (S3 LTE), i9300 (S3) and N7105 (Note 2 LTE) and shares the same base-source. I solely own a I9300 Galaxy S3, but since all the phones derive from the same Midas platform, I merely adapt the differences without having the other devices.
    Ultima modifica di pegliese93; 05-04-13 alle 21:20
    Se ti sono stato d'aiuto un Thanks è sempre gradito
  2. I seguenti 3 Utenti hanno ringraziato pegliese93 per il post:
    battaglia (31-03-13),checco1926 (31-01-13),Picciotto (30-01-13)
    Liguria, Genova
    Avviso: Se volete leggere o scaricare le specifiche tecniche per ogni versione (CLICCA QUI)
    v36.3
    v36.1
    v35
    v34.2
    v33.4
    v33.3
    v33.1
    v32.1
    v31.2
    v30
    v29.1
    v29
    v28.2
    v28
    v27.5
    Ultima modifica di pegliese93; 07-05-13 alle 11:20
  5. I seguenti 3 Utenti hanno ringraziato pegliese93 per il post:
  6. #3
    Liguria, Genova
    Guida ai settaggi dei profili su STweaks:
    L'utilizzo dei profili di Stweaks è alternativo agli script, permettendo mediante l'utilizzo dell'applicazione STweaks Profiles di creare dei profili di configurazione, che gestiscano tutti gli aspetti configurabili sul kernel, mantenendo la possibilità di infiniti profili e di applicazione degli stessi in tempo reale, senza necessità di riavvio.
    I profili per essere visti dall'applicazione, vanno copiati nel percorso /data/.perseus/ che è il percorso in cui verranno salvati automaticamente nuovi backup/profili che verranno creati. Possono essere infiniti.
    La raccomandazione importante nell'utilizzo di Stweaks è che si vadano a variare parametri importanti come alimentazione di CPU/GPU e gestione del Governor, solo se si conosce esattamente quel che si fa. Altrimenti meglio chiedere piuttosto che fare danni.
    Questi di seguito sono i miei profili, quello che ritengo il più bilanciato è il NORMAL, gli altri sono più estremi, in un verso e nell'altro, a scopo più che altro "scolastico".
    Installazione/modifica profili:
    Immaginiamo di voler usare il profilo NORMAL. Scaricare il file e lo copiarlo nel percorso indicato. Aprire l'applicazione Stweaks Profiles e andare nella scheda RESTORE. Vedremo l'elenco dei profili presenti. Selezionare NORMAL e attivarlo.
    Quando è finita l'attivazione, andare nella parte BACKUP e crearne uno con il proprio nome o con un nome di riferimento che indichi le modifiche che andremo a fare (ad es. AUDIO). In questo modo il profilo di partenza resterà intatto, e si potrà facilmente tornare indietro in caso di modifiche "sbagliate". Per esempio se si modifica la parte screen facendo esperimenti, e poi non ci si ricorda più come era impostato in partenza, sarà sufficiente fare nuovamente il restore di Normal.
    Male che vada sarà sufficiente ricopiare il file originale, sostituendo quello presente. L'importante è capire che le modifiche vengono salvate automaticamente nel profilo attivo in quel momento. Se attivo NORMAL e poi vado su STweaks e vario un parametro, da quel momento NORMAL resterà con quel parametro modificato.
    E' possibile anche rinominare i vari profili, però consiglio di farlo sui profili NON attivi. Quindi se voglio rinominare NORMAL in PIPPO, ed in questo momento è attivo, attivare BATTERY e poi rinominare NORMAL.
    Da notare che l'ultimo kernel ha integrato una modifica alla calibrazione dei colori dello schermo, molto professionale, che è attiva in tutti e 3 i miei profili. Pertanto caricando i profili, all'inizio, abituati ai colori stock, potrà sembrare che i nuovi colori siano "sbiaditi", ma non è così, sono solo più reali e non così saturi e "sparati" come gli originali a cui siamo abituati. Ci vorrà solo un pò di tempo per abituare la vista alla nuova visione.
    Se comunque si preferisce ripristinare i normali colori Samsung, è sufficiente andare nella voce "SCREEN" e togliere le prime 2 spunte.
    Raccolta profili:
    BATTERY: Profilo votato all'utilizzo di frequenze più basse possibili. Possibili lag a seconda dell'applicazione in uso.
    NORMAL: Ottimo compromesso prestazioni/consumi, nessun lag.
    PERFORMANCE: Profilo estremo per salita ultrarapida delle frequenze e dei core. Da usare solo se non importa nulla dell'autonomia.
    Guida all'inserimento degli script:
    1. Riavviamo in recovery e flashamo il kernel (install zip from sdcard/external sdcard)
    2. Flashamo lo script (install zip from sdcard/external sdcard)
    3. Riavviamo il dispositivo (reboot system now)
    Raccolta script:
    Avviso: Per togliere lo script: CLICCA QUI
    01/04:
    - Script ottimizzato per la v34.2:
    30
    /03:
    - Script ottimizzato per la v33.4:
    02/03:
    - Script ottimizzato per la v33.3:
    24/02:
    - Script ottimizzato per la v32.1:
    Immagini allegate
    Ultima modifica di pegliese93; 05-04-13 alle 21:17
  7. Il seguente Utente ha ringraziato pegliese93 per il post:
  8. #4
    Liguria, Genova
    Deep Sleep Battery Saver:
    Battery Saver mette costantemente il dispositivo in modalità "sonno profondo".
    Durante la modalità di sonno profondo, Wifi e 3G sono spenti, le applicazioni in background sono ferme. Di conseguenza, la maggior parte delle applicazioni non funzionano, tra cui Facebook, Google... E poi si "risveglia" costantemente in modo da scaricare la posta elettronica, sincronizzazione status su Facebook... In modalità avanzata (PRO), è possibile personalizzare più parametri, tra cui le impostazioni giorno/notte, periodo di attivazione, timeout schermo, sincronizzazione...
    eMMC Brickbug Check:
    eMMC Brickbug Check è un'app fondamentale per verificare il chip del nostro dispositivo.
    Controllate nell'app che non siano presenti i seguenti valori altrimenti potreste essere soggetti a una morte improvvisa:
    Type: VTU00M
    FwRev: 0xf1
    Avviso:
    Se il chip del nostro dispositivo risulta soggetto a una probabile SDS (sudden death syndrome) vi consiglio di tutelarvi, installando il Perseus v31.2, recovery Philz Touch 3 e seguendo il 3D apposito per tutti i chiarimenti e aiuti possibili (CLICCA QUI).
    Galaxy Charging Current:
    Galaxy Charging Current è un'app molto utile segnalata dal confratello Linuxx , per chi riscontrasse problemi nella lunga durata di carica del nostro dispositivo, dovuto al malfunzionamento del caricatore o alla qualità (non ufficiale).
    Ci basterà quindi installare l'apk e collegare il dispositivo al caricatore e vedere che valori ottenete in current_avg e current_max.
    PhilZ Touch 4:
    Se siete interessati a una recovery avanzata, questa è quella che fa per voi . Inoltre è consigliata per azzerare le probabilità di morte improvvisa del nostro Note 2 dovuta al chip maledetto!
    Ultima modifica di pegliese93; 07-05-13 alle 11:22
  9. #5
    Liguria, Genova
    riservato!!!!
    Ultima modifica di pegliese93; 31-01-13 alle 00:13
  10. #6
    Androidiani Power User L'avatar di Picciotto
    vBulletin
    Nexus 5 P9+ P10+
    Ringraziato 3,631 volte in 1,957 Posts
    Ottimo fratello incominciamo a far popolare questa sezione
  11. #7
    Liguria, Genova
    Quote Originariamente inviato da Picciotto Visualizza il messaggio
    Ottimo gratello incominciamo a far popolare questa sezione
    Grazie fratello! si esatto tanto molte cose sono simili...aspetto che si sistemi completamente il modifica messaggio così inserisco tutto
    Ultima modifica di pegliese93; 11-02-13 alle 14:43
  12. #8
    Note 3
    ragazzi mi spiegate come si cambia il kernel e quale mi conviene flashare per diminuire i consumi della batteria??? grazie =D
  13. #9
    Liguria, Genova
    Quote Originariamente inviato da onimusha90 Visualizza il messaggio
    Basta che scarichi la v32.1 e la installi in recovery vedi come ti trovi a consumi ed eventualmente ci scarichi anche gli ultimi script del 17/02
  14. #10
    i link delle app non funzionano!!!
