[ROM][4.4.2]Ultimate Rom SM-N9005 NE4 v1 [OTA][Fast, Stable, Battery Friendly]ONLINE
    Androidiano L'avatar di joosh3
    Ringraziato 253 volte in 130 Posts
    Ciao a tutti!
    La Ultimate Rom è finalmente disponibile per il Galaxy Note 3.
    Con più di 500.000 downloads, in aumento, la Ultimate Rom dell'ormai vecchio GT-N7000, arriva finalmente su Galaxy Note SM-N9005 pronta per essere scaricata e installata, con tante features incluse.
    NOTA: Scusatemi se il resto del post è in inglese, ma ho avuto poco tempo per tradurre il tutto
    Più in avanti pubblicherò pure una pagina sul blog italiano. Per adesso è soltanto presente in quello internazionale.
    Homepage Ufficiale
    XDA Thread
    Se ti piace il mio lavoro e la Rom, offrimi una birra o un caffe!
    Download Links:
    Sourceforge Mirror - Ultimate Rom NE4 v1 - DL
    Controllate sempre l'MD5 prima di installare:
    bc226e1a5e4d45a59c7a4fd167c1dc8f
    ScreenShots
    Features:
    • ROM based on the official N9005DXUENE4 firmware
    • Deodexed: system/priv-app, system/app and system/framework
    • Zipaligned
    • Pre-Rooted ROM with SuperSu
    • Busybox Installed
    • init.d Support
    • Knox has been totally removed
    • Modded SystemUI compatible with OGBattery Mod
    • Modded and soft themed SecSettings
    • S5 Optional Conversion during installation process
    • S5 Bootanimation and Sounds
    • Ultimate Rom Tools inside Settings
    • build.prop Tweaks
    • Possibility to switch from normal settings to grid S5 look settings directly inside the SecSettings application
    • 9 Themes pre-installed
    • 3 Different kernels to choose during installation
    • PullUp App
    • Good battery life
    • Aroma Installer included to customize everything during the installation process
    • and more...
    More features listed below
    INSTRUCTION: HOW TO FLASH:
    It's really easy,
    If you're not rooted, of course you need to root your device. Keep in mind that rooting your device will void your warranty.
    Root with CF-AutoRoot HLTE-HLTEXX for N9005
    Install custom recovery, I recommend the latest CWM from Philz
    Reboot into recovery and perform wipes
    Format /system /data and /cache
    Clear /dalvik-cache and cache
    Now you're ready to flash
    Install zip from SD Card
    Follow Aroma Installer Steps
    Choose whatever you want to install
    Once the installation process is started, it can take from 2 up to 5 minutes
    Let the device reboot and it's ready to be used!
    IS HIGHLY RECOMMENDED TO ENABLE XPOSED FRAMEWORK ONCE THE PHONE IS READY FOR USE. IT REQUIRES A REBOOT.
    ALSO, IF YOU INSTALLED THE S5 CONVERSION DURING THE INSTALLATION, ACTIVATE THE S5 SYSTEMUI THEME ON XPOSED FRAMEWORK TO HAVE FULLY S5 LOOK EXPERIENCE. ALSO THIS REBOOT TO TAKE EFFECT.
    WARNING:
    Everyone who will like to support my work with a little donation, please, do not use the UPDATEME app to do it, but do it through the DonateMe button on XDA, on this page or in the Ultimate Rom Tools app.
    Thanks!
    Aroma features:
    With Aroma Installer you can totally customize your installation. Possibility to choose Full to Slim Installation.
    General Apps, Samsung Apps and Google Apps splitted in 3 different groups
    Applications:
    • AlarmWidget
    • DigitalClock
    • Dropbox
    • EasyFavoritesContactWidget
    • Flipboard
    • InteractiveTutorial
    • LiveWallpapers
    • MobilePrint
    • MusicLiveShare
    • TalkBack
    • YahooWidget
    SamsungApps:
    • AllShare
    • PolarisViewer
    • SamsungHub
    • SamsungWatchON
    • SamsungWidget_ActiveApplication
    • StoryAlbum
    GoogleApps:
    • Books
    • Chrome
    • GMail
    • GoogleDrive
    • GooglePlus
    • Hangouts
    • Magazines
    • Maps
    • Music
    • PlayGames
    • Videos
    • YouTube
    ADDITIONAL APPS:
    CSC:
    • BTU
    • DBT
    • ITV
    • XEF
    • XEO
    • More will be added soon...
    Kernel:
    • AbyssKK 1.7.1
    • Aurora R11v2
    • Stock NE4 Kernel
    SAMSUNG S5 CONVERSION:
    During the installation process you can choose to convert the full framework-res and some additional apps to the S5 look.
    If you don't like how it looks, is always possible to revert it back just downloading the BackToStock.zip package from OTA, flash it and everything will return with a stock look.
    MailClient
    • Note 3 Stock Mail Client
    • S5 Mail Client
    MeteoWidgets
    • Note 3 Stock Meteo Widget
    • S5 Meteo Widget
    Pinboard
    • Note 3 Stock Pinboard
    • S5 Pinboard
    SBrowser
    • Note 3 Stock SBrowser
    • S5 SBrowser
    SecMms
    • Note 3 Stock SecMms
    • S5 SecMMs
    SecMyFiles
    • Note 3 Stock SecMyFiles
    • S5 SecMyFiles
    SFinder
    • Note 3 Stock SFinder
    • S5 SFinder
    SHealth
    • Note 3 Stock SHealth
    • S5 SHealth
    SNote
    • Note 3 Stock SNote
    • S5 SNote
    Splanner
    • Note 3 Stock SPlanner
    • S5 SPlanner
    SVoice
    • Note 3 Stock SVoice
    • S5 SVoice
    TouchwizLaunchers
    • Note 3 Stock TW Launcher
    • Note 3 Modded 5x4 TW Launcher
    • S5 Modded 5x4 TW Launcher with fully working PullUp, Headlines (MagazineHome), ThemeChooser etc...
    Ultimate Rom Tools Features:
    Inside the custom settings application you can find:
    Xposed Framework with the following pre-installed modules:
    • Screen Off Animation (you can choose different animation when the screen goes off or when turn on)
    • Wanam Xposed (a lot of features can be enabled with this module, such as 4 Way Reboot, Call Recording and much more)
    • S5 SystemUI Theme (with this you can enable the S5 SystemUI theme for quick settings and recent apps without any modification to build.prop) I HIGHLY RECOMMEND TO ENABLE IT IF YOU USE S5 CONVERTER DURING THE INSTALLATION.
    • GravityBox (another nice tool to fully customize your device)
    • AppSettings (with this tool you can choose DPI for every app)
    • Xposed Wanam Torch (enable the torchlight)
    • more to be added...
    OTA Updates:
    Every new mod, update and more will be added inside this app to be downloaded and flashed via recovery
    OG Battery Style Mod:
    With this tool you can customize the battery icon. The SystemUI has been modified to properly work
    Zip Installer:
    Tool to easily select .zip files and flash them in a second through recovery
    Pen Window Manager:
    Choose custom apps for pen window
    Multi Window Manager:
    Choose custom apps for multiwindow
    Change DPI:
    Change the Rom DPI
    Adaway:
    Block Ads if they annoy you
    LED Manager:
    Manage the LED colors
    App Ops:
    Control App Permissions
    and more to be added...
    CREDITS:
    Samsung for the firmware
    rovo89 and Tungstwenty for Xposed Framework
    Wanam for his modules for Xposed Framework and penwindowmanager-multiwindowmanager apps
    xperiacle for his modules for Xposed Framework
    ficeto for his useful and customizable CustomSettings app
    firasusman for S5 conversion icons
    OsamaGhareeb for OG Battery Mod app
    Chainfire for SuperSu
    MojosManagement for Aurora Kernel
    Beerbong for zip installer utility
    C3C076 for GravityBox Xposed Module
    zst123 for ScreenOffAnimation Xposed Module
    FakeJap for Pullup
    aquariusoft for updateme app
    ksr007 for themes collection
    amarullz for Aroma Installer
    and the amazing XDA Community...
    If I forgot someone, first of all I'm sorry, and then just pm me, I'll be glad to add you in the credit list!
    If you like my work, you can offer me a beer or a coffee to keep me awake!
    Thanks
    Official Homepage
    Ultima modifica di joosh3; 26-06-14 alle 11:34
  2. I seguenti 5 Utenti hanno ringraziato joosh3 per il post:
    edino (27-06-14),guidoiann (26-06-14),iscio (25-06-14),japoco_poz14 (25-06-14),mescal67 (25-06-14)
    Provata ieri e subito tolta.. continuano a bloccaesi le applicazioni ...l'ho flashata ben 3 volte seguendo tutto alla lettera..xo niente da fare..peccato sul mio note 2 andava benissimo
    pensavo di averla ritrovata....:-(
  5. #3
    Ringraziato 51 volte in 39 Posts
    Quote Originariamente inviato da edino Visualizza il messaggio
    Il problema è noto. Verrà rilasciato a breve o il Fix o la rom corretta.
  6. Il seguente Utente ha ringraziato HI-NRG per il post:
    edino (27-06-14)
  7. #4
    Riscaricatela ora, la rom è stata corretta.
  8. Il seguente Utente ha ringraziato HI-NRG per il post:
    edino (27-06-14)
  9. #5
    Versione sistemata disponibile per il download.
    Scusate per il piccolo bug del play store, ormai era già stata caricata e pubblicata e non sembrava ci fossero problemi.
  10. I seguenti 4 Utenti hanno ringraziato joosh3 per il post:
    edino (27-06-14),guidoiann (26-06-14),japoco_poz14 (29-06-14),mescal67 (26-06-14)
  11. #6
    Installata oggi la versione Fixata. Tutto ok e senza FC. L'unica cosa che ho notato sono le impostazioni del Widget Meteo completamente bianche su sfondo bianco (e quindi quasi illeggibili).
    Chiedo inoltre se c'è un modo per avere il widget Samsung Hub in formato 5x4 (anziché' 4x4) ed anche le colonne di applicazioni nella home in formato standard (attualmente sono mi sembra 6x4) e quindi più piccole.
    La rom è veramente valida ed ha tutto quello che cercavo. La testo un paio di giorni per vedere la durata della batteria.
    Grazie al cuoco joosh3.
  12. #7
    Installato nuova versione ...tutto ok
    Tranne gps..devo settare qualcosa..
    Grazie x le eventuali risposte..ci tengo a tenere questa rom...:-)
