Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 38
[ROM][4.4.2][HLTE] [LINARO] Resurrection Remix® 4.4.2 KitKat v5.0.9 [04/15/14]
    Sulla Resurrection Remix ROM ®
    Resurrection Remix è la ROM basata su AOKP, CM, PA, Omni, tutto ciò fa si che si abbia un concentrato di potenza,perfomarce, e molto altro sul tuo telefono!
    MOD già incluse nella ROM! Enjoy!
    Resurrection Remix
    Special thanks to the AOKP team ParanoidAndroid team, the CM team, OMNI team and of course to all the supporters.
    FUNZIONI INCLUSE :
    codice:
    OPTIMIZATIONS
    * Linaro 4.8.3 Toolchain Loaded On ROM & Linaro 4.7.4 Kernel
    * -O3 (highest GCC optimization level)
    * Memory optimization
    Halo
    Active display
    Lockscreen Notifications
    Application side bar
    Omniswitch
    Notification panel tweaks
    Tiles style
    Music Toggle
    Pitch Black UI Mode
    Camera mods
    ListView Animations
    Custom system animations
    Custom progress bar
    Screen recorder
    Hardware buttons and navbar options
    Status bar traffic monitor
    Battery bar options
    CRT animations
    SB Brightness slider
    Expanded desktop
    Profiles
    Performance controller
    Flip tiles
    Theme chooser
    Keyboard features
    Lockscreen see blur and reduce slider
    Show Wi-Fi name
    Headset action
    Low battery warning
    Lock clock widget
    Privacy guard
    Permission management
    Power sounds
    Share ROM
    Battery mods
    Changelog
    Lockscreen options and targets
    Center Clock/No clock/Right Clock
    AM/PM,date and colors
    New Wallpaper app
    Nova/Stock launcher included
    AND MORE...
    ISTRUZIONI SULL'INSTALLAZIONE :
    codice:
    1.- Wipe data / factory reset
    2.- Installate la ROM tramite CWM
    3.- Installate le gapps
    4.- Poi andate su Advanced
    5.- Wipe Dalvik Cache
    6.- Wipe Cache Partition
    7.- Reboot
    DOWNLOAD :
    ROM DOWNLOAD QUI:
    Dev-Host - The Ultimate Free File Hosting / File Sharing Service
    Gapps RR-KK
    LEAN KERNERL (CONSIGLIATO PER USARE LA ROM AL 100%)
    imoseyon Downloads For hlte-aosp @ AndroXfer.in
    ECCO QUALCHE SCREEN DELLA ROM (GRAFICA DIVINA)
    LA STO USANDO E VA' UNA SCHEGGIA! ED E' TROPPO BELLA GRAFICAMENTE.. CONSIGLIATA AL 100%
  2. I seguenti 2 Utenti hanno ringraziato BraKoS per il post:
    japoco_poz14 (19-04-14),luchino71 (18-04-14)
    Androidiano VIP L'avatar di Fuoritempo
    Verona
    (s2,s3,s4,Note 3) S7 Edge.
    Ringraziato 769 volte in 579 Posts
    Buona segnalazione, purtroppo come con tutte le non samsung-based ti giochi la s-pen e relative applicazioni.... Per me è una limitazione troppo pesante.
    NOTE 3: Phronesis Rom Note 5 port v.6.1 LP 5.1.1
  5. Il seguente Utente ha ringraziato Fuoritempo per il post:
    eL145 (22-04-14)
  6. #3
    Io la penna non la usavo mai quindi... con questa rom ho solo un problema e che l'audio delle casse con la musica mentre tipo faccio altro oltre a sentire musica fa una specie di interferenza come quando entri in galleria con la macchina e la radio non si sente.. invece se ascolto musica senza premere niente va tutto bene.. secondo me è per il kernel
  7. #4
    Ringraziato 70 volte in 63 Posts
    So che si parlava di interferenze audio da qualche parte, e ricorso che molti utenti che avevano questo problema hanno risolto usando LeanKernel 2.3.
    Cmq nemmeno io uso la penna moltissimo, quindi perdere le funzioni dedicate mi dispiacerebbe ma non mi ucciderebbe. Il problema è che non so ancora quanto stabili siano queste rom. Dopotutto tutte le basi sono ancora in fase nightly/beta.
  8. #5
    Verona
    Mah.... potrebbe essere...
  9. #6
    Quote Originariamente inviato da asusgarb Visualizza il messaggio
    Guarda io la sto usando da 2-3 giorni la grafica è davvero bellissima, il nero con il rosso ci sta una bomba, la lockscreen è spettacolare.. con l'effetto blur.. la velocità è ottima, io ho solo il problema dell'audio che non so come risolvere, e infatti ora che ci penso si è verificato dopo l'installazione del Lean.. ma io ho già montato la 2.3 magari dovrei riflesharlo?
  10. #7
    Androidiano VIP L'avatar di luchino71
    Dec 2009
    Pesaro Urbino
    Ora G4 poi boo,
    Ringraziato 814 volte in 547 Posts
    Bel lavoro...
    Se posso darei 2 consigli per le Rom AOSP:
    Quando passiamo ad una rom su base Samsung dopo aver installato una AOSP con alcune applicazioni si potrebbero avere problemi ed FC e quindi usare questo fix:
    [GUIDE] Internal sdcard not writable? Fix.. - xda-developers
    Le AOSP consumano un pò di più rispetto alle Samsung e qui ci sono alcuni settaggi per il kernel per migliorare la durata della batteria e la stabilità:
    Kernel Settings - Beanstalk rom
  11. Il seguente Utente ha ringraziato luchino71 per il post:
    japoco_poz14 (22-04-14)
  12. #8
    Grazie @luchino41
    Se qualcuno installa questa rom resurrection mi fa sapere se ha problemi con l'audio? Perchè in giro li ho solo io e non capisco perchè, ho testato 4 kernel con tutti e quattro il problema audio persiste quindi mi sà che è la rom, però nessuno ha avuto questo problema mio.. e non capisco cosa può essere
  13. #9
    Ringraziato 196 volte in 170 Posts
    Qualcuno mi consiglia un buon kernel per questa ROM ..problemi di audio non ne ho per niente
  14. #10
    Androidiano VIP L'avatar di japoco_poz14
    p500,Htc Evo3d, Note 2, Note 3
    Ringraziato 1,028 volte in 447 Posts
    Penso che il migliore sia il lean per aosp. Provalo e dimmi come va
    Il mio C.V.
    Tester:
    - Audax rom
    - FoxHounh team
    - Blumark
    - Abyss kernel
    - R2D2 Droid
    Editore per Batista70 phone
