[ROM][LP][5.1.1r10] CyanogenModX [AOSP]
    Moderatore L'avatar di 8thphloor
    ONEPLUS2, NOTE2, NEXUS 7 2013
    Ringraziato 2,944 volte in 1,616 Posts
    codice:
     * Your warranty is now void.
     * I am not responsible for bricked devices, dead SD cards, thermonuclear war,
     * or you getting fired because the alarm app failed. Please do some research
     * if you have any concerns about features included in this ROM before flashing!
     * YOU are choosing to make these modifications, and if you point the finger
     * at me for messing up your device, I will laugh at you.
    LaCyanogenModX si pone a metà strada tra la CyanogenMod "pura" e ROM molto più ricche di features (e quindi più pesanti e più soggette a bug) come ad esempio la Resurrection Remix.
    Il codice sorgente è sviluppato in modo autonomo dal dev UtkarshGupta mettendo insieme le migliori caratteristiche di Cyanogenmod e NamelessRom.
    Come tutte le lollipop aosp based è molto reattiva, graficamente curata e personalizzabile, e si porta per ora dietro i classici bug di cm12.1.
    Downloads
    ROM
    TWRP
    GApps
    SuperSU
    How to install
    Install TWRP
    Install ROM
    Install GApps
    Install SuperSU
    Install Custom Kernel (Not recommended Optional step)
    How to update
    Install ROM
    How to request features
    Requests about features or tweaks from OEM firmwares and Android M Preview will be ignored
    Goto XDA DevDB Feature Requests section
    Request feature giving clear description of the functionality or examples of where else you've seen it
    How to report bugs
    Make sure you can reproduce the bug on a clean flash without any mods, custom kernel or xposed framework
    Goto XDA DevDB Bug Reports section
    Report bug giving clear steps to replicate it, the expected result and the actual result
    XDA:DevDB Information
    CyanogenModX, ROM for the Samsung Galaxy Note II
    Contributors
    UtkarshGupta, CyanogenMod Team, NamelessROM Team
    Source Code: github.com/UtkarshGupta
    ROM OS Version: 5.1.x Lollipop
    ROM Kernel: Linux 3.0.x
    ROM Firmware Required: GT-N7100
    Based On: CyanogenMod12.1
    Version Information
    Status: Stable
    Current Stable Version: June16
    Stable Release Date: 2015-06-16
    Created 2014-05-21
    Last Updated 2015-06-16
    Ultima modifica di 8thphloor; 17-06-15 alle 01:59
    The answer to the ultimate question of life, the universe and everything is:
    CLEAN FLASH
  2. Il seguente Utente ha ringraziato 8thphloor per il post:
    NiloGlock (17-06-15)
    Changes over NamelessRom-2.1:
    [HIDE]
    * Fixed WiFi battery drain
    * Fixed music playback from external sdcard
    * Disabled HW key illumination on screen touch
    * Ability to disable HW key illumination
    * Ability to disable HW keys & use navbar
    * Disabled touchboost
    * Disabled ondemand governor
    * Disabled userspace governor
    * Enabled conservative governor
    * Enabled interactive governor
    * Enabled vibrator intensity setting
    * Increased LED brightness
    * Fixed Netflix
    * Performance profiles
    * Battery percent in device off charging mode
    * Enabled 802.1x EAP
    [/HIDE]
    Changes over CyanogenMod-12.1:
    [HIDE]
    * Removed: AOSP Live wallpapers (Bloat)
    * Removed: CM Wallpapers (Bloat)
    * Removed: CM Bug report (N/A)
    * Removed: CM Updater (N/A)
    * Removed: Visualizer tile (Temporarily)
    * Ability to use custom system partition size
    * Optimized APKs to reduce size
    * Black statusbar/navbar in battery saver mode
    * Performance profile tile: Delay profile change to avoid lags
    * Cellular tile: Convert to main tile
    * Cellular tile detail: Network mode toggle
    * Battery light: 100% charged level
    * Smart pulldown
    * QS: Allow 4 tiles per row
    * Status bar date
    * Network traffic monitor
    * Upgraded keyguard visualizer
    * Enabled restricted profiles
    * Integrated SuperSU into settings
    * Eleven: Sort adjustments
    * Eleven: Visualizer tweaks
    [/HIDE]
    Known issues:
    [HIDE]
    * Face unlock doesn't work (Common AOSP Issue)
    * Back camera in Instagram doesn't work (Common AOSP Issue)
    * Bluetooth calling with some car kits doesn't work (Common AOSP Issue)
    [/HIDE]
    To increase wallpaper quality:
    [HIDE]
    * Wallpaper must be 720x1280 (or lower) and must be in jpg format
    * Copy & rename wallpaper to /sdcard/Wallpaper.jpg
    * Reboot (everytime you change the wallpaper)
    * FYI, this works around android compression of the wallpaper
    [/HIDE]
    To increase album art quality:
    [HIDE]
    * Resize album art to 480x480 (you may use this utility)
    * Delete /sdcard/Android/data/albumthumbs
    * Delete media player album art cache
    * FYI, this prevents android compression of the album art
    [/HIDE]
    Ultima modifica di 8thphloor; 03-08-15 alle 01:19
    CLEAN FLASH
  5. #3
    Ultima modifica di 8thphloor; 03-08-15 alle 01:17
    CLEAN FLASH
  6. #4
    Mar 2015
    Funziona con la Philz??
  7. #5
    Sassari
    LG G2, LeMax 2
    Sembrerebbe un mashup tra CM 12.1 e Nameless, su XDA ho letto molti pareri positivi... Da provare senz'altro
    Smartphone:
  8. #6
    ..dopo un paio di giorni di test posso affermare che questa rom, perlomeno con la mia padella, va particolarmente d'accordo.
    la reattività è ottima e molti dei bug che presentano altre ROM simili non ci sono.
    sono presenti inoltre alcune comode features non disponibili sulla cm "pura" (personalizzazione status bar, pulsanti fisici, network indicator,..).
    il consumo batteria è simile a cm. di default la frequenza massima viene tagliata a 1200 (profilo bilanciato in impostazioni batteria) e il consumo è davvero esiguo. ma per i miei gusti meglio ripristinare il classico 1600.
    Sicuramente per chi è abituato come me alle innumerevoli features di RR qui qualcosa manca..ma è un'ottima (e al momento più stabile) alternativa tra le aosp lollipop, sicuramente da provare almeno una volta
    CLEAN FLASH
  9. Il seguente Utente ha ringraziato 8thphloor per il post:
    NiloGlock (28-07-15)
  10. #7
    EVA01
    Ciao @8thphloor,volevo comunicarti che ci sono stati vari aggiornamenti della rom e l'ultimo risale al 24 Luglio.
  11. #8
    Quote Originariamente inviato da EVA01 Visualizza il messaggio
    prima (e unica) pagina aggiornata
    CLEAN FLASH
