Utente del mese: megthebest con ben 44 Thanks ricevuti nell'ultimo mese
Pagina 1 di 6 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 58
(Rom) CriskeloRomNOTE
    Apr 2010
    Droidland
    Arrow
    La firma di Criskelo approda anche su note con questo lavoro basato su XXLA3 - CallRec -Jkay Mod-14Toggles-THEME ICS
    *[Kernel] SpeedMod N7000 [K1-1 TEST CWM4 RAÍZ CIFS]
    * Mpdem XXLA3
    *Busybox
    *Zipaling
    *Rooted
    * Recording function calls (if you want to record a call you press the rec button on Phone) Note: The files are saved in SD-Card/soundo
    * Mod to accelerate processes and system apps By nikademus
    * Roletube (downloads youtube video sdesde SD-Crd/downloads)
    * MOD Jkay
    Note: If you want to test the mod Jkay, do not install this ROM and install the original Mod Jkay and testing to prevent errors and problems
    * Disable overscroll effect toggle
    * Support for setting Auto brightness delay. Select between values: No delay, 0.5 seconds, 1 second and 2 seconds.
    * Support for Auto brightness profiles
    * backup and restore all settings
    * Volume Lock (on/off toggle: a deluxe setting that will make sure notification volume is the same as ringer volume).
    * Added Home button haptic feedback on/off toggle
    * Added 'No lock screen' option as lock screen selection.
    * A toggle for CRT TV on effect (bypassing Animation setting!)
    * A toggle for CRT TV off effect (bypassing Animation setting!)
    * Support for Skipping music track/fm radio station using vol-up/down-keys when screen is off (as a toggle)
    * 15 seconds timeout on lockscreen... (as a toggle)
    * Confirm shutdown on/off toggle (asks for confirmation when using Reboot, Recovery, Download and Power off)
    * Support for disabling Home button double click
    * Supports customizable Power Options Dialog (all the toggles from SGS2 and can also be reordered)
    • Wallpapers high quality custom CriskeloGallery
    • And many more that do not remember now
    DOWNLOAD V2
    LINK
    Consigliato il flash su base LA3 senza wipe
    Tema KALAGAS per questa rom
    LINK
    Ultima modifica di thay; 17-01-12 alle 15:15
    Riserva Navajo
    mi piaci quando posti le rom
    lool
    p.s. criskelo ha sempre fatto ottimi lavori...molto colorati...ne sarà felice Skyman....
    Apr 2010
    Droidland
    Quote Originariamente inviato da Andromeda1968 Visualizza il messaggio
    lool
    Si vero un giretto qui si puo' fare tanto per dare un po di novita al solito stock ..in attesa di ICS stabile poi criskelo e veramente bravo ad integrare le features piu' in del momento
    Androidiano VIP L'avatar di nexus76
    Mar 2010
    l'ho flashata su base LA3 stock senza wipe e ora mi va in bootloops..suggerimenti?
    Androidiano VIP L'avatar di ITAIce
    Feb 2011
    Monza & Brianza
    Galaxy Note 3, Galaxy Tab 10.1
    Ringraziato 257 volte in 239 Posts
    Quote Originariamente inviato da nexus76 Visualizza il messaggio
    Deep Clean e riflash...
    Mar 2010
    ho fatto tutti i wipes e riflashata. continua ad andare in bootloops..non la digerisce proprio sta rom..
    E' il mio primo post, approfitto per salutarvi e dirvi come ho fatto:
    anche a me andava in loop. Reinstallate una romo diversa e poi mettete questa SENZA FARE ALCUN WIPE. Così va!!!
  9. #8
    Apr 2010
    Droidland
    E scritto in 1 pagina NO WIPE per flashare questa rom .Potete fare un wipe dalvik e cache ma non un wipe data
  10. #9
    Jan 2011
    funziona il market?
  11. #10
    Androidiano VIP L'avatar di Osarco94
    HTC ONE m7 ,HTC Wildfire
    Ringraziato 163 volte in 138 Posts
    mmm...penso che la provo..anche se devo dire che con l'ultima rocet mi sto trovando da favola...quacuno ha già impressioni da sfornare?
    In custodia
    HTC Wildfire
    rooted with Cyanogen 9
LinkBacks (?)
