Utente del giorno:megthebest con ben 1 Thanks ricevuti nelle ultime 24 ore Utente della settimana:megthebest con ben 8 Thanks ricevuti negli ultimi sette giorni Utente del mese:bluemask con ben 32 Thanks ricevuti nell'ultimo mese
enabled SNote / Premium Suite running!!!! ==> download SNote from here and install as Data App (as you also do on any TW-ROM) or use any other SNote app you already stored on you PC or SD-Card: Snote_Q1.apk
issues fixed coming with every MIUI stock version:
NetworkLocation fully working
no more Forceclosing in Settings - About phone - Status
added full list of APNs
Fix WIFI for 5 Ghz
there is an issue with build in Hydracore 5.1 - kernel (VideoRecording not working). So please flash HC 3.5 or HC 4.3b after instaling the ROM and everything will work fine again!!! Download flashable zips from here: Download Link
enabled SNote / Premium Suite running!!!! ==> download SNote from here and install as Data App (as you also do on any TW-ROM) or use any other SNote app you already stored on you PC or SD-Card: Download Link
Fix WIFI for 5 Ghz
based on unofficial MIUI 2.10.12
zipaligned
Kernel Hydracore 5.1 (thanks gavin) --> this kernel comes with Stock MIUI now!
enabled SNote / Premium Suite running!!!!--->download SNote from here and install as Data App (as you also do on any TW-ROM) or use any other SNote app you already stored on you PC or SD-Card: Snote_Q1.apk
Several enhancements for speed and RAM-Usage ...you'll feel the difference
N.B. per chi proviene da altre Rom, dovrā flashare prima una versione precedente ovviamente previo i 3 wipe di rito...
mentre per chi usa la v3 puō fare i semplici wipe cache e dalvik, e flash della v4...
Metodo di installazione...Da qualsiasi Rom si proviene..Anche se da MIUI Rom
Scaricare un kernel Hydracore qualsiasi, "Sempre meglio l'ultima versione"..da QUI
Copiare lo zip della ROM + zip del KERNEL in memoria interna e riavviare in Recovery..
Flashare il kernel hydracore e riavviare in recovery dalla voce ADVANCE..
Full WIPE: wipe cache + wipe dalvik + wipe data/factory...
Flash della ROM.. e Riavviate...
Buon divertimento con la RocketMIUI...
N.B. Se state usando la RocketMIUI, vi basterā copiare lo zip della rom/Update nel telefono, riavviare in recovery,
wipe cache + wipe dalvik - e flash della Rom.
Ciao..."diavolo tentatore" volevo chiederti se funziona tutto... magari un'affacciatina la faccio, previo backup della V.9, male che vā...
Poi detto da te che č un'ottima rom mi fido, mi hai convinto. Non credo di provarla oggi perchč ho da fare, l'ho scaricata....inoltre il fix gps vā installato sulla v.2 o č solo per la v.1? Ciao e grazie!!!!
Io ho sempre avuto la miui con s2, una delle migliori rom in circolazione.... peccato che questa abbia alcuni bug non essendo ancora una versione ufficiale.
Se ti sono stato utile, ringraziami premendo sul tasto THANKS !!!!!
Davvero una bellissima rom, penso che la terrō su per molto molto tempo...
Pensa che sto ancora configurando tutto..
Tantissime cose nuove, ed un'eleganza da paura...
Il fix nella v2 non serve.
