Utente del mese: megthebest con ben 42 Thanks ricevuti nell'ultimo mese
Pagina 1 di 2 12 ultimoultimo
[KERNEL] [3.0.70] [4.2.2 - CM/PA/AOKP] DH-Kernel v1.8 [28/03] [LINARO Kernel is here]
    Androidiano VIP L'avatar di AlienwareAR
    Pavia & Milano
    Honor 8 Pro
    Ringraziato 337 volte in 303 Posts
    Exclamation
    Ciao.
    Apro questo nuovo thread perché vorrei segnalarvi il nuovo kernel Dragon Heart..!
    Ecco qui tutte le info direttamente dal thread ufficiale XDA..
    Welcome Folks,
    First of all this is a safe and enhanced CM Kernel named DH a.k.a. DragonHeart Kernel and will work only on AOSP based ROMs. No touchwiz (for now?).
    Features over CM-Kernel:
    Kernel version updated to 3.0.70 from 3.0.31
    Linaro Kernel (Much better performance, search on XDA to know more)
    Governors included: HYPER (default), Lulzactiveq, Pegausq, SmartAssv2, Zzmoove, Adaptive, Conservative, Interactive, Ondemand, Userspace, Powersave, Hotplug, LagFree
    I/O Schedulers included: BFQ, CFQ, NOOP, DeadLine, ROW(default), SIO, VR, ZEN, FIFO
    Overclocked to 1.6GHz (1.4 GHz default, overclocking is optional).
    Fully customized RAM-DISK to inherit more optimization
    LMK using upgraded code. Auto detect parameters.
    Frequency adjustable under Performace Control or any relative app.
    Battery friendly. Less wakelocks.
    Mdnie improvements. More sharpness. Black crush fix.
    Init.d script tweaks: Smart & Fast Zipalign, Database compaction and optimization, USB Mass Storage enabled
    No depletion of entropy pool - Increases performance of app loading.
    ZRam enabled. 3 ZRam drives. (Backported from 3.x.x kernel)
    SWAP memory used on unused Preload partition. (Check with app like "Kernel Tuner")
    CWM recovery
    Dyanamix FSync
    Added ARM Topology (better than generic ones)
    Optimized CRC32 code, Added AES Cipher code.
    Panic mode disabled.
    OOM Protection for init process.
    Many many fixes & upgrades viewable on github source.
    Read more on what are governors, IOscheds and other FAQs to be updated in posts below.
    Your note will never be same with DragonHeart. Feel the fluid fire power!
    Planned Features:
    More fixes.
    Port features from Note2, I9300 and I9100 kernels.
    Driver updates.
    Slide2Wake Feature. Needs lot of merger again.
    Requested Feature: Show CPU and Board temperature in Kernel Info.
    Any feasible feature request?
    Kernel Source:
    https://github.com/neobuddy89/androi...msung_smdk4210
    Download Here:
    My Files
    Caution:
    First Boot will be long.
    It take usually 5-10 minutes (depending on no. of apps & Rom you have) after first few boot to give you fluid performance
    Warning:
    It's your device. It's your responsibility for what you flash. Do not blame us.
    DO NOT flash over forbidden kernel as that kernel has incompatible/unstable/non-tested init.d scripts.
    Do not discuss forbidden kernels over here. Hail open-source!
    You may post anything related kernel. Make sure to mention ROM name, Governor name, IO Scheduler name.
    Qualche info in più...
    Topic explaining all basic Governors & I/O Schedulers: Click Here
    Governor we use as default:
    Hyper -
    The Hyper (formerly known as kenobi) is an aggressive smart and smooth, optimized for SMDK4210 board getweakt and, based on the Ondemand, which was getweakt of Arighi and was equipped with several features of Ondemandx suspend imoseyon. (Added by sysfs, the settings suspend_freq and suspend Imoseyon's code) is the behavior of the hyper Ondemand if he is in action, very similar. He also has the Arighi's fast_start deep_sleep and detection features. In addition, the maximum frequency is in suspend mode 500Mhz
    IO Scheduler we use as default:
    BFQ -
    Instead of time slices allocation by CFQ, BFQ assigns budgets. Disk is granted to an active process until it's budget (number of sectors) expires. BFQ assigns high budgets to non-read tasks. Budget assigned to a process varies over time as a function of it's behavior.
    Advantages:
    Believed to be very good for usb data transfer rate.
    Believed to be the best scheduler for HD video recording and video streaming. (because of less jitter as compared to CFQ and others)
    Considered an accurate i/o scheduler.
    Achieves about 30% more throughput than CFQ on most workloads.
    Disadvantages:
    Not the best scheduler for benchmarking.
    Higher budget assigned to a process can affect interactivity and increased latency.
    zzmoove is ported governor (by me) from SGS3. Read about it HERE.
    My Recommendations:
    Recommended Governors: HYPER > SmartAssv2 > LulzActiveq > Zzmoove > Pegausq > Others
    Recommended Schedulers: BFQ > ROW > ZEN > CFQ > SIO > NOOP > Others
    In case you have SOD (Sleep of death), please check minimum frequency. It should be greater than 100 MHz.
    Recommended 200 MHz.
    F.A.Q.:
    Q. I am getting FC / Performance control not working. What is the solution ?
    A. Reboot in recovery. Wipe cache and dalvik cache.
    Q. I am getting sleep of death. What do I check ?
    A. Adjust minimum frequency to 200 MHz and not lower.
    Q. Which is best governor and IO Scheduler?
    A. All of us have different choices. There is no thing like best governor or IO Scheduler.
    You need to set your personal favorite. I have posted my recommendation in above post.
    Q. It takes long time to boot. What is wrong ?
    A. Nothing is wrong. Let DragonHeart optimize your apps and database.
  2. I seguenti 2 Utenti hanno ringraziato AlienwareAR per il post:
    7raiden7 (29-03-13),Sfattucci (28-03-13)
    Pavia & Milano
    Honor 8 Pro
    Changelog Ultima Versione
    v1.8:
    Stop the panic mode. Should fix sleep of deaths. Please report.
    OOM protection for init process.
    SWAP enabled.(Check with app like Kernel Tuner. To disable SWAP, set vm.swappiness to 0)
    Swappiness set to 60% (Default)
    Overall improvement of multitasking.
    New MALI from Note8.
    Fix wifi power drain on standby.
    Improve touch screen sensitivity.
    Tune CPU throttle values.
  5. #3
    Pavia & Milano
    Honor 8 Pro
    Riservato...
  6. #4
    Baby Droid L'avatar di Darius87
    Torino
    Samsung Galaxy Note (GT-N7000)
    Non è possibile tradurlo in Italiano?
  7. #5
    Senior Droid L'avatar di giaris
    Ravenna
    Galaxy Note GT-N7000
    Ringraziato 206 volte in 166 Posts
    Quote Originariamente inviato da Darius87 Visualizza il messaggio
    Prova con il traduttore di google: funziona
    Se ti sono stato d'aiuto, non scrivermi "grazie": usa il tasto "THANKS" a sinistra
  8. #6
    ho letto giusto le prime righe, su touch wiz non funziona giusto?
  9. #7
    Pavia & Milano
    Honor 8 Pro
    Quote Originariamente inviato da arinin Visualizza il messaggio
    Ciao.
    Per ora no, le TW non sono ancora supportate..
  10. #8
    Banned
    Palermo
    Ringraziato 701 volte in 438 Posts
    Quote Originariamente inviato da AlienwareAR Visualizza il messaggio
    Ciao.
    Grande Alien!! Dato che tu l'hai provato perché non srivi una mini recensione nel terzo post? E anche i settaggi che usi! Sempre se hai tempo, se ti va, e se lo ritieni opportuno! Io sono sull'Asylum.. Dire che è una scheggia è poco!!! Ed ero anche un po' tentato dalla 1.8, perché ha anche aggiornatocai nuovi mali!
    Edit: scusa sono un niubbazzo, la recensione l'avevi già scritta nel thread della stunner!!! Ps: non sono d'accordo nell'utilizzare Juice Defender perché interferisce col funzionamento del kernel (lo dice Utacka, non io )
    Ultima modifica di 7raiden7; 29-03-13 alle 07:48
  11. Il seguente Utente ha ringraziato 7raiden7 per il post:
    AlienwareAR (29-03-13)
  12. #9
    Pavia & Milano
    Honor 8 Pro
    Quote Originariamente inviato da 7raiden7 Visualizza il messaggio
    Ciao 7raiden7!
    Sai che forse hai proprio ragione..?!?!! O meglio, a quanto pare ha ragione Utacka..
    Perché purtroppo con la nuova StuNNeR 2 sto ancora avendo il problema del blocco con conseguente FC..
    Ovvero sono costretto a tenere premuto il pulsante di alimentazione per riavviare il Note..
    Pensando fosse colpa del kernel ho messo l'ultimo CM ma tale problema persiste.
    Quindi penso proprio che nel pomeriggio troverò il tempo per fare nuovamente un bel Deep Clean + Full Format,
    e poi di non installare più Juice Defender Ultimate..
    Ah sì..?!?! Ed allora cosa mi consigli..?! Asylum oppure StuNNeR..?!?! :o
    Ovviamente poi troverò il tempo di fare la recensione..!
  13. Il seguente Utente ha ringraziato AlienwareAR per il post:
    7raiden7 (29-03-13)
  14. #10
    Banned
    Palermo
    Ciao 7raiden7!
    Beh come recensione va benissimo questa:
    Ciao!
    Bene..! Infatti a mio modesto avviso questa è superiore rispetto alla ParanoidAndroid 3.10..
    Dunque, flashando il nuovo kernel ho avuto dei problemi di crash e SOD, ovvero il Note non si riprendeva più,
    ed ero costretto a tener premuto il pulsante di alimentazione per farlo riavviare..
    Ecco qui maggiori dettagli della situazione nella quale ho riscontrato quel problema:
    - Governor = smartassV2
    - IO Schedyler = row
    - Current Max = 1400 MHz
    - Current min = 100 MHz
    Così, dopo aver letto vari thread su XDA sia in merito alla rom sia al kernel ho deciso di impostare questi nuovi parametri:
    - Governor = HYPER
    - IO Schedyler = bfq
    - Current Max = 1600 MHz
    - Current min = 300 MHz
    Tra tutti, penso che la frequenza minima sia quella più importante, in quanto altri utenti hanno riscontrato il mio stesso problema
    solo se settavano sotto ai 200 MHz..
    Ora, dal punto di vista della batteria devo ancora vedere come si comporta in associazione con Juice Defender Ultimate..
    Per il resto non c'è bisogno di deep clean, basta disinstallarlo, cancellare la sua eventuale cartella in android.secure e fare wipe cache e dalvik!!
    Io non ho provato la Stunner ma la Asylum con l'ultimo Kernel suo è una bomba!! Appena noto rallentamenti, lag o simili cambierò e proverò questo kernel!! Ci tengo a precisare che sono presenti gli Stylus quindi non perdiamo le funzionalità della S-Pen!!
  15. Il seguente Utente ha ringraziato 7raiden7 per il post:
