Pagina 1 di 9 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 86
[ROM][JB][4.1.2] XXLT4 240 Dpi v.2.5 AROMA INSTALLER
    Riserva Navajo
    ROM spettacolare a 240 DPI...installabile tramite AROMA INSTALLER !!....scelta CSC ITV
    Download 2.5
    http://www.androidfilehost.com/?fid=23329332407577275
    Scaricare e copiare lo zip nella sd interna del Note....riavviare in CWM recovery eseguire tutti i wipes e flashare
    changelog:
    changelog:
    AROMA Installer (you can almost fully customize your Rom)
    JB Bootloader included (no more bootloop after power off, or removing battery)
    Base: JZO54K N7000XXLT4
    Modem: N7000XXLSO or N7000XXLT3 or N7000XXLT4 or N7000BOLT1 *
    Philz kernel XXLT4-5.00.5 or Philz kernel XXLT9-5.08.5 or SpedMod K5-5
    or c.o.h HelloWorld kernel v1.3.7b or Forest HelloWorld-Make-II v1.5.5 and v1.6.4
    Display languages: en_GB; en_US; en_AU; en_IE; en_NZ; en_ZA; de_AT; de_CH; de_DE; fr_FR;
    fr_CH; it_IT; es_ES; es_US; nl_NL; pt_PT; pl_PL; tr_TR; ko_KR; ru_RU; bg_BG; hr_HR; cs_CZ; da_DK;
    nl_BE; et_EE; fi_FI; el_GR; hu_HU; is_IS; ga_IE; kk_KZ; lv_LV; lt_LT; mk_MK; nb_NO; pt_BR; ro_RO;
    sr_RS; sk_SK; sl_SI; sv_SE; uk_UA; uz_UZ; az_AZ; hy_AM; ka_GE; ca_ES; eu_ES; gl_ES; ar_AE;
    zh_CN; zh_HK; zh_TW; ja_JP; in_ID; vi_VN; ms_MY; th_TH; fa_FA; ar_IL; iw_IL; ur_PK;
    More info in Post #171
    Note 2 Keyboard (Fully working)
    Auto correct not enabled
    Long press delay 200ms
    Input languages: en; az; ca; cs; da; de; et; es; eu; el; fr; gl; ka; hr; it; is; kk; lv; lt; hu; nb; nl; pl;
    pt; ru; ro; fi; sr; sk; sl; sv; tr; uk; ko; hy; bg ; ar; zh; in; vi; ms; th; fa; iw; ur;
    Handwriting support for: bg, ca, cs, da, de, el, en, es, et, eu, fi, fr, gl, hr, hu, id, is, it, kk, ko, lt,
    ms, nb, nl, pl, br, pt, ro, ru, sk, sl, sr, sv, th, tr, uk, vi, zh, ur *
    Japanese language input not supported (but it's enabled)
    Online language download and update (internet connection needed to start language support)
    Stock Note Keyboard : Support list Included in the attachments
    Secondary symbols can be enabled for: CA; MS; ID; CS; EN; DE; EU; ES; HR; GL; IT; LV; HU; PL;
    NL; PT; SK; RO; SR; SL; TR; TH; UR; AR; KR; ZH *
    CSC codes for 97 countries: ABS; AFG; AFR; ALO; ARB; ARO; AUT; BGL; BRI; BTC; BTU;
    CDR; COA; CPW; CYO; DAM; DBT; ECT; EGY; ETR; EUR; FOP; FTD; FWD; GLB; HAJ; HTS;INS; INU; ITV;
    JED; KEN; KOR; KSA; MAT; MED; MID; MM1; MRT; MSG; MSR; MTN; MWD; NPL; ORS; PAK; PCT;
    PHE; PSP; SEB; SEK; SER; SIN; SKZ; SLK; SMA; SMO; STH; TCE; TDR; TGP; TGY; THL; THR; TMC;
    TML; TOP; TPH; TRA; TSR; TTT; TUN; TUR; TWO; UPO; VHC; VIM; VNO; XEF; XEH; XEO; XEU; XEV;
    XEZ; XFA; XFC; XFE; XFV; XME; XSA; XSE; XSG; XSK; XSP; XTC; XTE; XXV * Only one can be used.
    Phonepad layouts: en, iw, ko, ru
    Airview enabled or disabled *
    More battery icon ; 1% or 3% battery; blue, green, white, grey colored circle battery *
    Ripple effect enabled
    Ink effects (none, pink, orange, green, blue, navy, purple, brown)
    Translation added (none, pink) for all stock language "native no extra app"
    Smart rotation
    Call recording enabled or disabled *, ascending ringtone disabled
    SMS hacks: displaying sent time, sms 100 recepients, SMS to MMS auto-converting increased
    Auto convert sms to mms after 6 sms; 10 recipients for mms
    Gallery airview
    OS Scrolling cache disabled
    Launcher: Home shortcut labels can be removed; wallpaper scrolling and rotation can be enabled or disabled *
    More wallpaper in wallpaper chooser *
    Lock screen rotation or no rotation *
    Mono audio, Turn off all sounds, Assistive Light, Negative colors Widget enabled
    Camera shutter on/off option enabled, focus sound disabled, battery restrictions removed
    Stock Multiwindow or semi transparent or ARYA themed or white themed *
    16 samples for S Note *
    Exit menu to stock web browser *
    Max. 7 home screen shortcuts enabled in the Launcher if the labels are hidden *
    Max. 6 Lock screen shortcuts
    Information Ticker fixed
    Some S4 ringtones *
    Update removed from settings (and the update files from Samsung)
    Voice Wake up command to unlock with SVoice (Note 2, or S4) *
    New Message app (added translations: German, Hungarian, Italian, Korean, Polish) *
    PhoneUI or TabletUI. *
    Power menu and recent apps button on the top of the notification Panel (without the MW layout buttons)
    Xposed Framework and per app density app added *
    ICS or JB transitions for the system *
    Google Earth *
    6x2 S4 styled Accuweather Widget but looks like the stock Note widget or semi and fully transparent or
    the same in blue or S5 themed widget *
    Polaris Office 4.0 and Viewer *
    Resizable Popup browser (can be started from app drawer) *
    A little power tweak: Wifi scan interval set to 18000 milliseconds (stock 0,25 Minutes),
    NTP timeout set to 20000 seconds (stock 10 Minutes)
    Minimum back light: 10%,15%, 20%, 25%, 30%, 35% or 40% *
    4 way reboot *
    CRT Off effect in the Settings/Extra settings with toggle *
    Skip track with the volume button can be enabled in the Settings/Extra settings with toggle *
    Talk or Hangouts *
    Google Play white or black *
    Keyboard: Samsung Note or Note 2 or Swype or Swiftkey trial *
    Launcher: TW or Nova or Apex *
    Blue or green Notification panel toggles *
    Lock screen Torch can be enabled or disabled *
    Phone and message app contact pictures can be changed to S4 pictures or back *
    Screenshot and reboot to recovery in the power menu *
    Menu, Back, None to kill app activity *
    S4 Icons or stock *
    Disable or enable SMS log in call log *
    S Note stock or S Note from Note 2 and IdeaSketch included *
    Browser Zoom mod included: pinch to zoom or pinch to zoom and Scrolling zoom *
    Themes can be applied and changed back to stock any time *
    White theme in preparation, so for now white settings, multi window, job manger, file manager, or restore stock *
    S4 Google Edition 4.3 Camera, Gallery and Video player, or Stock *
    Viper4Android XHIFI and FX version included *
    TabletUI can be enabled with the xposed TabletUI trigger modul *
    White Phone, Sms, Downloads, Settings, Email, Filebrowser in white theme *
    Speedmeter in status bar with toggle
    GB video editor *
    Picto TTS enabled *
    More detailed selection in the Aroma Installer (Xposed modul, TTS language selection, etc.)
    Setup Guide started to include in the Aroma Installer
    Included Xposed Modules: Enable Call Recording; Long Sms; Play Store Link in App Info; Scrolling Wallpaper;
    Tablet UI trigger; XBackground; Multi Window Apps Manager; Tweakbox; Quick Setting Toggles KM edition;
    XTweakbox, VolumeSkipTrack, XButtonActions
    Floating Multi Windows (on Phone or on TabletUI)
    S Pen Airview On / Off toggle
    Quick command *
    Note 2 S Planner with fully Airview *
    Status bar: blue, green, red, white or stock grey icons, stock battery icons are included,
    centered or stock clock position, animated or stock battery charge
    Tone selection: minimal, default, extra (ringtones, alarm, notifications, UI sounds) *
    S4 Boot animation or stock, S4 unlock sound or stock, or no boot sound
    build.prop tweaks *
    Some CSC features in Settings/Extra settings with ON/OFF toggle
    Airplane and Allshare Cast toggle
    Note 8 Contacts and Video player *
    Sketch Book for Galaxy
    Automatic call recording *
    Hot spot icons in app drawer
    More menu item in the settings (Airplane mode, Call/message block, Users & restrictions, USB settings)
    Crt effect and Statusbar keyboard notification can be turned on and off from Settings/Extra Settings
    Universal Odex app *
    In the Messaging app all useful extra functions are enabled (restore function translated with google translate)
    Xposed disabler *
    Adobe FlashPlayer *
    Auto Scroll in Statusbar quickpanel toggle disabled
    Arman, Arya Blue, Arya Passion, Parsa, S4 theme *
    Toggle added to Settings / Extra Settings for: Mostly for Phone UI.
    TW Launcher
    - Transition tilt effect
    - Home screen looping
    - Home screen edit menu
    - Scrolling Wallpaper
    TW Contacts
    - Contacts photos
    - Contacts list call buttons
    TW Browser
    - Exit prompt
    - Edge Zoom
    Power Menu Addons
    - Screenshot
    - Recovery
    Status bar
    - Keyboard Notification
    - Speed Meter
    - Transparency
    Miscellaneous
    - Lockscreen torch light (on locked screen with home button)
    - Long Press to Kill Button (Menu, Back or none)
    - Volume to skip sound track
    - Crt off animation
    - AOSP Lockscreen
    Fix for transparent status bar on the lock screen included
    Tablet TW launcher for TabletUI
    Siganture verification disabled
    Ultima modifica di Andromeda1968; 10-04-14 alle 15:52
  2. I seguenti 2 Utenti hanno ringraziato Andromeda1968 per il post:
    Jo-san (28-11-13),Sfattucci (28-05-13)
    Riserva Navajo
    riservato !!!!!!!!!!!!
  5. #3
    Riserva Navajo
    riservato !!!!!!
  6. #4
    Riserva Navajo
    mettiamo un po' di sana competizione al nostro amico Sfattucci
    ciao carissimo
    p.s. gran bella rom....
  7. Il seguente Utente ha ringraziato Andromeda1968 per il post:
  8. #5
    Baby Droid L'avatar di Nutella
    Galaxy Note
    Scaricata stanotte e flashata stamattina. Grande rom. Ho provato anche quella di Sfattucci, ma ha sempre avuto qualcosa che non mi convinceva a 240 dpi. Mi sa che terrò questa per un pochino XD
    P.S. Se può interessare dovrei fare dei test per installare Awesome Beats con uno zip che ho trovato su XDA. Se interessa riporto il link per integrare ^^
  9. #6
    Riserva Navajo
    certo postate pure tutte le mods
    comunque anche io per ora posso solo parlarne bene
  10. #7
    Galaxy Note
    Allora per quanto riguarda l'installazione dei driver Beats fate riferimento a questo link: [MOD][APP]AwesomeBEATS™ v.5 For ALL ANDROID AOSP ROMS(02.05.13) Experience BEATS - xda-developers
    In seguito, come molti sapranno, sarà sufficiente utilizzare un player simile a Walkman, Google Play o qualsiasi altro che possa supportare i driver esterni al classico MusicFX integrato nella rom.
    P.S. I driver Beats sono un pacchetto da flashare in CWM e utilizzano l'Aroma Installer, quindi è una passeggiata mettere il tutto ^^
    Aggiungo il link per il player ^^ http://forum.xda-developers.com/show....php?t=1803894
    Ultima modifica di Nutella; 28-05-13 alle 12:33
  11. #8
    Jul 2010
    Salve, ROM installata dopo qualche piccolo problema sicuramente dovuto sicuramente a qualche mio errore
    Avrei diciamo qualche domanda da porvi:
    1) E' possibile ingrandire i caratteri?? Andromeda già mi ha detto che dipende dal fatto che è a 240Dpi però non so se è possibile modificare qualcosa.
    2) E' possibile ingradire le foto dei contatti in chiamata?
    3) Il programma S Voice funziona solo se "cliccato" !?!? E poi come mai quando dico "Ciao Galaxy" non si "riaccende" ??
    Galaxy Note
    Quote Originariamente inviato da RobCZ Visualizza il messaggio
    Ciao BobCZ
    1) Per quanto riguarda i caratteri potresti impostarli da Schermo->Dimensione Carattere, anche se devo darti ragione sul fatto che non tutte le scritte vengano realmente ingrandite.
    2) A proposito delle foto invece non saprei darti una risposta precisa. Credo in realtà debba essere modificata la dimensione mettendo mano all'apk che gestisce il telefono, ma non vorrei sparare una cavolata
    3) Ho provato S-voice e a me non da nessun problema. Lo attivo con il doppio click sul tasto Home, esattamente come nelle versioni stock Samsung.
    Prova a darci qualche dettagli in più rispetto al problema che riscontri e vediamo se riusciamo a trovare una soluzione
  13. #10
    Jul 2010
    Quote Originariamente inviato da Nutella Visualizza il messaggio
    Ciao BobCZ
    Ciao Nutella,
    allora per i caratteri ho provato, ma non cambia quasi nulla. Per le foto,non sai neanche se esiste tipo un apk per risolvere il problema?? E' un peccato avere un display GIGANTE e la foto un quadratino piccolo
    Per quanto riguarda S-voice anche a me funziona con il doppio click, ma avvolte quando devo dire "Ciao Galaxy" l'applicazione non si "sblocca" e devo cliccare sul microfono, e poi volevo sapere, a display bloccato esiste un modo per farlo partire?
    Ora mi sono accorto, che il telefono non suona quando la batteria scende sotto il 30%, devo impostare qualcosa?
