Utente del giorno: cladroid con ben 1 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: bluemask con ben 18 Thanks ricevuti negli ultimi sette giorni
Utente del mese: bluemask con ben 36 Thanks ricevuti nell'ultimo mese
Visualizzazione dei risultati da 1 a 10 su 29
[MOD] Pure performance
    samsung note, galaxy tab
    Ultima modifica di ntony17; 30-07-13 alle 20:16
    Ringraziato 25 volte in 17 Posts
    Quote Originariamente inviato da giopon Visualizza il messaggio
    messa sulla paranoid 3.68 ... molto più fluido, provato per curiosità antutu e fà 9717
    dal thread:
    ◢ Features ◣
    - Android performances improved at 360°
    - Radically improved management ram on android (Lags...adios!)
    - Script lightweight and revised to be adapted to this engine
    - Improves a lot the graphics: of course Pure Graphic™HD, Pure Dithering Plus™ and... AOSPA 3.60 system tweaks
    - Scan multimedia time drastically reduced
    - Network Improvements, 3G experience even in 2G modality
    - All SQlite database optimized
    - Enable hardware features turned off by default for a better experience on entry level devices
    - Greatly increases the score AnTuTu: Try it to believe it!!
    - Reduces the startup time of Android
    - A version for stock rom and one for CM, to squeeze any roms!
    - Allows you to play ported games without lags
    - Cleans the system every 24 hours, thecache every week and the Dalvik every month (cronos easter egg)
    - Automatically Zipalign on each boot (sensitive to the user)
    Battery
    - Drastically decreased the drainage of battery
    - Check the activities that consume too much battery stop them with PureWakelocks™
    - When the phone is charging reduces system services for faster charging
    - The battery is calibrated on every boot
    - Disable animation of the system when the battery is nearly exhausted
    - Improvements in build.prop as regards the part of consumption
    Graphics, Screen, Images
    - Enables a non-aggressive dithering to save CPU
    - When you lock the device, the engine makes sure that the GPU is turned off
    - Enables deep sleepalso in the bugged rom
    - Parts of bravia engine
    - Of course parts of CrossBreeder (credits to dev)
    - Of course parts of Adrenaline Engine (credits to dev)
    - Of course PureGraphics HD, even though I already told you
    - Of course V6 supercharger
    - Generates video entropy (like seeder)
    CPU, Governors, I/O Schedulers
    - Slightly improves the scaling of the frequencies (for better results you need a good kernel)
    - Lightens the load on the CPU switching the workload to GPU rendering
    - Enable the swap partition in Android (experimental)
    I've said too much, man. Install this engine and discover its power! :P
    Ultima modifica di nardudtyle; 31-07-13 alle 01:42
    Napoli
    Galaxy Note
    Come si installa?
    È davvero buona?
    Quote Originariamente inviato da milza0000 Visualizza il messaggio
    Come si installa?
    È davvero buona?
    io noto veramente una velocità impressionante rispetto a prima, e montavo gia kernel n/x 1.4.2 e paranoid, basta fare flash da bios.... non so che faccia ma è assurdo provatelo
    Androidiani Power User L'avatar di ntony17
    Plutone
    G Note (PiastrellaPhone)
    Ringraziato 1,673 volte in 1,138 Posts
    Giopon aggiusta il primo post... Descrizione screenshots ecc ecc così poi io sistemo il titolo...
    Edit:titolo sistemato
  7. Il seguente Utente ha ringraziato ntony17 per il post:
    giopon (31-07-13)
  8. #6
    Napoli
    Galaxy Note
    Ragazzi la monto da ieri su JB 4.1.2 LT4 Stock.
    Praticamente un turbo, se applicata ad un quadcore avrebbe la fluidità di Ios
  9. #7
    Androidiano L'avatar di melzapr
    A metà strada fra Betelgeuse e Alfa Centauri
    Galaxy Note GT-N7000
    Ringraziato 14 volte in 10 Posts
    Ma gli svantaggi dove sono? La batteria come va rispetto a prima?
  10. #8
    Napoli
    Galaxy Note
    è questo il bello, non vedo svantaggi O.o
  11. #9
    Se ho ben capito va su tutte le versioni... basta flashare da recovery clockword dico bene?
  12. #10
    Scusate ma si installa come un zip da recovery? E i wipe si fanno ?
