[Rom] ChamelonOS basata su Cyanogen Mod 10.2
    Senior Droid L'avatar di fateviunavita
    Nexus 4 - Samsung galaxy s scl
    Ringraziato 51 volte in 42 Posts
    ciao raga volevo mettere in risalto questa rom per il nostro dispositivo, sembra promettere bene e sembra anche molto bella!
    Qui il link alla discussione su xda ( file:///C:/Users/mamma/Pictures/FOTO...developers.htm )
    Ecco i punti principali:
    [ROM][UNOFFICIAL][JB 4.3][A1] Chameleon OS [0.8_4.3][I9003][9 Sept 2013]
    Chameleon OS (or ChaOS for short) is a custom Android ROM that gives the user more control than they can experience on any other Android ROM. Starting with a CyanogenMOD base, we customize each piece to give ultimate control while maintaining the simplicity we all love about Android. The most notable feature of ChaOS is the theme engine, which can apply different pieces of themes in a true mix-and-match style. The launcher has been completely overhauled with tons of options that you'd normally need to download a third-party launcher for, such as home screen previews, folder sorting, and folder icon styles. The Messaging app has also had some UI retouches, including messaging bubbles and quick emoji button.
    The entire framework of ChaOS has been modified around the theme engine, allowing for custom fonts, boot animations (with animated preview), and themes. No longer do you have to try to find the perfect theme, with Chameleon OS you can patch it together with your favorite pieces from different themes. Messaging, Phone, Status Bar, icons, everything can be set completely individually from each other which provides the capabilities to completely re-imagine your phone. Creating themes for the ChaOS Theme Engine is superbly simple and has extreme versatility.
    Even with all of the features we've currently implemented, ChaOS will continue to mature with even more refined settings and features. We will be completely open source and will welcome developers to join us, whether it be by maintaining a device or utilizing our gerrit review. Even if you're not a developer, your voice will not go unheard. We will continually poll our users for the most wanted features and do our best to implement them.
    Ultima modifica di Fabiox08; 30-09-13 alle 13:17
    Ricorda se ti sono stato d'aiuto un THANK'S è ben accetto!
    io ho seguito tutti i passaggi per installarla.
    dopo che faccio "reboot sistem now" bisogna configurare il cell ma quandoarrivoal punto di inserire la data e l'orario faccio "avanti" ma a quel punto mi esce la seguente scritta "il processo di installazione guidata si è arrestata improvvisamente" ........come potrei risolvere??
    Senior Droid L'avatar di chievo93
    i9003 cm10.1
    Ringraziato 75 volte in 66 Posts
    Quote Originariamente inviato da fateviunavita Visualizza il messaggio
    Su xda Lola dice che la ROM ha problemi e che bisogna aspettare il prossimo aggiornamento per installarla.
  5. Il seguente Utente ha ringraziato chievo93 per il post:
    fateviunavita (10-09-13)
  6. #4
    Quote Originariamente inviato da chievo93 Visualizza il messaggio
    infatti ho letto e molti hanno problemi di FC! peccato
  7. #5
    OnePlus X 16 gb -Onyx-
    Riordina il primo post e rendilo in italiano, e metti una guida per l'installazione.
    Pagina Clan S Advance ->
    Clan Galaxy S Advance
    Card Del Clan ->
    Motorola Moto G 8 Gb
    Founder Del J-Team
