ROM MIUIv4 ICS 4.0.3 BETA8.1
		FEATURES -
*based on official MIUIv4 release for nexus s , 2.2.3
*devil latest kernel- v1.0 .
*MULTILANGUAGE- English, Chinese , Portuguese, German , polish, French and more to come later as people help us.
* added/fixed video recording which wasn't working in latest build.
*Fixed ril.
*added face unlock which wasn't working in latest build.
*added APEX LAUNCHER.
* added nova launcher.
*zipaligned .
*various tweaks.
*Fixed camera.APk which does not crashes when changing megapixel( thankxx to djkoa ).
*removed unwanted apps to extend battery life.
*EXTERNAL SD CARD TOTALLY works, IS SCANNED BY ALL APPS. CAN BE LOCATED IN EMMC FOLDER IN ROOT OFBDEVUCE USING ROOT BROWSER.
*tv out works.
*build.prop tweaks.
*THEMES NOW WORK.
*BRAINMASTER'S ICS TWEAKS (not all)
*ADhoc host, by brainsmaster.
*CM9's Aries parts in app drawer .
*GOOD BATTERY LIFE, NOT LIKE OLD MIUIs
*MIUI GB MUSIC APP, cm music app, ORANGE GOOGLE MUSIC APP.
* READ CHANGELOG IN THIRD POST.
known bugs/issues
*market shows the 'wifi' suggestion in many apps which it should not as those apps aren't very big sized. Not a big problem, again this is not from our side. Base bug.
*graphical glitches in status bar.
*external SD card can't be accessed when connected to computer via USB.
* unknown bugs. Pls report.
Flashing instructions (FOLLOW THESE IF U R ON ANY OTHER ROM)-
*you can flash this rom from any gingerbread/ics rom you are on .
*download rom.
*optionally backup your data using titanium backup/ my backup root and make a nandroid backup, just in case.
*Wipe data/factory reset.
*install zip from SD card -- choose zip from SD card -- install from where you have stored it.
*install again to make sure you don't loose cwm.
* reboot and let the rom settle for 5 minutes then complete Google setup, after that let the rom settle for another 5-10 minutes. Then use your device.
*please charge to 100% after first boot for perfect battery results.
Flashing instructions from any previous beta.
*download rom  Hotfile.com: One click file hosting: drZMIUIv4_beta-8.1_2.2.3.zip
*wipe data-- recommended, not necessary.
*install rom.
*install again to make sure u don't loose cwm .
*reboot.
*let it settle for 5-10 minutes.
*recommended- after installing rom charge to 100%. Download NStools app from android market to tweak kernel settings.NStools isn't found in games section of market that means it isn't a game so don't play with it, use it sensitively.
Installation instructions also here - HERE
NOTE- rom is still in beta but is pretty stable. Report bugs, and now feedback is also appreciated.
OFFICIAL THREAD [ROM][MIUIv4][ICS][4.0.3][BETA8.1]drZMIUIv4- MULTI LANGUAGE[08/02/2012] - xda-developers
