Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 20
[ROM] Elenco Rom by iaio72
    Androidiano VIP L'avatar di iaio72
    Jul 2009
    Ringraziato 618 volte in 346 Posts
    - ROM MODDATE BASE ECLAIR:
    * SuperEclair base XXJM8 ----> https://www.androidiani.com/forum/sa...air-i9000.html
    * iaioROM V.1 base XXJM8 ----> https://www.androidiani.com/forum/sa...rom_v-1-a.html
    ROM MODDATE BASE FROYO:
    * iaioROM V.2 base BUILD FROYO XXJPC ----> https://www.androidiani.com/forum/sa...royo-base.html
    * iaioROM V.3 base BUILD FROYO XXJPH ----> https://www.androidiani.com/forum/sa...froyo-jph.html
    * LightRom base BUILD FROYO XXJPK ----> https://www.androidiani.com/forum/sa...oyo-xxjpk.html
    * LightRom 2 base BUILD FROYO XXJPK ----> https://www.androidiani.com/forum/sa...oyo-xxjpk.html
    * LightRom 3 base BUILD FROYO XXJPK ----> https://www.androidiani.com/forum/sa...oyo-xxjpk.html
    * LightRom 4 base BUILD FROYO XXPK ----> https://www.androidiani.com/forum/sa...m-4-xxjpk.html
    * LightRom 5 base BUILD FROYO XXJPM ---->https://www.androidiani.com/forum/sa...rom-5-jpm.html (IN LAVORAZIONE)
    * Base_Froyo_JPO_V.1 base BUILD FROYO XXJPO ----> https://www.androidiani.com/forum/sa...oyo_v-1-a.html
    * Base_Froyo_JPA_V.2 base BUILD FROYO XXJPA ----> https://www.androidiani.com/forum/sa...jpa_v-2-a.html
    * FROYAYO x3 base BUILD FROYO XXRSJP5 -----> https://www.androidiani.com/forum/sa...-rsjp5-x3.html
    * SUPERFROYO K10I base BUILD FROYO XXRSJP5 -----> https://www.androidiani.com/forum/sa...0i-themed.html
    * FROYO XXJPU FULL 2.2.1 base BUILD FROYO XXJPU -----> https://www.androidiani.com/forum/sa...2-1-froyo.html
    ** TATU★ROM Froyo XXJPY -----> https://www.androidiani.com/forum/sa...-tatu_rom.html
    ** Essential v1 Froyo XXJPY -----> https://www.androidiani.com/forum/sa...tml#post282566
    ** Essential Full Froyo XXJPY -----> https://www.androidiani.com/forum/sa...tial-full.html
    IN AGGIORNAMENTO.
    Ultima modifica di iaio72; 11-01-11 alle 15:15
    OnePlus 3T
    Meizu Mx6
  2. I seguenti 7 Utenti hanno ringraziato iaio72 per il post:
    befanello (05-11-10),d33p (25-01-11),Gufi (02-11-10),idiversss (02-12-10),jrandrea (04-11-10),Peppegs (03-11-10),SirJack (04-11-10)
    Androidiano L'avatar di GabrieleBeNN
    Aug 2010
    Ringraziato 71 volte in 31 Posts
    Ti serve una mano per tutte le altre?
    Innervision - System of a Down Tribute - Bass Player
    Follow us on:
    -------->Facebook<--------
    -------->MySpace<---------
    -------->YouTube<----------
    Per ringraziarmi usate il pulsantino thanks in basso a destra!
  5. #3
    Jul 2009
    Quote Originariamente inviato da GabrieleBeNN Visualizza il messaggio
    bellaaaaa domandaaa!
    tu per "le altre " che intendi ? tutte le build che trovi su samfirmware o tutte le rom moddate che trovi su xda?
    io pensavo le nostre moddate, al momento sono solo io, ma ben presto si accodera tatuato! poi fare una lista di tutte le build eclair e froyo ma senza link, non avrebbe senso....e limitiamoci a questo, se poi dovessimo linkare xda, allora siamo fritti...
    questa è la mia idea....
    OnePlus 3T
    Meizu Mx6
  6. Il seguente Utente ha ringraziato iaio72 per il post:
    idiversss (01-12-10)
  7. #4
    Aug 2010
    Quote Originariamente inviato da iaio72 Visualizza il messaggio
    Direi le varie che compaiono su XDA (per ora sono una decina non mi sembra così impossibile) con solo il link al thread e update quando ne escono di nuove. Eviterei le build su Samfirware che tanto sono "originali"...
    Farei anche un bel post con la spiegazione dei vari Lagfix (3 per adesso che sono utilizzati) soprattutto per spiegare come funziona ULF che è il più complesso ma quello che dovrebbe avere più futuro... dimmi tu se ti serve una mano!
    Ultima modifica di GabrieleBeNN; 02-11-10 alle 21:21
    Follow us on:
  8. #5
    Jul 2009
    azz e come nooo..certo che mi servirebbe una mano, anzi 2! grazie mille
    se ci pensi tu, poi quando hai finito lo sistemo nel 1° post!
    grazie!
    OnePlus 3T
    Meizu Mx6
  9. #6
    Aug 2010
    grazie!
    Inoltre credo e spero che la froyo che uscirà sarà la "base" per le rom cucinate evitando così la moltiplicazione delle versioni (prima Jpc, poi Jpm, poi Jpo, etc).
    In sti giorni vedo di farlo... così abbiamo tutto a portata di mano!
    Follow us on:
  10. Il seguente Utente ha ringraziato GabrieleBeNN per il post:
    Gufi (02-11-10)
  11. #7
    Jul 2009
    io come vedi quando ho potuto ho iniziato..ma tra lavoro, rom, cercare di rispondere in sezione..insomma il tempo è tiranno a volte per me!
    OnePlus 3T
    Meizu Mx6
  12. #8
    Senior Droid L'avatar di Peppegs
    Sep 2010
    Ringraziato 86 volte in 53 Posts
    Raga complimentoni per il lavoro.
    Ho una curiosità, ma le rom presenti su samfirmware non sono "originale" nel senso a me che ho la jm8 su versione kernel mi appare curio@.. che presumo sia il curio di xda.. son cmq rom moddate cucinate da xda?
    altra domanda.. ma esiste su xda un elenco di tutte le rom che sfornano? un post tipo questo che hai aperto tuo iaio.. perchè non ci si capisce un'H là in mezzo, ho l'impressione che uno cucina una rom e da quella ne nascono altre 4-5... e non si capisce differenze.. qualità etc.. dovrebbero fare un sistema di voto...
    Ps: scusate l'offtopic
    CIAO
  13. #9
    Aug 2010
    Quote Originariamente inviato da Peppegs Visualizza il messaggio
    Sto per mettermi a farlo io!
    Se mi dai mezz'ora dovrebbe esserci...
    Follow us on:
  14. I seguenti 2 Utenti hanno ringraziato GabrieleBeNN per il post:
    iaio72 (03-11-10),SirJack (04-11-10)
  15. #10
    Androidiano L'avatar di SirJack
    Oct 2010
    SGS2, Ideos, Nokia N95 8GB
    Grazie per il gran lavoro.
    Tre domande:
    1. Queste sono le ROM specifiche per il Galaxy S, giusto?
    2. Le ROM, ad esempio, Cyanogen o G.O.T. non sono contemplate?
    3. Perchè non riportare anche l'elenco delle varie releases ufficiali Samsung?
    Samsung Galaxy S III GT-I9300 NoBrand NoRoot yet!
    - AP/CP/CSC: I9300XXUGMK6/I9300XXUGMK6/I9300OXXGML1
    - Firmware: Stock 4.3
    - Kernel: 3.0.31-2168382 se.infra@R0301-02 #1
    - Build: JSS15J.I9300XXUGMK6
    - MicroSD: Samsung 32GB speed 10
    - MicroSIM: Vodafone
    Thanks are welcome!
