Pagina 1 di 11 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 101
[Firmware] I9100XWLP3 [23.03.2012][Android 4.0.3] [ICS]
    Mar 2009
    I9100XWLP3
    Base Firmware: I9100XWLP3 (4.0.3)
    Build Date: 23th March 2012
    Modem: I9100XXLPR
    CSC: I9100O2ULP4
    Change List: 287862
    codice:
    # begin build properties
    # autogenerated by buildinfo.sh
    ro.build.id=IML74K
    ro.build.display.id=IML74K.XWLP3
    ro.build.version.incremental=XWLP3
    ro.build.version.sdk=15
    ro.build.version.codename=REL
    ro.build.version.release=4.0.3
    ro.build.date=Fri Mar 23 03:30:10 KST 2012
    ro.build.date.utc=1332441010
    ro.build.type=user
    ro.build.user=dpi
    ro.build.host=DELL168
    ro.build.tags=release-keys
    ro.product.model=GT-I9100
    ro.product.brand=samsung
    ro.product.name=GT-I9100
    ro.product.device=GT-I9100
    ro.product.board=smdk4210
    ro.product.cpu.abi=armeabi-v7a
    ro.product.cpu.abi2=armeabi
    ro.product.manufacturer=samsung
    ro.product.locale.language=en
    ro.product.locale.region=US
    ro.wifi.channels=
    ro.board.platform=exynos4
    # ro.build.product is obsolete; use ro.product.device
    ro.build.product=GT-I9100
    ro.tether.denied=false
    # Do not try to parse ro.build.description or .fingerprint
    ro.build.description=GT-I9100-user 4.0.3 IML74K XWLP3 release-keys
    ro.build.fingerprint=samsung/GT-I9100/GT-I9100:4.0.3/IML74K/XWLP3:user/release-keys
    ro.build.characteristics=phone
    # Samsung Specific Properties
    ro.build.PDA=I9100XWLP3
    ro.build.hidden_ver=I9100XWLP3
    ro.build.changelist=287862
    # end build properties
    Just tested Handcent and it appears the the duplicate SMS bug IS NOT present on this build
    The only bloat appears to be an "O2 Space" app. Plus their boot animation and shut down animation, and lockscreen wallpaper.
    There seems to be a new Google Video app that I haven't seen before too
    Download:
    https://hotfile.com/dl/150294102/69b...XXLPR.zip.html
    rom no wipe deodexed: http://ul.to/w9tne0sr/GT-I9100_Wanam...ck.NO-WIPE.zip
    modem separato:http://www.filefactory.com/file/73lt...ODEM_XXLPR.tar
    kernel separato: http://www.filefactory.com/file/3rkh...RNEL_XWLP3.tar
    Ultima modifica di ZiCkY; 29-03-12 alle 22:06
  2. Il seguente Utente ha ringraziato ZiCkY per il post:
    onidjkd (30-03-12)
    Zuk Z1
    Nazione? Come mai non lo vedo ancora su samfirmware? Grazie.
  5. #3
    Senior Droid L'avatar di pole7
    Jul 2010
    Sestri Levante
    Ringraziato 70 volte in 64 Posts
    È brand O2 Inghilterra...
  6. #4
    Mar 2009
    Quote Originariamente inviato da moav79 Visualizza il messaggio
    ora c'è
  7. Il seguente Utente ha ringraziato ZiCkY per il post:
    moav79 (27-03-12)
  8. #5
    Androidiano VIP L'avatar di STEULM
    Sabaudia (LT)
    Galaxy S II
    Ringraziato 1,306 volte in 623 Posts
    ora c'è
    oh, noi sempre gli ultimi........
  9. #6
    Mar 2009
    Quote Originariamente inviato da STEULM Visualizza il messaggio
    io la prenderei invece dalla parte buona..come stiamo notando, le versioni si stanno evolvendo LPQ-LP2-LP3
    probabilmente in italia arriverà un firmware un pò migliore rispetto alla prima uscita lpq...e questo è un bene...
  10. #7
    Sabaudia (LT)
    Galaxy S II
    speriamo tu abbia ragione.....ma io credo che fra una versione e l'altra, cambino solamente le policy
  11. #8
    Androidiano VIP L'avatar di crisgen
    Napoli
    Oneplus 3 - LG G4
    Ringraziato 3,318 volte in 1,294 Posts
    Considerata la notizia nel blog circa la falla sulla sicurezza (grave) scovata in ics proprio da italiani concordo e spero avvenga quanto supposto da Zicky
  12. #9
    Senior Droid L'avatar di lorys80
    Cellole (CE)
    LG G3 ,Nexus 4,Samsung S2
    Ringraziato 43 volte in 37 Posts
    dalla LPQ alla LP2 ci son stati miglioramenti quindi e meglio che avvenga in questo modo graduale che altrimenti rischiamo come accadde con microsoft per windows meglio piano e con migliorie che di fretta e piena di problemi
    Il Thanks non costa nulla usatelo su chi vi e stato di aiuto
    Guida al Deep Clean
    Tutte le vostre domande qui trovano risposta
    CFKROOT XWLP7
  13. #10
    L'HO VOLUTA PROVARE ... e ora ho il telefono briccato ... mi date un aiutino ?
    uso odin ho scaricato il file sopra e l'ho inserito come PDA una volta scompattato ...
    odin va senza problemi ho solo flaggato auto reboot e f.reset time..quelle di default ,a fine operazione
    il telefono fa un primo riavvio, mi compare il robbottino che frulla poi si riavvia e si pianta sul logo samsung s2 ...
    che fo ? ho provato a ritornare alla precendete la i9100xxlpq_i9100xalpq_xeo .. quella polacca ... ma il telefono si pianta sempre allo stesso modo ...
    che posso fare ho già fatto 3 reflash !!
    soccorso !
