[ROM][4.0.4][AROMA] FOXHOUND 0.1 Cyano+Aokp |Fast|Ota|Customizable [May 26]
http://img821.imageshack.us/img821/7178/featuresd.png
Feature ROM
Based on Cyanogenmod 9 and AOKP
AROMA installer
Costumize installation
Android 4.0.4 -- IMM76I
Unsecure boot.img
Superuser & Busybox preinstalled
Deodexed
180 Degree rotation
Built in performance/init.d configuration (Thanks Kejar & company)
CM Brightness slider
Custom color for anything in RC
Clock Color/Location: Right, Center, Disable
Battery Icon/ Color Picker: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
Battery Bar in Status Bar or Nav Bar, Bar Thickness, Charging animation
Nav Bar Transparency
Nav Bar Button Reorder: Back-Home-Search-Menu
Nav Bar Color Picker
Nav Bar Button Glow Duration: Off, Fast, Slow
Nav Bar: Long press to Search button
Nav Bar Hide on Lockscreen
Toggles in Pull Down Menu: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
LCD Density (Careful with this)
Menu Button location: Right, Left, both, Remove
Menu Button Visability: Always show, Always show Invisible Icons
Lockscreen Style: Quad, Octo, Stock
Lockscreen SMS customizable shortcut
Lockscreen Horizontal Option
Performance Menu: (Use With Caution) Max/ Min CPU, Scaling Governor
Unlock Sceen with Legacy Menu Icon
Volume Key to Wake Screen
Volume Key to Skip Tracks
Long-press back button to kill process
Disable CRT off animation
ICS ringtones/notification sounds
Customize carrier text to whatever.
Power Menu options: Boot to recovery/ Boot loader, Reboot, Screenshot
Facebook contact sync integration (must wipe to get this)
Disable Boot animation
Keyboard: Volume keys act as a cursor while typing -- disable in keyboard options
Long press home for recent apps (thanks brucekey)
Dpi change to 200 (default are 240)
Insert Theme Manager (CM)
Insert TweaksGS2
Insert BLN in settings
Insert Ota app for update ROM
Insert SettingsGS2 (CM)
http://img521.imageshack.us/img521/5...toinstallh.png
1.Fate un bel NANDROID
2.Se provenite da una ROM Base Samsung,installate prima una CM9
3.Rientrate in recovery
4.Wipe data/factory reset in recovery
5.Flash ROM
6.Reboot
Nota bene:
Se l'installazione non dovesse andare a buon fine,basta ripetere l'operazione
http://img254.imageshack.us/img254/9336/downloadpb.png
Download
http://img528.imageshack.us/img528/8537/creditsl.png
AOKP Team - Link
CM9 Team - Link
Aroma Installer - Link
All Xda Developers
