Vi presento un kernel solo per rom AOSP/AOKP sviluppato da pinpong,quindi tutti i meriti e crediti vanno a lui.
Thread ufficiale xda:
[KERNEL][AOSP/AOKP/CM10[7-September][4.2][Thoravukk] APP•TUN•NTFS•CIFS•OC/UV•BLN•OTG - xda-developers
http://img513.imageshack.us/img513/1878/kernelh.png
E' un kernel per rom AOSP/AOKP/CM10.Solo mod stabili con un'ottima durata della batteria.
http://img96.imageshack.us/img96/7796/featuresh.png
based on samung update 7 patched to linux 3.0.42
I/O Schedulers: bfq, noop, sio,
cfq (default), deadline, vr
Governors:
ondemand (default) , lulzactive, conservative interactive, sakuractive,
intelldemand, lagfree, smartassv2, savagedzen, performance, userspace, powersave, brazilianwax, lazy
Bootanimation Support
J4FS: Custom Bootlogo (( you can use helcat's bootscreen changer from market SGS2 BootScreen Changer )
be sure you have reset your flash counter)
XZ Compression
DISABLED CAP_ERASE (No superbrick bug)
Improved Touchscreen sensitivity
Tegrak Second Core App Support
Brilliant Color
Thoravukk control
[APP]Thoravukk Control for Thoravukk Kernel
LED Timout ON/OFF
BLN fadeout / breathing effect
Voodoo Louder Support ( need the VoodooLouder app )
CPU Overclocking & Undervolting support
GPU Overclocking & Undervolting support
Charging voltage support (
use at your own risk )
CIFS
TUN
OTG ( USB mouse and keyboard support )
fuse.ko ntfs support
Compile with special CFLAGS
stripped modules
init.d support
Ultimate Kernel Cleaning Script included
http://img10.imageshack.us/img10/8199/changelogv.png
codice:
***4.3***
init.d script fix
more performance by code opzimizations
add lulzactive governor
***4.2***
It run on Jelly Bean now
***4.1***
linux 3.0.37-42
update to latest samung sources
MDNIE fixes
revert a lot of patches
add lazy governor
bfq, sio, vr tweaked
latest clockworkmod recovery without touch
and a lot of other new and cool stuff
import a lot of fluxi's patches thx to him
***3.40***
wakelock: main_wake_lock fix by tungstwenty
wakelock: (tungstwenty's implementation)
Auto-brightness increased slightly from s3 ( thx hardcore )
MDNIE screen sharpness and color tuning (improves text readability) from s3 ( thx hardcore )
init.d script fix ( was my fault, i forgot to change it after update th initramfs :D )
MDNIE color tuning: reduce color saturation for Standard mode from s3 ( thx hardcore )
Remount all partitions with noatime
Remount ext4 partitions with optimizations
linux 3.0.37
update ramdisk
update ramdisk-recovery
APPLICAZIONE DISPONIBILE SULLO STORE
http://www.android.com/images/brand/...logo_large.png
Downloads:
thoravukk-jb-4.3_cwm.zip
