[KERNEL] [GPL] Ninphetamine-2.0.2 - Now with 100% less Samsungyness
[Kernel][GPL] Ninphetamine-2.0.2 - Now with 100% less Samsungyness - xda-developers
Linko questo fantastico kernel proveniente da Xda.
Ha un sacco di opzioni utili e ottimizzazioni.
Permette di raggiungere un'ottima prestazione nel benchmark.
Permette l'OC fino a 1.6mhz (usare setcpu)
Permette di undervoltare (usare setcpu)
Ninphetamine version 2.0.2 Release Edition
TAR file for Odin/Heimdall/CWM app.
ZIP file for flashing via Clockwork Mod Recovery.
Ninphetamine version 2.0.2 Workaround Edition
As stated earlier, only download this version if you have issues with the release version.
Ninphetamine version 2.0.1 Release Edition
Ninphetamine version 2.0.1 Workaround Edition
Ninphetamine version 2.0.0 Release Edition
Ninphetamine version 2.0.0 Workaround Edition
2.0.2 Release/Workaround Edition
More VPN features added.
JHash updated to version 3.
2.0.1 Release/Workaround Edition
CIFS support added.
Samsung's latest source update applied to base.
Kernel base updated to 2.6.35.11.
Overclock up to 1.6GHz.
Voltage control via SetCPU from 800mV up to 1500mV.
BFQv2-r1 IO scheduler added and set as default.
Optimised EXT4 mount options.
Various other performance related tweaks.
As above, but with some patches applied to workaround errata inherent to some Cortex A8/A9 processors.
All new downloads should download the release version. Only people who get an unexplainable reboot while running under stock 1.2GHz (or less) conditions at normal voltage with no OC software installed should download and install the workaround version.
Thanks
Many thanks to my genius partner netarchy.
Many thanks to my harem of testers, pulser, designgears, Ante0, mattgirv, Obihoernchen, Kullt, Veyka, Lenny, yoda and Rawat.
Setcpu
Consiglio di mettere la modalità scaling in ondemand (flaggano Set on Boot) e di creare un profilo Screen Off 500max e 500mix con Priority 100 ondemand
Voltaggi suggeriti (verificateli e vedete se sono stabili con la vostra CPU). Se notate dei reboot aumentate di 25mv il voltaggio del clock al quale avete avuto il riavvio :cool:
1600 - 1425
1400 - 1275
1200 - 1175
1000 - 1050
800 - 950
500 - 850
200 - 825
Ovviamente prima di lanciarvi in cose strane leggete bene tutte le guide di modding. Non fatelo se siete dei nubbi totali, potreste rischiare di bickare il telefono (in questo caso non mi riterrò responsabile, cazzi vostri).
