[ROM][KI8] Batista70 FOXHOUND EDITION 2.3|Jkay 12|20-10-2011 +++New OTA Updater+++
Guide for Batista70 3.7.7
1) Copy the ZIP file (not unzip) Batista70 ROM memory of the phone sdcard
2) Unplug the USB memory and restart the phone in recovery mode
3) Now select the "Install zip from sdcard" and then the "choose zip from sdcard" and select the Rom Batista70
4) After the installation select the "reboot system now"
XWKI8 Batista70 FoxHound Edition 2.2
-Based on the latest official firmware 2.3.5 WIPE
-Deodexed
-Zipalinged
- Abyss Kernel 2.1 By Angelom
• Added patch's zimage
• Prevention revive syscall due to multiple
• Fix wrong address after relocation SP kernels
• Changed the levels of brightness
• Added patch EXT4
• Adding classic RCU
• Change the tuning options
• Added support MDNIE
• Lowered the value of the automatic brightness
• Added smartass governor
• Added V (R) I / O scheduler
• Based on Samsung kernel Update2 Source (XXKG5) + adj. 2.6.35.11
• Updated to version XXKH3 initramfs
• Fixed problem vibration degradation
• Fixed problem proximity sensor
• Fixed problem WiFi
• Fixed Deep Sleep
• Change frequency (Available: 1536, 1400, 1304, 1200, 1000, 900, 800, 600, 500, 300, 150)
• Voltage adjustable via SetCPU Table (up to 1.5 volts), the voltages are standard default
• Posted ReadAhead tweak
• Updated to version 3 JHash
• Added small tweaks in the Conservative and Ondemand Governor
• Modified Table range and improved contrast and sharpness
• Added fix multitouch
• Enabled ThumbEE
• Enabled by default BFQ V2 I / O scheduler (possible noop, deadline, CFQ, BFQ, v (r))
• Enabled BLN (activated by the application BLN Control)
• On Interactive Governor
• Submissions: Form cifs.ko, tun.ko, fuse.ko, ntfs.ko, nls_utf8.ko
• Changed value of polling battery
• Added custom boot screen
• Submissions and Battery Memory Tweak
• Added ability change GPU clock
• Configuration Optimization
• Imported tweak the kernel to save battery Abyss AOSP
• Changed the kernel optimization
• Changed the kernel optimizationAdded OndemandX Governor
• Added Simple I / O scheduler
• Posted Tweak for Touchscreen
• Added SmartassV2 governor
• Added InteractiveX governor
• Changes in ondemand governor:
• Removed iowait-is-busy-queues tunable
• Added Samplig down factor tunable queues
• Minimum sampling rate set to 10ms
• Enable fast start
• Cpufreq: optimized (removed some unnecessary loops)
• Faster out of the deep sleep
• Optimized Jhash 3
• Modified Wireless: fixed memory leak in case of failure of dhd_bus_init
• modified TCP
• SLUB: Order slub_max set to 0
• modified workqueue
• EMMC put to sleep before the suspension
• Modified ondemand governor
• Modified driver vibration
• Added low-power idle notifier
• Other minor changes to improve compatibility
• Updated to 5.0.2.3 recovery CW
• Input-hotplug tweaks pm
• CK2 patch inserted
• added cpufreq scaling smooth
• ARM optimized algorithm RWSEM
-Theme Original Stock
-NEW Tw 4.5 English By Fr4ggor
-CRT Old-TV Fix
-Added Overglow
-Browser NO Lag
-Added the Mod-Battery with incremental rate of 1%
-Delete the sound notifications full charge and minimum charge battery
-GPS Quick-Fix
-All Framework DEODEXED zipaligned and optimized PNG and has been compressed to save space
-Submitted Gtalk with Video
-Modified the app Mms.apk:
• muveszur_Mms_mod full mod
-Added the Mod rom to improve the bitrate audio / video
-Romoved the Wifi-sharing
- Added VOIP for Wifi
- Added multilingual T9 Dictionaries
- Camera Stock is better NOW on 2.3.5
-Browser no lag with user agent
-Improved Audio
-Jkay 11 not included (for now)
-Transition animations
-Updated hosts to eliminate advertising and web apps
-New phone.apk CallRec integrated (No Auto Rotation + No Increasing Tone ) Thanks Leomar ---Translate
-New Ringtones(FFVICTORY-fringe intro-melody-new born-Sorcerer-V for vendetta-vanh)
-New Notification(confirm-long-shotr-silent-speed.bubbles)
-New Market 3.1.5
-New Bootanimation
-Video and Audio Gtalk Front Camera 2.3.5
-Adding Torch app
-Adding Titanium Backup
-EmailWidget trasparent
-Added CWM app
-Removed some apk samsung
-New Status Bar with 12 button (thanks sileshn and lidroid )
-Remove vibrate icon
-Add Agile Lock
-Add DSP Manager
-Fix red line instead of the call
-Added to change font Fontomizer thanks Guidox
-Added Astro file manager
-NEW Clock Ice Cream
-NEW Music player Ice Cream
-App removed flashable with this ZIP
Thanks Video ROM 3.2 By Gorran And right Video 3.7.1
[YOUTUBE]0Ma7Di240WU[/YOUTUBE] [YOUTUBE]fxBeeBRHoXk[/YOUTUBE]
MORE Video thanks to
pjdannie VIDEO REVIEW 3.2
+++Official Topic+++
Please pressing thank button - Thanks :)
[ROM] Batista70 FoxHound 2.4 Edition by SnakeS 2.3.5 per Galaxy S2 25/10/2011 ++XXKI4
Ciao é uscita la nuova Release la 2.4 con il nuovo kernel di Angelom
XXKI4 Batista70 FoxHound Edition 2.4
-Deodexed
-Zipalinged
-CRT Old-TV Fix
-Added Overglow
-Browser NO Lag
-GPS Quick-Fix
-Improved Audio
-Jkay 12.1 included
-New Ringtones ICS
-New Notification ICS
-New Market 3.1.5
-Bootanimation SnakeS
-Adding Torch app
-Added CWM app
-Add SparePart plus
-Add Agile Lock
-Add DSP Manager
- Fix Audio
- Mod to remove sms from the callog
- New Contact and Dialer Trapsarent on stock
- RolleTube widget trasparent on stock
- Email Widget trasparent on stock
- APN new confing
- BLN full work now
- CSC Multi
- Modem KI1
- Add app Voltage Controll to set your CPU
- Add New script for Undervolt in init.d (more battery save)
- Old Tweaks WIFI
- Add New Camera Hack kI8
- Add app HomeMyHome
- Updated SUPERUSER.apk and Binaries
- New App to download ALL
- Add Maxthon browser
-Fix app FoxHound Update for OTA (now full work)
-Improved AUDIO
-Added more theme in FoxHound Upadate
Aggiornato kernel a ICS ver 1.0
Cambiamenti nel governor Ondemand:
Migliorata stabilità
Inserito fix WiFI
CPUfreq bugfix
Disabilitato Frame point
Cambiato frequenza di wakeup governor SmartassV2
Inserita autocalibrazione batteria al termine della carica
inserito auto-backup cartella EFS inserito in /data/.Abyss
Rimosso iowait-is-busy-tunable code
Aggiunto Samplig down factor tunable code
Impostato Sampling rate minimo a 10ms
Abilitato fast start
Cpufreq: ottimizzato (eliminati alcuni loop inutili)
Velocizzata uscita dal deep sleep
Aumentate performances
Ottimizzato Jhash 3
Modificato wireless: fissato memory leak in caso di fallimento di dhd_bus_init
Modificato TCP
SLUB: impostato ordine slub_max a 0
Modificato workqueue
EMMC messa in sleep prima della sospensione
Modificato governor ondemand
Modificati driver vibrazione
Aggiunto low-power idle notifier
Altre piccole modifiche per miglioramento compatibilità
Aggiornata CW recovery a 4.0.2
Inseriti pm-hotplug tweaks
inserita CK2 patch
inserito cpufreq smooth scaling
Ottimizzato algoritmo ARM RWSEM
Aggiornati alcuni files a base 2.6.35.14
Risolto bug che alla riaccensione dello schermo portava la frequenza a 1536-600
Fissato wrapping timers a 4.294 sec.
Aggiunto cleancache
Aggiunti EXT4 file tweaks
Introdotto cgroups Timer slack subsystem (per meno wakeups)
Abilitati Hard-Float
Regolazione frequenza basata a secondo che gli eventi avvengano con screen on/off
Aggiunta RCU Classica
Introdotte e migliorate alcune macro per memory copy
Disabilitato MALI-400 GPU State Tracking
Rimossa Sync workqueue in wakelock
Velocizzato accesso a cgroupfs
Modificate alcune routines di gestione della mmc
Fissato il problema con alcuni governor nella gestione della massima frequenza.
Tutte le funzioni del kernel Abyss
Batista70 FoxHound 2.4 Download[
