Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 11
[ROM][AOSP/SAMMY][XXALF2][16/06] BlackStaR V2.1 VelocitY OF Ligh + AGGIORNAMENTI
    Torino
    LG G5, LG Nexus 5
    Ringraziato 80 volte in 68 Posts
    [ROM][AOSP/SAMMY][XXALF2][03/07] BlackStaR V3 Jelly Bean Edition + AGGIORNAMENTI
    Ciao a tutti,
    vi presento la rom balckstar per il nostro Galaxy SIII, la rom dotata di kernel siyah si presenta molto fluida e performante ed è consigliata a tutti coloro che non utilizzano e trovano inutili tutte le varie applicazioni samsung.
    Queste sono le descrizioni della rom dalla V1 alla V2.1 :
    BlackStar V3
    Based on stock LF6 Rom
    Deleted all Sammy bloat but all functions working
    Added Crt-On/Off effect
    Added 15 toggles thx gh.rohit
    Themed MMS.apk thx nbeebe24
    SystemUI themed
    Framework themed
    Added Power Profile
    Siyah 1.3.7 Kernel added thx gokhanmoral
    Added Jelly Bean Music app
    Calculator blacked out
    File Manager blacked out
    Added HX-Camera 1.4 thx hyperX
    Jelly Beans Sounds added
    Jelly Beans Animation added
    Jelly Beans Fonts added
    Newest Play Store 3.7.13 blacked out added
    Added GoogleReader blacked out
    Center Clock with ICS color added
    Added newest Apex Launcher
    Added Home lag Fix
    Rom Size about 300mb only
    and more i forget...
    BlackStar V2.1
    Disabled Increasing ring
    Disabled Scrolling Cache
    Added Themed Gtalk
    Themed phone ICS
    Themed Contacts ICS
    Added smooth spinners thx gadgetcheck
    Added siyah 1.1 Kernel thx gokhanmoral http://forum.xda-developers.com/show....php?t=1709686
    Added ExTweaks thx gokhanmoral
    Disabled fast dormancy
    Asus Weather Widget added
    Tweaked some .jar files for more speed and smoothness
    BlackStar V2
    Based on XXALF2
    Very fast and Smooth
    New SystemUi Theme thx jackmu95 modded with new Battery Icon
    Samsung Camera HX-MOD v1.35 thx hyperX
    Extended Power Menu thx Walhalla
    New CM9 MMS with Emoji support and new Theme
    Framework Theme changed
    New Framwork animation
    SiyahKernel S3-v1.0 thx gokhanmoral
    Added Sammy Fmradio
    Added Flipboard
    Added CM9 Browser
    Added CM9 Calculator
    Added CM9 Gallery (you can set fullscreen desktop wallpaper)
    BlackStar V1.1
    Fixed Battery bug
    Changed Launcher to NOVA for better performance
    Added some speed tweaks
    Added blacked out Goggle+
    Added Sammy S-Planner
    Added new ICS Keyboard
    Added newest Hyper Camera 1.30
    Updated SuperSU
    some build.prop tweaks
    New Siyah Kernel v0.92b
    BlackStar V1
    Based on XXALEF Android 4.0.4 (Date: 22/05/2012)
    Rom is Deodexed + Rooted + Zipaligned
    Kernel: Abyss S3 kernel 1.0 Final Stable Version by Angelom
    Rom Size 250mb
    Framework tweaked
    SystemUI Theme changed + percentage Battery
    4-WAY Reboot added
    New Framework Animation
    Deleted all Samsung Bloat, but all features still work
    Added newest CM9 Gapps and blacked them OUT
    ApexLauncher included, can be changed
    Camera MOD HX 1.25 added
    Disabled increasing ring on Phone
    init.d tweaks added
    Added CM9 App Icons
    Added File Manager
    and much more i forget...
    Link Download BalckStar V2.1 : Goo.im Downloads - Downloading BlackStar_V2.1.zip
    Questo è il link della discussione su XDA : ★★★ [ROM][AOSP/SAMMY][XXALF2][16/06] BlackStaR V2.1 VelocitY OF LighT ★★★ - xda-developers
    Per installare questa rom :
    1. Go to CWM
    3. In Recovery wipe data then wipe cache and dalvik
    4. Install BlackStaR
    5. Reboot Phone
    Ultima modifica di Ste Oh Yes; 08-07-12 alle 00:42
    LG G5 + MicroSD SanDisk Extreme Pro 32GB
    Blog Modding Smartphone: http://moddingsmartphone.altervista.org/
    Canale You Tube M.S. : http://www.youtube.com/user/ModdingSmartphone
    <--- CLICCA THANKS
    Senior Droid L'avatar di Maurizio7013
    Ringraziato 34 volte in 30 Posts
    Funziona tutto? Non presenta proprio nulla della stock samsung?
    Torino
    LG G5, LG Nexus 5
    Ciao no non è presente nulla della rom stock
    <--- CLICCA THANKS
    Mar 2009
    metti qualche immagine
    Torino
    LG G5, LG Nexus 5
    Ok entro sta sera le metto
    <--- CLICCA THANKS
    Torino
    LG G5, LG Nexus 5
    Aggiunte Immagini della rom
    <--- CLICCA THANKS
    Torino
    LG G5, LG Nexus 5
    è uscita la verione v3 della rom
    <--- CLICCA THANKS
  9. #8
    Apr 2011
    la seguo da un pò su xda, ma non ho capito se sia wipe o no wipe?altra curiosità tutte le chicche tipo smartview sbean o wifidirect funzionano tutte?in quanto già togliendo già la touchwiz non funzionano più..grazie
  10. #9
    Torino
    LG G5, LG Nexus 5
    Quote Originariamente inviato da scupetta Visualizza il messaggio
    Ciao guarda penso funzioni adesso nei prossimo giorni provo ma penso di si perchè la chiamata diretta per esempio funzionava nella 2.1
    <--- CLICCA THANKS
  11. #10
    Apr 2011
    a sto provando da ieri..leggera e velocissima davvero...peccato che abbia quache bug a livello di tema..in alcuni programmi non si vedono bene i menu a a popup e anche i segni di selezione nell archivio..la touchwiz originale nn c ė e quindi non funziona ne sbeam ne wifi direct
