Visualizzazione dei risultati da 1 a 10 su 26
[ROM] Android Revolution HD | High Quality & Performance | Legendary
    Androidiano VIP L'avatar di ste22032
    Como
    OnePlus 3, S3
    Ringraziato 4,806 volte in 2,635 Posts
    Post
    DESCRIZIONE
    Android 4.0.4 (Ice Cream Sandwich) - latest official Samsung I9300XXLG8 firmware
    This is improved version of stock ROM - no visual changes!
    Very fast, clean & stable!
    Multi-language (WWE)
    Full Arabic and Hebrew languages support! (ICS feature)
    For Samsung Galaxy S3
    Thanks to Samsung for the base firmware
    Stock kernel (the most stable!)
    Removed software (CPU) rendering - full Exynos 4 Quad (GPU) rendering
    Fully optimized and tweaked
    ROOT (su + SuperSu Permissions - Thanks to chainfire)
    Unsecured boot.img
    Newest BusyBox
    RAM optimizations
    System signatures check enabled for system security and safety
    Improved virtual memory management
    Speed optimizations
    Enabled GPU UI rendering
    Data, cache and system partitions mounting tweaks
    Bloatware applications removed
    All /system applications updated to latest available
    All /data applications updated to latest available
    Improved camera performance
    Improved CPU governors performance
    Most optimal system scheduler
    Disabled kernel debugging for better performance
    Zipaligned (Improved RAM management)
    Zipalign on boot (for user applications on data partition)
    Fully de-odexed
    init.d scripts (BusyBox run-parts) support
    Auto init.d permissions set on boot
    sysro/sysrw commands support
    Excellent battery life!
    Improved EXT4 performance
    You can replace Samsung boot animation with any custom one (or use ICS default)
    OpenVPN support
    Most up-to-date system files permissions
    Adobe Flash Player support for Ice Cream Sandwich
    Support almost 24h a day
    ...and many more!!
    Procedura di flash:
    • Scaricare la rom e copiarla sulla micro sd
    • Scaricare lo script Super Wipe e copiare sulla sd
    • Riavviare il telefono in recovery mode (tasto home + tasto vol su + tasto power)
    • Dal menu principale selezionare "install zip from sd card"
    • Selezionare "choose zip from sd card" e poi Super Wipe script
    • Selezionare di nuovo "choose zip from sd card" e poi la rom
    • A processo completato riavviare il telefono!
    DOWNLOADS:
    Android Revolution HD 2.1.1 (31.07.12) --->>> Android Revolution HD - Mirror Site
    Android Revolution HD 2.1.0 (27.07.12) --->>> Android Revolution HD - Mirror Site
    Super wipe script --->>> http://goo.gl/PG4Yg
    Lo script formatta le partizioni data (inclusa la memoria interna del telefono!), system e cache. La micro sd non viene toccata ed è consigliabile lasciarla così com'è, in fat32. E' necessario copiare il file zip della rom sulla micro sd prima di usare lo script Super Wipe, in quanto non verrà persa.
    CHANGELOG:
    codice:
    Android Revolution HD 2.1.1 (31.07.12) (Non serve alcun wipe se si proviene dalla 2.1.x)
    *Services.jar patched with superCharger Launcher Tweak
    *Incorporated SIM-Relock fix
    *Incorporated "Cell stand by" fix
    *Adobe Reader updated to latest 10.3.1
    *Google Play updated to latest 3.7.15
    *DropBox updated to latest 2.1.8
    *YouTube updated to latest 4.0.23
    *Other minor changes and fixes
    Android Revolution HD 2.1.0 (27.07.12) (Super Wipe consigliatissimo!)
    *Re-based using latest I9300XXLG8 firmware
    Android Revolution HD 1.0.0
    *Initial release
    Tutti i meriti sono di Mike1986 e del suo team e vanno riconosciuti a loro.
    THREAD DI RIFERIMENTO XDA -> [ROM] Android Revolution HD 2.1.1 | High Quality & Performance | ICS | Legendary - xda-developers
    Ultima modifica di ste22032; 01-08-12 alle 13:26
  2. Il seguente Utente ha ringraziato ste22032 per il post:
    ValoX (31-07-12)
    Como
    OnePlus 3, S3
    Riservato!
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    ciao, volevo visionare il thread di riferimento, ma non trovo il link
  6. #4
    Genova
    Galaxy s 5
    Ringraziato 4 volte in 2 Posts
    Com é sta rom ?
  7. #5
    Androidiano VIP L'avatar di Linuxx
    Nowhere
    Samsung Galaxy Note 2 Immortal
    Ringraziato 815 volte in 619 Posts
    Ma quel Super Wipe Script si può usare solo su questa rom o si può usare benissimo quando si deve fare full wipe per qualsiasi cosa? Sarebbe interessante usarlo per tutto senza dover fare sempre wipe manuali. (non che ci voglia così tanto tempo)
  8. #6
    Quote Originariamente inviato da Linuxx Visualizza il messaggio
    lo puoi usare sempre, visto che si flasha prima , non è legato alla rom
  9. Il seguente Utente ha ringraziato dieguccio per il post:
    Linuxx (31-07-12)
  10. #7
    Nowhere
    Interesssssante!!! Me lo carico sulla sd esterna!
  11. #8
    Como
    OnePlus 3, S3
    Ciao dieguccio, il link del thread di riferimento è questo: [ROM] Android Revolution HD 2.1.0 | High Quality & Performance | ICS | Legendary - xda-developers
    Quote Originariamente inviato da kameomax Visualizza il messaggio
    Com é sta rom ?
    Purtroppo il mio telefono è ancora in assistenza e non ho la possibilità di provarla... comunque su xda ne parlano molto bene. Inoltre posso dirti che io ho già utilizzato in passato le rom di mike sui miei htc e sono davvero prestanti e stabili!
  12. Il seguente Utente ha ringraziato ste22032 per il post:
    ValoX (31-07-12)
  13. #9
    Androidiano VIP L'avatar di ValoX
    Bari
    Ringraziato 469 volte in 282 Posts
    Proverò anche questa. Sembra interessante.
    Modello: -
    ROM: -
    Operatore: Iliad
    Github: ValoXTech
  14. #10
    Quote Originariamente inviato da cubeacid Visualizza il messaggio
