Visualizzazione dei risultati da 1 a 10 su 24
[ROM][AOSP][JB][4.1.1] Android 4.1.1 JellyBean
    Androidiano VIP L'avatar di pittar
    huhuuhuhhuuhuhuh
    htc m8 lg g2 nexus 5x
    Ringraziato 409 volte in 252 Posts
    Cool
    THREAD IN CONTINUO AGGIORNAMENTO PER RILASCIO DI BUILD SEMPRE PIU FUNZIONANTI
    DETTAGLI DI SISTEMA:
    Android ICS 4.1.1 (JRO03H - Android-4.1.1_r3)
    ultimo kernel compilato sulle sorgenti di cm(cyanogen mode)
    tutte le caratteristiche e apps di jelly bean (nessuna esclusa dall' AOSP)
    nessuna variazione al tema
    tutto stock jelly bean
    questa rom cambiera' il tuo s3 in un galaxy nexus google experience
    CARATTERISTICHE DELLA ROM:
    Fully Deodexed
    Zipaligned APKs
    Rooted (Super SU)
    BusyBox Installed
    No 3rd Party App
    ZERO Bloatware
    Official Jelly Bean Bootanimation (From Official Galaxy Nexus Android 4.1.1 Factory Image)
    Init.d Support
    COSA FUNZIONA
    WiFi - BT - NFC
    HW Composer - Sensors - Audio
    Data - Calls - SMS - MMS
    Mostly Everything is Working
    BUG CONOSCIUTI
    Wi-Fi tethering is semi-broken
    Found one ? Report it.
    REQUISITI PER FLASHARE LA ROM:
    Clockworkmod Recovery (CWM)/Any custom recovery
    Wipe se provieni da qualsiasi custom rom
    GUIDA AL FLASH:
    copiare le gapps e la rom nella micro sd
    avviare in recovery
    eseguire il wipe data/factory reset
    flashare la rom
    Flashare le Google Apps
    riavviare
    buon divertimento
    downloads
    BUILD(#2) :
    Hotfile.com: 1-CLICK Dateihoster: AOSP-JB-I9300-BUILD2.zip
    BUILD(#3)
    http://api.viglink.com/api/click?for...13438057197491
    Google Apps:
    http://api.viglink.com/api/click?for...13437203362082
    Source Code:
    http://api.viglink.com/api/click?for...13438087819161
    Changelog:
    AOSP JB I9300 BUILD2 (30-07-12):
    Fixed Google Now FC Issue
    Added APN List
    Added SPN List
    Added Device Asserts in Updater-Script (So noobs don't flash this on a different device)
    AOSP JB I9300 BUILD3 (30-07-12):
    Fixed Play Store issue
    Fixed SD Card issue
    screenshot
    Screenshot_2012-07-18-11-39-12.jpgscreenshot2012073003330.jpgScreenshot_2012-07-04-13-05-50.jpgscreenshot2012073003324.jpg
    potete seguire l autore su twitter
    http://api.viglink.com/api/click?for...13437314109162
    NON SONO RESPONSABILE IN NESSUN MODO NE' DI EVENTUALI MALFUNZIONAMENTI DEI VOSTRI TERMINALI NE' DI EVENTUALI BRICK
    Immagini allegate
    Ultima modifica di pittar; 06-08-12 alle 11:49
    http://www.androidiani.com/forum/avatars_and_pics/signaturepics/sigpic95055_6.gif
    huhuuhuhhuuhuhuh
    reserved.......#1
    huhuuhuhhuuhuhuh
    reserved...........#2
    cosa sarebbe?
    DEVICE:HTC One
    ROM: Rayglobe
    KERNEL: Stock
    huhuuhuhhuuhuhuh
    Quote Originariamente inviato da IcedEarth Visualizza il messaggio
    cosa sarebbe?
    le prime build.........quindi non piu' preview
  7. Il seguente Utente ha ringraziato pittar per il post:
    IcedEarth (31-07-12)
  8. #6
    ah ok ma devo scaricare anche Previous Builds?le prime due già scaricate
    DEVICE:HTC One
    ROM: Rayglobe
    KERNEL: Stock
  9. #7
    huhuuhuhhuuhuhuh
    Quote Originariamente inviato da icedearth Visualizza il messaggio
    ah ok ma devo scaricare anche previous builds?le prime due già scaricate
    la previous build....sarebbe la prima che e' uscita.......scarica direttamente la seconda.....:d
  10. Il seguente Utente ha ringraziato pittar per il post:
  11. #8
    ok allora solo le prime due,grazie
    DEVICE:HTC One
    ROM: Rayglobe
    KERNEL: Stock
  12. #9
    Senior Droid L'avatar di LPirro
    Aug 2010
    Google Nexus 5
    Ringraziato 78 volte in 48 Posts
    Quote Originariamente inviato da peterpan79 Visualizza il messaggio
    Guarda che sono basate sull preview di Cyanogen, quindi sono delle preview anche queste! E' praticamente uguale alla ROM CyanogenMod10 con gli stessi problemi. L'unica cosa che sono state eliminate le personalizzazioni CyanogenMod (lockscreen, bootanimation, piccoli tweek nelle impostazioni, ecc). E' un Android puro.
  13. Il seguente Utente ha ringraziato LPirro per il post:
  14. #10
    x cui nn vale la pena provare questa build?
    DEVICE:HTC One
    ROM: Rayglobe
    KERNEL: Stock
