Utente della settimana: megthebest con ben 16 Thanks ricevuti negli ultimi sette giorni
Pagina 1 di 15 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 150
[KERNEL APP][SIYAH] "SiyahMODs" APK PER CHI VUOLE TRE & QUATTRO ROM!
    Androidiano VIP L'avatar di alegu
    Localitą
    MILANO
    NOTE3
    Ringraziato 2,319 volte in 1,584 Posts
    QUI TROVATE UNA GUIDA AL DUALBOOT
    DUALBOOT
    DOPO QUALCHE GIORNO DI TEST MI SENTO DI PUBBLICARE QUALCOSA INERENTE A QUESTA APK CHE PERMETTE DI INSTALLARE ADDIRITTURA 4 ROM NELLO STESSO TELEFONO PURCHE' ABBIATE INSTALLATO COME KERNEL IL SIYAH 1.8.9
    LINK E RINGRAZIAMENTI SU XDA QUI [KERNEL APP]][SIYAH]=SiyahMODs= APK-V4.1-Boot-Shrink-TripleBoot...MORE!>>> - xda-developers
    Welcome to SiyahMODs V4.6...
    ***BIG UPDATE... MORE TO COME***
    Quad boot has arrived!
    >>>Clone 3rd to 4thROM
    >>>Swap 3rd and 4thROMs
    >>>Name 4thROM
    >>>Remove 4thROM
    >>>Brand new 4thROM popup window
    >>> Big clean up to total task operations.
    >>> Simlink .defaultrom from the "Zero" folder so S tweaks will be able to access this file from AOSP ROM.
    http://db.tt/CM0B2tkP V4.6
    APRITE L'APK E VI APPARIRA LA SCHERMATA QUI SOPRA DOVE TROVERETE DIVERSE OPZIONI CHE ILLUSTRERO'
    TRA LE OPZIONI TROVERETE:
    1-REBOOT SECOND ROM: IL TELEFONO SI RIAVVIERA' NELLA ROM CHE AVETE SECONDARIA
    2-RBT TO 2nd UTIL: IL TELEFONO SI RIAVVIA NELLA RECOVERY DEL SIYAH RELATIVA ALLA ROM SECONDARIA
    3-REBOOT TO 3rd ROM: IL TELEFONO SI RIAVVIERA' NELLA TERZA ROM DA VOI INSTALLATA
    4-RESTORE 2nd: RESTORA LO SPAZIO SU SDCARD INTERNA DA 1,5 Gb DELLA SECONDA ROM MODIFICABILE CON "SHRINK 2nd"
    5-RESTORE 3rd: RESTORA LO SPAZIO SU SDCARD INTERNA DA 1,5 Gb DELLA TERZA ROM MODIFICABILE CON "SHRINK 3rd"
    6-SWAP ROMs: SCAMBIA DI POSTO LA SECONDA ROM CON LA TERZA ROM
    7-MOUNT 2nd ROM:
    8-MOUNT 3rd ROM:
    9-UNMOUNT 2nd ROM:
    10-UNMOUNT 3rd ROM:
    11-SAVE IMPUT: COMANDO PER CONFERMARE "NAME" "SHRINK 2nd" E SHRINK 3rd"
    12-ROMs STATUS: SERVE PER CAPIRE QUALE ROM C'E' COME SECONARIA E TERZIARIA E LA LORO RELATIVA DIMENSIONE
    13-NAME: SERVE PER CAMBIARE NOME ALLA SECONDARIA E TERZIARIA
    14-SHRINK 2nd: COMANDO PER RIMPICCIOLIRE LA CARTELLA RELATIVA ALLA SECONDA ROM CHE DI DEFAULT E' IMPOSTATA A 1,5 Gb
    15-SHRINK 3rd: COMANDO PER RIMPICCIOLIRE LA CARTELLA RELATIVA ALLA TERZA ROM CHE DI DEFAULT E' IMPOSTATA A 1,5 GB
    ORA VENIAMO AL DUNQUE SU COME SI USA
    1-INSTALLARE L'APK "SIYAHMOD" SU PRIMARIA
    2-INSTALLARE LA ROM SECONDARIA DAL MENU' DUALBOOT CHE TROVATE IN STWEAKS
    3-INSTALLATE ANCHE QUI L'APK "SIYAHMOD" SU SECONDARIA
    4-DA SECONDARIA FATE "SWAP ROMs" E VERRA' SPOSTATA LA SECONDARIA COME TERZA ROM
    5- A QUESTO PUNTO AVRETE LO SPAZIO LIBERO PER INSTALLARE UNA NUOVA SECONDA ROM SEMPRE DAL MENU' DUALBOOT DI EXTWEAKS
    6-UNA VOLTA INSTALLATA LA "NUOVA SECONDA ROM" AVRETE FINALMENTE TRE ROM SUL VOSTRO CELLULARE
    7-INSTALLATE L'APK ANCHE SULLA NUOVA SECONDARIA
    SUCCESSIVAMENTE:
    1-APRENDO L'APK "SIYAHMOD" IN BASSO A SINISTRA E A DESTRA TROVERETE SCRITTE LE DIMENSIONI DELLE VOSTRE ROM ACCANTO A "system.img"
    2-DI DEFAULT QUESTO "system.img" E' DI 1,5 GB OCCUPANDO PIU' SPAZIO DI QUELLO CHE OCCORRE AD OGNI SINGOLA MOD
    3-QUINDI A QUESTO PUNTO CAPIRETE A COSA SERVE "SHRINK 2nd":GUARDATE IN MB QUANTO E' GRANDE "data size" DELLA SECONDA ROM TAPPANDOGLI SOPRA A "SHRINK 2nd" VI SI APRIRA' UNA SCHERMATA RETTANGOLARE BIANCA IN CUI DOVRETE METTERE LA GRANDEZZA DELLA ROM PRECEDENTEMENTE LETTA +100 MB (CONSIGLIATO DALL'AUTORE DELL'APK) E TAPPATE "SAVE INPUT"... CI IMPIEGHERA' QUALCHE MINUTO
    4-QUINDI A QUESTO PUNTO CAPIRETE A COSA SERVE "SHRINK 3rd":GUARDATE IN MB QUANTO E' GRANDE "data size" DELLA TERZA ROM TAPPANDOGLI SOPRA A "SHRINK 3rd" VI SI APRIRA' UNA SCHERMATA RETTANGOLARE BIANCA IN CUI DOVRETE METTERE LA GRANDEZZA DELLA ROM PRECEDENTEMENTE LETTA +100 MB (CONSIGLIATO DALL'AUTORE DELL'APK) E TAPPATE "SAVE INPUT"... CI IMPIEGHERA' QUALCHE MINUTO
    5-"NAME":CON QUESTO COMANDO SI POSSONO DARE I NOMI ALLE RISPETTIVE ROM, TAPPANDOLO SI APRIRA' UNA SCHERMATA BIANCA A SINISTRA IN CUI SI NOMINERA' LA SECONDARIA E PER CONFERMARE "SAVE INPUT", SI APRIRA' UN'ALTRA SCHERMATA BIANCA IN CUI SI RINOMINERA' LA TERZA E PER CONFERMARE "SAVE INPUT".
    NON SONO, IL RESPONSABILE SE VI BRIKKATE IL TELEFONO, NE' TANTO MENO IL BLOG "ANDROIDIANI", SIAMO TUTTI MAGGIORENNI!.
    Ultima modifica di alegu; 06-03-13 alle 12:19
  2. I seguenti 11 Utenti hanno ringraziato alegu per il post:
    Anna (16-11-12),blasf70 (15-11-12),Dragonheart (27-03-13),Fuoritempo (18-11-12),illuminato67 (20-12-12),N1m0Y (05-05-13),PatrickBateman (05-03-13),Pietrone94 (09-01-13),Ragz (12-02-13),skricciolo1981 (06-04-13),TopoMonko (28-01-13)
    Localitą
    MILANO
    NOTE3
    Mioanche questo si sa mai
  5. #3
    Localitą
    MILANO
    NOTE3
    Soffigo o no
  6. #4
    Androidiano VIP L'avatar di blasf70
    galaxy s4, galaxy s5, gear2neo
    Ringraziato 115 volte in 105 Posts
    Grande alegu, guida perfetta...
  7. #5
    Localitą
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    Quote Originariamente inviato da alegu Visualizza il messaggio
    Soffigo o no
    Ma si che lo sei :-*
    Inviato con s3 che fa tip tap con tapatalk
  8. #6
    E io che avevo capito che si metteva nel thread del siyah....
    Non capisco mai nulla sono vecchio ormai
    Trollallero Trollallį
  9. #7
    Localitą
    MILANO
    NOTE3
    Quote Originariamente inviato da JacOcaJ Visualizza il messaggio
    Non lo avevo capito io...fai copia incolla e mettilo nel Siyah...e' uguale...:thumbup:
    INVIATO DA ? CON IL MIO S?
  10. #8
    No, va benissimo cosģ... Ho gią messo i riferimenti nel thread.
  11. #9
    Androidiano VIP L'avatar di diegomattia
    samsung galaxy s galaxy s3
    Ringraziato 2,848 volte in 1,796 Posts
    scusate la domanda ..questo passaggio vorrei capirlo bene
    3-QUINDI A QUESTO PUNTO CAPIRETE A COSA SERVE "SHRINK 2nd":GUARDATE IN MB QUANTO E' GRANDE "system.img" DELLA SECONDA ROM TAPPANDOGLI SOPRA A "SHRINK 2nd" VI SI APRIRA' UNA SCHERMATA RETTANGOLARE BIANCA IN CUI DOVRETE METTERE LA GRANDEZZA DELLA ROM PRECEDENTEMENTE LETTA +100 MB (CONSIGLIATO DALL'AUTORE DELL'APK) E TAPPATE "SAVE INPUT"
    adesso il file image e di 1536 mb e fin qui ci siamo
    mentre la rom e di 957 mb
    ecco io adesso dovrei mettere come valore 1057 mb ?
    Se volete offrirmi un caffč,cosi lavoro ancora di piu (schiavisti) c'e' questo
    SpartaRom - Frankenstein Team
    Il Ritrovo degli Spartani http://www.androidiani.com/forum/off...ml#post3548701
  12. Il seguente Utente ha ringraziato diegomattia per il post:
    impazzito89 (07-08-13)
  13. #10
    Localitą
    MILANO
    NOTE3
    Quote Originariamente inviato da diegomattia Visualizza il messaggio
    Perfetto...proprio cosi...
