Visualizzazione dei risultati da 1 a 10 su 45
[KERNEL] SpeedMod S3 Jelly Bean [ K2-7 SDS_Fix ROOT BRIGHTNESS+ ]
    Moderatore L'avatar di BlackJack89
    Vault 105
    OnePlus 5
    Ringraziato 741 volte in 538 Posts
    Dopo il kernel per ICS, presente QUI, Hardore ha sviluppato lo stesso kernel, per JB
    Caratteristiche
    • NO UV, NO OC o modificazioni che potrebbero provocare instabilità al Sistema
    • Ottimizzato attraverso l'implementazione del Codice
    • Ottima durata della batteria attraverso la rimozione dei file log e di debug
    Ecco qui le modifiche
    Root:
    - Automatically installs root (SuperUser and su) but can be disabled
    Screen and misc tweaks:
    - Auto-brightness increased slightly (in low-to-mid light)
    - MDNIE screen sharpness and color tuning (improves text readability)
    - init.d, TUN, CIFS, IPV6 Privacy support
    - Fixed freeze on FC problem with Samsung ICS & JB ROMs
    Performance:
    - CPU governor tweaks: increase responsiveness
    - IO tweaks
    - Read ahead tweaks
    - Compiled with optimizations using CodeSourcery GCC toolchain
    - Optimized GPU DVFS
    - ARM CPU topology support
    - SCHED_MC multi-core aware scheduler
    Turned off unnecessary logging for better smoothness and efficiency:
    - Disabled Android Debug Logger / logcat
    - Disabled Samsung debug
    - Disabled various kernel debugging, statistics and tracing options
    Versione K2-3 (e precedenti)
    - Updated to JB_Opensource_Update6 Samsung source code
    - Moved to SuperSU (Existing Superuser app will be auto-replaced with SuperSU)
    - Implemented fix for "freeze on FC (Force Close)" problem caused by dumpstate
    - Added ExFAT support via Samsung's proprietary kernel modules
    - Rebuilt based on GT-I9300_ICS_Opensource_Update4 source code
    - Rebuilt using Codesourcery 2012.03 GCC 4.6.3 toolchain
    - Minor tweaks to pegasusq cpu and hotplug governor
    - Minor tweaks to GPU DVFS driver
    Download Discussione Ufficiale XDA
    Flash solo da Odin
    - Mettere in download mode l'S3
    - Aprire Odin e mettere in PDA il file *tar
    - flash
    Un Grazie è sempre ben accetto
  2. I seguenti 2 Utenti hanno ringraziato BlackJack89 per il post:
    N1m0Y (05-05-13),scimmia01 (27-06-13)
    Vault 105
    OnePlus 5
    Come abilitare alcune funzioni
    [HOW TO ENABLE LOGCAT]
    If you are a developer or want to re-enable logcat for whatever reason, do this:
    • adb shell
    • su
    • mount -o remount,rw /system
    • echo ANDROIDLOGGER >> /system/etc/tweaks.conf
    • mount -o remount,ro /system
    [HOW TO DISABLE AUTO-ROOT]
    Create a file called ".noautoroot" in either /system or /data. This will disable the auto root installation. This example, shows how to remove root completely:
    • adb root
    • adb shell
    • rm /system/xbin/su
    • rm /system/app/Superuser.apk
    • rm /data/app/Superuser.apk
    • touch /system/.noautoroot
    • sync
    • reboot
    [HOW TO RE-ENABLE AUTO-ROOT]
    • adb root
    • adb shell
    • rm /system/.noautoroot
    • sync
    • reboot
  5. Il seguente Utente ha ringraziato BlackJack89 per il post:
    N1m0Y (05-05-13)
  6. #3
    Androidiano VIP L'avatar di chiccomix
    Arezzo
    Samsung Galaxy S3
    Ringraziato 102 volte in 88 Posts
    Ho un problema con il phenomenal perchè mi causa il malfunzionamento della telecamera in modalità video pertanto vorre provare lo speedmood. Ho letto che questo kernel comprende già il root per cui volevo chiedere se il fatto che abbia già fatto il root al terminale con il CF-Root 6.4 possa o meno comportare qualche problema.
  7. #4
    Vault 105
    OnePlus 5
    Quote Originariamente inviato da chiccomix Visualizza il messaggio
    Nessun problema
  8. #5
    Arezzo
    Samsung Galaxy S3
    Quote Originariamente inviato da BlackJack89 Visualizza il messaggio
    Nessun problema
    Ho aggiornato oggi dalla LL5 alla LLA il cui kernel, a quanto ho letto, dovrebbe correggere il problema della sudden death. L'ultima versione dello speedmood tiene conto di questo problema?
    EDIT
    Ho trovato la risposta sul sulla discussione su XDA e ho visto la K2-5 contiene il fix a questo punto provo a installarlo. Se ho capito bene con questo kernel viene installata anche la sua recovery giusto?
    Ultima modifica di chiccomix; 29-01-13 alle 15:51
  9. #6
    buon giorno a tutti non so se sono nella sezione giusta e se riuscirò ha spiegarmi bene ma ci provo.
    ho da poco installato la rom rootbox 4.2.2 con kerlel 3.0.31-cm-gc715892.volevo sostituirlo con un altro kernel tipo SpeedMod Jelly Bean,BOEFFA,Abyss,ecc.
    ma riesco solo ad installare il kernel Siyah.gli altri dolo installazione il telefono non si riavvia e mi rimane lo schermo nero,mi tocca fare un full wipe e ricominciare.
    la procedura che uso è. download del kernel in zip.copio nella sd esterna.entro in recowery faccio wipe data poi wipe cache install zip,intalo il kenel,ri facio i wipe di prima e riavvio.
    mi dite se sbaglio.
    grazie buona giornata.
  10. #7
    Androidiano VIP L'avatar di TopoMonko
    Romagna
    Note 4 - G4
    Ringraziato 593 volte in 437 Posts
    Quote Originariamente inviato da randone Visualizza il messaggio
    mi dite se sbaglio.
    Può essere che qualche file o script del vecchio kernel vada in conflitto con quello che vuoi installare.. per questo poi non riesce a avviarsi il cell!
    Prova a usare lo script di pulizia per il kernel di Slim che trovi qui: https://www.androidiani.com/forum/mo...-1-slim80.html
    Flasha lo script
    Flasha il nuovo kernel
    Riavvia
    HTC One - Black Pearl 32GB
    Se ti sono stato d'aiuto Ringraziami con il tasto "Thanks"
  11. #8
    Androidiano VIP L'avatar di alegu
    MILANO
    NOTE3
    Ringraziato 2,319 volte in 1,584 Posts
    Online K2-7:
    - Updated to JB_Opensource_Update8 source code
    - Additional protection from data loss: disable ext4 delayed allocation (nodelalloc) *
    * This will result in slightly lower IO benchmark scores (e.g. Quadrant) but no real-world difference
    oihcceps ollad klatapat noc otaivnI
  12. #9
    Catania
    Samsung Galaxy S3
    Raga ho appena scaricato il kernel, scusate le stupide domande ma con la room stock va bene? una volta installato devo configurare qualcosa? Grazie mille in anticipo!
  13. #10
    MILANO
    NOTE3
    Quote Originariamente inviato da DamiCairoli Visualizza il messaggio
    Io ho stock xxemr2 e va bene...non devi configurare nulla visto che non c'è possibilità tranne se hai "tegrak overclock" a pagamento dal playstore ed in questo caso puoi cambiare gpu cpu undervoltando, overvoltando, underclokkando e overclokkando...ma non ne vale la pena secondo me...io già ce l'avevo per cui te lo dico.
  14. Il seguente Utente ha ringraziato alegu per il post:
    DamiCairoli (28-02-13)
