Visualizzazione dei risultati da 1 a 10 su 50
[ KERNEL ][22/01]· ▀▄ · Kernel 3.0.58 HydRx-v4r97 - For Samsung Stock-JB -
    Androidiano VIP L'avatar di linus98
    Jan 2011
    Palermo
    HTC Diamond, HTC HD2, GS3, GS6
    Ringraziato 1,358 volte in 776 Posts
    [ KERNEL ][04feb] ▀▄ · Kernel 3.0.61 HydRx-v5r2 - For Samsung Stock-JB ▀▄
    Ciao ragazzi, vi segnalo questo kernel che, con le dovute ottimizzazioni, ho sulla ROM in firma.
    HydRx-v5r2
    JB Kernel for Samsung Stock ROMS
    Only for stock jelly bean ROMS
    EXTREME won't work in all mobiles so, if don't work extreme for you, put Semi.
    The config:
    * Based on 3.0.57 - Yank.555+neak with patches, configs, optimizations and tweaks (so thanks to Yank and Simone)
    * OC up to 1700mhz.
    * Reduced low cpu steps to get some performance (Deleted 300mhz, 400mhz, and 600mhz)
    * Voltages:
    * EXTREME:
    Cpu arm : -112,5mv in all freqs from 200 to 1500mhz (low freqs as 200,500 +12,5mV)
    Cpu internal: -50mv in all freqs
    Bus: -100mv in all freqs
    Gpu: -100mv in all freqs
    * SEMI:
    Cpu arm : -87,5mv in all freqs from 200 to 1500mhz (low freqs as 200,500 +12,5mV)
    Bus: -75mv in all freqs
    Gpu: -75mv in all freqs
    * MEDIUM:
    Cpu arm : -62,5mv in all freqs from 200 to 1500mhz (low freqs as 200,500 +12,5mV)
    Cpu internal: -37,5mv in all freqs
    Bus: -50mv in all freqs
    Gpu: -50mv in all freqs
    • Tree RCU+NO_HZ
    • SIO Iosched enabled by default and tweaked.
    • Governor hydrxq (simply a lulzactiveq governor with tweaks to performance (thanks to tegrak), if you see it drains much with this governor, you can
      select pegasusq governor with voltage control)
    • Disabled Tracing, logging, and debugging.
    • Some compiler CFLAGS optimizations added (linaro toolchain)
    • Tweaks virtual mem, I/O, kernel & scheduler.
    • Set wifi power limit to 8dBm.
    • Max powersave in sleep mode with some modifications and screenstate:
    *More stable GPU voltajes set on the fly when you screen off the display (min 775mV).
    *Cleaning of cache/inodes when you screen off, and each 6 hours.
    *laptop mode enabled with screen off.
    *some tweaks more when you screen off I consider they save power.
    • Priorized some system apps at boot, to get some a performance system..
    • Auto script to close all possible samsung apps at boot.
    • Swap compatible, but not used for now.
    • Stand alone hotplug tweaked to low usage of cores.
    • Sound eargasm voodoo patch added controlable with STweaks from market. (thanks to gokhanmoral)
    • Tweaks mdni, for better colors.
    • More powersave in 2G/3G networks and wifi supplicant time modified.
    • I forget some things I'll put more.
    • etc
    GPL: https://github.com/NeoPhyTe-x360/i9300-S3-JB-kernel
    [*] It's not compatible with 64GB exFAT sdcards (if you like to see your files you have to format your sd64 in FAT) [It's a common issue with updated kernels and proprietary modules]
    Some versions go from letter A to letter D.
    Letter A; Less UV, internal are more "conflictive" voltages, so letter A is a "light" uv in internals
    to
    Letter D: More UV, the most UV possible, agressive internal volts and -125mV GPU volts, the maximum possible without freezes in some devices.
    Download:
    Ultima modifica di linus98; 11-03-13 alle 20:29
  2. Il seguente Utente ha ringraziato linus98 per il post:
    Zangetsu (15-01-13)
    Jan 2011
    Palermo
    Riservato....
  5. #3
    Sicilia
    Samsung Galaxy S5,S4, S3
    Ringraziato 47 volte in 43 Posts
    io ho scaricato la versione HydRx v4r59...poi tramite aroma installer scelgo da la gli UV? ora come ora sto usando quello piu estremo...oppure ne esiste uno tra quelli postati nel primo post ancora piu parsimoniosi di batteria???
    Samsung Galaxy S5 Italia - No Brand
    ROM: 4.4.2 Stock
    Modem: Stock (Vodafone)
    Kernel: Stock
  6. #4
    Jan 2011
    Palermo
    Non c'è un kernel che vada bene per tutti, provali e scegli il migliore per il tuo utilizzo
  7. #5
    Sicilia
    Quote Originariamente inviato da linus98 Visualizza il messaggio
    a me non interessa quello che va bene per tutti XD
    a me interesserebbe sapere quello che dovrebbe durare di piu? come ti ho gia detto nell'installer ho selezionato il penultimo...extreme plus se non ricordo male? è quello meno dispendioso di batteria?
    ROM: 4.4.2 Stock
    Kernel: Stock
  8. #6
    Androidiano VIP L'avatar di Zangetsu
    Torino
    Samsung Galaxy S9+ G965F
    Ringraziato 394 volte in 324 Posts
    (Il server per il download è momentaneamente fuori servizio)
    Tra i vari download, a me che provengo dal Siyah quale consigliate?
    Vorrei un settaggio con prestazioni il più vicine possibili al siyah ma senza overlock rischioso brucia telefono e con una durata della batteria superiore rispetto a quella del siyah (che si fa fuori il telefono dopo 5/6 ore di utilizzo schermo) e che non mi inibisca il telefono come il boeffla.
    Ultima modifica di Zangetsu; 14-01-13 alle 13:34
    Se ti sono stato d'aiuto, clicca GRAZIE.
  9. #7
    Sicilia
    Quote Originariamente inviato da Zangetsu Visualizza il messaggio
    io penso che se fai 5/6 ore di schermo acceso con il siyah non lo dovresti cambiare...non so che uso ne fai ma fare 5 ore di schermo acceso è gia un record mi sa...
    a meno che tu non lo accendi e guardi il display senza fare nulla XD
    ROM: 4.4.2 Stock
    Kernel: Stock
  10. #8
    Torino
    Quote Originariamente inviato da Corrado89 Visualizza il messaggio
    Intendevo solo schermo. Ahah
    Con applicazioni e uso intenso arrivo si e no a 3 ore.
  11. #9
    Sicilia
    ah ecco...XD
    a sto punto punto io come durata mi sono trovato bene con il bleckened o adesso che sto provando questo pensa sia ancora migliore e in piu ti consente un OC fino a 1700! provalo e quando lo installi con l'AROMA installer non scegliere raccomandato e prova le varie configurazioni di undervolt...ieri per esempio ho fatto 2 ore di display in 13 ore e ancora mi rimaneva il 55% di batteria...non l'ho usato tantissimo ma gia 2 ore di display acceso con ancora il 55% non credo siano male!
    ROM: 4.4.2 Stock
    Kernel: Stock
  12. #10
    Senior Droid L'avatar di clark12
    Jul 2009
    Ringraziato 52 volte in 29 Posts
    In test...
